Here is what I know...but there must be a more rigorous - and safe/effective - methodology.
I take my trailer out to some big parking lot and slam on the brakes...adjusting the control until all action seems to be appropriate - no premature locking or nosediving, etc.
With that as a base reference, a heavier load takes a higher number; a lighter load a lower.
Now....what's the proper way? Please.....
Sold: 1999 White Lariat CC SB F-250. Sold to next-door neighbor in 2001....received final payment 2007! Still going strong at 198Kmiles as of Dec'07
Sold: 2001 Bright Amber Lariat CC LB F-250 with 4 million candlepower of LightForce lights in the bow. Line-X bedliner. Dual alternator. Clearance lights. Glass-tite cap. 250-gallon auxiliary tank for trips to the Lesser 48. 70-gallon auxiliary for trips around Alaska. Rec'd Dec'07: '08 ForestGreen/Gold F-350 CC LB. Handshaker, as always, Rear stabilizer, rear static video, rear step, dual alternators. B&W turnover ball on its way; soon to be Line-X'd. LightForces on their way.
Not sure if it is exactly proper but I jack up each wheel and adjust until I just feel drag, then back off a click or two. I then tow the trailer and closely watch the trailer while driving straight and watching for any slight movement of the trailer to one side when applying the brakes to be sure they are balanced left to right. Also after hauling a heavy load down a hill with hard brake use I will check the drums with an IR gun through the wheel slots, you can tell pretty quick which ones are working too hard or not enough.
Not sure if your brakes are like mine for not, but my trailer brakes are NOT self-adjusting. You have to jack the wheel up and using a brake adjusting tool or screwdriver, turn the cog inside the brake housing until it starts to drag and then back off just a bit.
Florida Ed
2001 7.3 F-350 Dually Lariat CC LWB 4X2 Dark Green 4.10 4R100 5'ver Hauler (32' Montana 2 slides 10,500# - 2,000# tongue weight), 106 gal aux tank, 112K miles, nephews arguing over who will inherit it 'cause I'm gonna' drive it 'til I die. Bone stock.
2001 5.4 Gasser F-250 XLT Crewcab SWB 4X2 3.73 4R100 67K miles headed to 150K (wife's vehicle on the "junk-iron" theory of vehicle safety....most junk iron wins in a crash) stock as the day it was made
Before these: '00 F-250 CC PSD, '97 F-250 CC PSD, '94 Ford F-150, '91 Ford E-250, '81 Ford E-150, '66 Ford F-100 (cars not included)
I tend to adjust on the fly testing the brakes on street as I'm leaving home as per the cheat sheet, then set the boost according to my estimate of the weight of the load. Roughly B1 under 3500lb, B2 for 3K thru 7500lb, B3 above 7500lb to 10,000lb, these weights include 2500lb for the trailer itself.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: olddieseldude</div><div class="ubbcode-body">Are you asking about actual brake adjustment at each wheel or are you asking about adjusting the brake controller before you haul something?</div></div> His post is somewhat miss leading. Looking at his sig, he has an '08 probably with the integrated controller. I think the Ranger wants to know how others set the gain for different loads.
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum. Winter Operation (How I Do It) Hard/No Start? Check here first
Brake CONTROLLER...not the brakes! Thanks for noticing the slip-up.
here is from what I understand and I usually use this method. On an empty lot with room to make two to three tries I drive at least 25 mph then step on the brakes in a normal stop pattern. if my rig go down at the rear I decrease the trl brake. If it go up I increase trl brake. I do this until both trl and truck kind of stop smoothly with no up or dpwn movement in the rear.
Then I test a "panic" stop with both the foot brake and another try with the brake controler at 25 mph on the empty lot.
Then after going down the road at 60 mph I exit off ramp for more testing to test stopping distance and gain. Then when I am satisfied with that I go on down the road at reasonable speed between 60 and 65 mph. Id like to go faster but I want to be able to slow down or stop in a controlled stop.
I cant tell you if this is the best way of testing the trailer brakes but thus far it has worked for me and Ive not had any problem with stopping.
Ive only had 2 panic stops one when a car cut in front and panic stopped because traffic was stopped, I hit the brakes and managed to stop in time. Another time was my error in inattention to traffic that required evasive action but was able to manuver a controlled stop.
my only aggrivation with the elec brake is that I have ABS system in my rig and often times coming to a stop light or stopping while driving slow I get a hard jerking from the trailer as if the brakes gain is too strong with a light touch of the foot brake. I dont know what the cause it but I may need to upgrade my elec brake contoller.
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
My brake controller adjustment is easy and requires no test stops. I have a Jordan 2020 which has the ammeter current readout. From experience I know where to set it for my various trailers depending on how they are loaded. Piece of cake!
I just hook up my trailer, and then let the truck idle forward. I push the slide bar so that it slows the truck at an appropriate rate, usually within a foot or two, and call it good. The trailer brakes are to stop a trailer not the truck, so you surely do not want it pulling you back, especially since the shoes are much thinner than any vehicles.
New addition:
2006 f-550 service body with a 20 foot stellar crane.
Arrest me red 2006 F-250 6.0 Even more loaded
Black 2000 F-250 4X4 PSD Lariat, loaded.
Green 2001 4x4 Excursion Limited with PSD, loaded
White 2004 F-250XL, it is loaded with just a LS. I can't find the other options.:P
Thats good, fine and dandy, in this case as with diffrent brands of brake controllers adjusting the gain are diffrent with each one but testing the brake is still a must and I emphasize that to ensure that it is working properly whether you have preset modes, readings or not. I encourage testing and inspecting of any equiptment before each and every trip. I like the idea of being able to set the controller at a setting so you dont have to adjust it all the time. Mine stays at a certain setting all the time after initial setting and brake testing but I still test stop it to ensure that it is working properly for each and every trailer. I do wish that all brake controllers have an ammeter read out for ease of adjustment and I think that they should. I think that when I am ready for a new brake controller Ill get one with the ammeter read out.....But I emphasize test stopping for any equipment......
I adjust on the road for most comfort - you likely have a more proportional controller then my older voyager - so I often have to reach down and adjust to controller for the situation.
Highway driving, they are on pretty high, parking lot driving, I have to lighten up the power a biut to prevent jerking.
I would think you can do the same by just driving and adjusting until you feel the trailer pulling you back some.
Basically, with your adjusted properly, you should not notice any extended braking distances with the trailer on - so adjust for that...
99.5 F-250 CC LB 4x4 7.3 Red, Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, BFG AT/KO 285/75x16, Magnaflow 3.5" DP - 4" Exhaust, 2003 Cup Holder, X-Springs, Rear 4" F350 Blocks, ATS Housing, Edge Evolution (Rev. 19), Banks Big Head, DS Boost Relief, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, Sonnax/Tricum
Whatever you do, adjust your trailer brakes. You can do it with a screwdriver, but it is much easier with a brake adjustment spoon.
Vince
1997 California F250 XLT HD Ext Cab LB 4X4
3.55LS & Tow Package
Banks Techni-cooler intercooler
Luk Heavy Duty clutch and single mass flywheel
Tymar 3 to 4 inch down pipe
Tymar Intake
4 position TW chip
4 inch exhaust
Pyrometer guage installed in a-piller
Bilstein shocks
I'll second that. From advice gotten here recently I checked the brakes on two brand new trailers bought from reputable dealers and both were WAY out of adjustment. And I was worried about my controller. Assume nothing;check everything.
'05 F-350 PSD 4x4 CC SB SRW Manual
