Best shocks for towing and slide-in camper on F350 DRW
What are your recommendations for replacement shocks on a 1995 F350 DRW, used for hauling a 2800# (loaded) slide-in camper, &/or towing a 12000# tag trailer? Driving is mostly smooth roads, but may include the occasional narrow/bumpy scenic highway. Worst regular part is the speed bumps on the semi-steep hill on the way to my house.
Thanks and regards,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 288k miles (Ford rebuilt E4OD at 226k)
10 ISSPRO Performax gauges, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Baby Swamps & Tunes, Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
2000 Jetta TDI - Kerma reflash, Der Chimera Stage II Clutch
1998 S&S 9.5' slide-in camper
33' enclosed tag trailer with 2 doorslammer drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
NRA member and certified firearms instructor
GOA member
IDPA member
Re: Best shocks for towing and slide-in camper on F350 DRW
I put Bilsteins on my dually and they handle great. It's not a mushy ride and with the 5er hooked up, it still does well over bumps and joints in the road. A friend just installed KYB shocks on his truck and his opinion is they are as good as the Bilsteins. It definitely helped the ride in his truck (dually). Maybe price between the two would make the choice, all things being equal. Good luck.
Bilstiens are OK, but if you want a stiff ride the camper, but want it a but softer when it is unloaded youy might want to look at Rancho 9000 adjustables. I can set them to what I want.
I installed my Rancho 9000's when I towed a 6 ton 5th wheel. Loved it! Crank them up when towing and turn them down when empty!
I now tote a Lance 1130 and still love them! Excellent to crank to the max for stability. I also highly recommend the Timbren overloads in the back. When empty they never touch the frame. Easy to install in 30 minutes. They use the same mounting holes as the 'bump stops'. And they work seamlessly with the Ranchos!
Chet
I have KYB's and agree with the alignment shop that sold them to me, they're really high quality but they don't have a big add campaign so they're not in the lime light like other brands. I found out later with a web search KYB is one of the biggest commercial hydraulics companies in Japan.
An interesting note, I told the shop owner since my truck rides like a board anyway I didn't want those huge Monroe's. He started laughing and led me over to a display board with KYB's, Monroe's, and Bilstein's all cut in half lengthwise from top to bottom. Like he pointed out, Monroes are all huge hollow shell with the smallest valving and working components of the three. It was evident the other two are twice the shock.
