Old 02-23-2007, 10:36 PM   #1 (permalink)
My Photos: (5)
best trailer tires
I'm no search wizard, so here we go, sorry if its been beat to death. Upon packing the bearings on my 24' car trailer I noticed my tires are starting to crack, they are the good ol marathon 225/75 15's. Sooo what is a good tire to replace these with? I need to stick with somthing in the same size, but would like a little stouter tire than the c load range that was on it. Trailer with all the goods is prolly a good 10k. I never had any issues with these, just heard all the horor stories about them blowing out. They are 5 yrs old, maybe have 3000 miles on them. I'm pretty anal about tire pressure before every trip, and take them off the trailer during the winter months.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
Old 02-24-2007, 09:21 AM   #2 (permalink)
Re: best trailer tires
I'd go with a Denman tire which are available in that size, D or E load range. Cooper is a great tire as well. However, more pricey than the Denman.
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
Gun Control means using both hands.
Stewey is online now
Old 02-24-2007, 04:24 PM   #3 (permalink)
My Photos: (5)
well, got some maxis st225 75 r15's mounted and balanced in town for 430.00 today, they said they see no problems with them so I'll give um a shot. They are a d load range where my old ones where c's, and they will handle 65 psi instead of 50 so maybe they will be better than the gooodyears.
1999.5 cc dually
Old 02-24-2007, 05:42 PM   #4 (permalink)
I'm sold on Denmans. My 5'ver has 15" rims and came with "D" rated tires, which popped like popcorn...seemed like a flat every couple of months.
I switched to "E" rated Denmans and nary a problem....Alaska and back and all over the US. I just put a second set on my 5'ver....first set probably went over 30K....my axles not the best aligned and the tires wore on one edge, so I put new ones on. A little over $420 out the door.
You local dealer will have to order them from a large metro area, though.
Florida Ed
2001 7.3 F-350 Dually Lariat CC LWB 4X2 Dark Green 4.10 4R100 5'ver Hauler (32' Montana 2 slides 10,500# - 2,000# tongue weight), 106 gal aux tank, 112K miles, nephews arguing over who will inherit it 'cause I'm gonna' drive it 'til I die. Bone stock.
2001 5.4 Gasser F-250 XLT Crewcab SWB 4X2 3.73 4R100 67K miles headed to 150K (wife's vehicle on the "junk-iron" theory of vehicle safety....most junk iron wins in a crash) stock as the day it was made
Before these: '00 F-250 CC PSD, '97 F-250 CC PSD, '94 Ford F-150, '91 Ford E-250, '81 Ford E-150, '66 Ford F-100 (cars not included)
FloridaEd is offline
Old 02-24-2007, 06:34 PM   #5 (permalink)
Florida Ed
I wanted the 225/15 Denmans to replace the bad (tread separations) Missions (Nanking Rber Co) but was unable to get them where I am staying so had to settle for Carlisles in Load range E (up from the D rated)...Leaving soon for home so we'll see. Could not find Coopers in that size LR E. I do not trust the tires that are made offshore but have no proof that they are lesser quality. If I could have , they would be Michelin LT tires in 16" but no room...
2004 PSD F350 Lariat 4X4 CC long box Arizona Beige , AIC, FX4 heated seats, adjustable pedals, power rear slider, towing pkg/ receiver, power Towing mirrors, camper pkg,reverse sensor, 3.73 LS, torqueshift, bedrug, born on Dec 3 2003. Towing 2005 Cougar 5th wheel 285 EFS with a bell and two whistles.
ikidd49 is offline
Old 02-24-2007, 07:00 PM   #6 (permalink)
My Photos: (5)
I searched over on the racer forums and seems the Denmans had a bad rap. I guess they all fail at one time or another, I think a big factor is the checking of pressure often and making sure the valve stems are not rotten. I did replace the stems in these when they put the tires on. You just have to know the racer mentality as well, those guys and towing can be a scary situation. Heck you should see what they pull their bigger than mine trailer with, 1/2 ton wore out suburbans and such. I really would like to step up to a 16" deal, but no room and I will prolly get a bigger trailer in a few years anyway.
1999.5 cc dually
Old 02-25-2007, 06:41 PM   #7 (permalink)
We have been using Deman's on Boy Scout trailer running near max load with no problem. A friend just bought his second set of Maxxis for his travel trailer. I have had problems with Goodyear Marathons and Carlise tires. Currents running Michelin XPS ribs on my travel trailer.
2000 Excursion Limited 2x4, 3.73 LS,PSD/Auto,ATS turbo shroud,Badging,BullyDog 4" exhaust,AIS,HX crossover,ISSPRO gauges/A-Pillar,SuperChip 1705, Pre-Pump & In-Tank Mod,Banks TransCommand, ZooDad, Baldwin Oil ByPass,Ford AIC, F350 rear springs, Helwig Rear Sway Bar,Michelin's LTX MS
2003 Sunnybrook/Mobile Scout & Hensley Arrow
sail684 is offline
Old 02-25-2007, 11:04 PM   #8 (permalink)
busbreath's Avatar
I am also switching to Denmans. My brand new Carlisle spare exploded - split across the tread - while parked in my storage yard. It had been mounted less than a month, and had only 30 miles tops! Still has the rubber tits on it. It replaced a carlisle tire - less than 2 years that shredded and trashed the side of my 5er. Get the load range E (10 ply), and don't look back. Many posts on RV.Net back this up with similar experiences.
Enjoy!
Doug
97 F-250 extra cab 2WD. K&N FIPK, 410 gears, Pace Edwards roll-top bed cover, Reese 16K 5th wheel hitch, defender trans cooler, 81K orig! New to me 10/2003. Pyrometer and trans temp pillar, boost gauge, SCMT, exhaust brake & t/c lockup, Hypermax downpipe/tymar out 4", ATS Intercooler (Thanks CaryT)
Mother is the Necessity of Invention!
busbreath is offline
Old 03-02-2007, 01:21 AM   #9 (permalink)
Supporting Member
detroitfd's Avatar
Florida Ed
Carliles SUCK [img]/ubbthreads/images/graemlins/wink.gif[/img] I know cuz I've used em a few times...best of luck!
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ serviceable S&B filter - Zoodad mod - B&M HD Trans rebuild w/ TransGo Shift kit & Amsoil Fluid- BD Triple Disc Billet Torque Converter - Exhaust : 4" Turbo Back (w/ 4" down pipe) Stainless Steel Magnaflow - ATS housing and 4" intake sleeve - Turbo Master Wastegate Controller - Dieselsite HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
Old 03-02-2007, 02:40 PM   #10 (permalink)
wkw
What about the 225-75R15 Titans in the Load Range E?
http://www.titanstore.com/info/4RT348
'00 350 4X4 6sp
wkw is offline
Old 03-04-2007, 03:17 AM   #11 (permalink)
I saw some of those on ebay, i wondered if they were good too? Goodyear makes good tires so i would think they would be good..
1995 F-350 Powerstroke 7.3 300000 miles
neepsjeeps is offline
