Old 08-20-2006, 07:41 PM   #1 (permalink)
Best way to secure a car to a car trailer?
I was just curious as to what works best for you guys when you secure a car in a enclosed car trailer. My trailer has the e-tracking system in it. I have just always used two big 12K tie downs, one on the front and one on the back. I usually just run them up and over the suspension on the car, and try to "pull the car apart" with the tie downs. Is this a good way, or is there a better way to do this? Just curious as I was reading about a accident somewhere else. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
08 F350, Lariat, snow plow prep, 6.4, torqshift, ESOF, Dark Shadow Grey with black accent, CC, SRW, Tow Command, upfitter switches
2000 Trans Am WS.6 Pewter M6 W/Pro 5.0, TSP lid, cutouts, Pacesetter headers, SLP subframe connectors, Taylor 10.4mm wires, CAGS delete, suspension upgrades, a few little things here and there....
1968 Mustang Fastback, 302, factory AC, automatic, original 42,000 mile car
nickPSD is offline
Old 08-20-2006, 08:10 PM   #2 (permalink)
olddieseldude's Avatar
My Photos: (15)
Re: Best way to secure a car to a car trailer?
I use 4 tie downs on my open trailer. Two chains crossed at the rear, two ratchet straps crossed at the front. I set the chain lengths first for tongue weight then pull everything tight with the ratchet straps from the front.
If I had Echannel I'd do the same thing unless I used basket straps on each tire, then I'd tie down front and rear of each tire.
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 08-21-2006, 11:12 AM   #3 (permalink)
KF6ZVT's Avatar
Like oldieseldude said, I use "basket" straps on all 4 wheels. Tighten them down like you want to crush the tires. It never moves, a fraction of an inch.
Tying down via the chassis, still leaves some give in the suspension. Going over bumps gets movement transmitted to the hauled vehicle's suspension and puts a lot of strain on your tie down points on the trailer and the vehicle.
2001 F250 SC 4X4 Blue PSD Auto, Cody Gooseneck Hitch, Rancho Shocks and Steering Stabilzer, Tekonsha Prodigy Controller, Garmin Streetpilot 2610 GPS, Walker BTM, 285/75R/16E, Western Diesel Trans-Pyro-Boost, Pillar Mount, Painless fuse panel, In-tank and Pre-pump mods, Slotted Rear Rotors, Slotted and Cross Drilled Front Rotors, Fumoto Valve, Zoodad Mod, Transfer Flow 46 gal tank, Mag-Hytec Differential Cover, Electric Tailgate Lock, IAH Deleted, Coolant Filter, DP-Tuner 80 hp PCM, CCV Mod, 203 Thermostat, Ford AIS Air Filter
KF6ZVT is offline
Old 08-21-2006, 11:19 AM   #4 (permalink)
I use four 10K straps. Two crossed in the front from the frame to the tiedowns, Two crossed at the back, again frame to tie downs.
This method will ensure that the car can neither roll fore and aft, but also will keep it from moving side to side (in case of some radical maneuver).
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 08-21-2006, 12:32 PM   #5 (permalink)
I have a business transporting cars and I use a single car trailer. I use wheel straps and tighten them down just like KF6ZVT said. That way you do not damage the frams at all with trying to hook to it. Another way is to put the straps around the actual wheel, but if you have chrome wheels don't do it that way.
It is always a good idea to check your load along the way just incase something does come loose IMO.
awayne is offline
Old 08-21-2006, 11:30 PM   #6 (permalink)
No matter what I haul I always check straps before going onto interstate/20 miles. (whichever comes first)
I seldom haul cars but for other stuff I run front chain and back up till chain is (singing) lock brakes then strap rear.
larry_minn is offline
