Old 12-31-2006, 07:10 PM   #1 (permalink)
A big load of hay
Any one still hauling hay this time of year. Here is a picture of one of the loads that I hauled to texas this year. <font color="red"> </font> DONT LOOK IF YOU ARE A FLAME THROWER. http://photos.thedieselstop.com/show...hp?photo=30348 [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
MY 4 DOOR HARDTOP SPORT TRUCK: 2002 F250, AEB2, 4x4 ESOF, 6spd w/SB Con O clutch, c/c, DP Tuner 60 80 & 120 tunes,Bellowed up pipes, Banks Monster exhaust, Banks exhaust brake, Airaid cold air intake, 3 gauge piller mount with DiProcol gauges, full front ranch hand bumper, Gooseneck hitch. Towing anything that I need to.
Waiting for the time to install:
Cab Lights, F350 4" blocks, Front leveling kit, inline fuel filter.
lebeouflimousin is offline
Old 12-31-2006, 07:20 PM   #2 (permalink)
RatherBNtheWoods's Avatar
Re: A big load of hay
Oh man that was so dangerous and had to be illegal. I would never do something like that................................Again!
Nah, just kidding, but I fear itsa commin. Brace yourself.
That is going to make an awful lot of cow poop though. And tasty steaks!
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 100gal aux fuel tank. A real pig from a stop, but give me 10' and she'll lite'em up.
RatherBNtheWoods is online now
Old 12-31-2006, 08:19 PM   #3 (permalink)
So how did it handle the load?
64
2005 F250 V10 AT, 4WD CC.
2005 F150 4.6L
2002 GT Stang
2006 500
64frdpwr is offline
Old 12-31-2006, 08:30 PM   #4 (permalink)
Wow, what was the gross weight?
2006 F-350 extended cab 4X4 SRW 6 speed 3.73
enginebill is offline
Old 12-31-2006, 11:57 PM   #5 (permalink)
I was able to maintain 65mph and did not try to go over 70mph. The total weight was somewhere between 40k and 45k. I had no proplem with handling the load nor did I have a problem stoping. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 01-01-2007, 12:25 PM   #6 (permalink)
Roy_Boy's Avatar
Just curious, how do you figure the weight?
I was thinking, 15K for the truck and trailer.
Those look like 4 x 5 bales, so maybe 800 lbs x 26= 20,800
total= 35,800lbs
But, how did you figure? [img]/ubbthreads/images/graemlins/smile.gif[/img]
Roy
2004 F350 super cab short box dually
One of a kind
6.0L, 6speed, 4x4, 3.73 axles
US gear exhaust brake
Custom SCT,tuned by Tadd
Engine#3- 6398 miles (still running great)
Haulin' More than most of y'all
02 VW Beetle TDI 5 speed
Roy_Boy is offline
Old 01-01-2007, 02:40 PM   #7 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I thought those bales looked closer to 1K. There are 26 bales there right? That is close to 26K just in load! Nice.
Most we ever did with our y2k was 33K. GA to CT. Had some things to fix after that.
MarkEkberg is online now
Old 01-01-2007, 08:22 PM   #8 (permalink)
These rolls weigh between 1000# and 1200#. I figured this load at 1000 pounds each at a min.
25 bales x 1000 each = 25k
Truck = 8k
Trailer = 8k
Total = 41k
Old 01-01-2007, 09:19 PM   #9 (permalink)
wow!
2000 F350 2wd DRW 6sp PSD Xcab long bed, AFE Intake, 5" exhaust straight back, no muffler, Edge Juice with Attitude, ATS Ported Turbo Housing
170typhoon is offline
Old 01-02-2007, 08:09 AM   #10 (permalink)
Albin's Avatar
My Photos: (24)
The only flame I have is that I don't see anything tieing the first upper bale down.
'06 F-350 SRW 6.0 PSD
Albin is offline
Old 01-02-2007, 09:42 AM   #11 (permalink)
My Photos: (13)
Look close, it doesn't have a strap but there's a rope just like on the third bale.
Ag__Teacher is offline
Old 01-02-2007, 09:48 AM   #12 (permalink)
MOre importantly, what type of hay was it? Where did you haul it to? and what price did you get?
2004 F350 Crew XLT 4x4 long box, SRW, 3.73 Gears
Bone Stock
newtodieseling is offline
Old 01-02-2007, 09:54 AM   #13 (permalink)
first off,i would like to say thanks for the hay.some texan is lucky to be getting it.texas got hit with the drought real hard this year,and being the second year in a row,it only made matters worse.i only yielded about 1/3 the normal this year,went down to natchitoches,La to buy the bulk of the remaining hay i needed.if not for all the hay coming from our louisianna/ark neighbors,i shudder to think how bad things could have gotten.i can remember at least one ocassion where ranchers to the south of me actually shot off livestock,due to a major drought.i have hauled many a load like that,and even heavier behind a 3/4,crossed my fingers every time i did it too! always swore when times got better,i was gonna get more truck to do the job,they did and i did. on a side note,still seeing lots of hay coming from the south and the north..
the fleet; ferds ,02'f350,[97'f350,90'f250 now gone].the generals ,82'2500, 82'2500 4x4, 82' blazer, 86' blazer ,93'3500, 96'3500, and a 99'3500hd soon to be 12v powered. the goats, 90'd250, 91'd350 4x4,[95 model 3500 now gone],00 model 3500 now wrecked, 05'3500. all are diesel powered. a list of bigger stuff, as well as gasser's, got lucky, wife comes from a family that collects junk iron too!
navistar45 is offline
Old 01-02-2007, 10:40 AM   #14 (permalink)
My Photos: (14)
i just scored about 100 bales of 4x5-1/2 net wrapped jiggs for 30.00 roll.
this is the same hay that is bringing 105.00 per roll in Pearsall, tx.
i only haul 17 rolls at a time on my 32' trailer, and truth is, thats all i really want to mess with.
chris
current trucks -
2003 dodge dually 4 door 4x4 6spd HO cummins straight pipe - baldwin pa2820 HUGE filter
2003 f550 11 flatbed, 6.0, 6spd, 19,000gvw, vac/had brakes
2004 f550 11 flatbed, 6.0, 6spd, 19,000gvw, vac/hyd brakes
previous truck - 1995 F-350 cc srw 4x4 5spd
CCOUGHRAN is offline
Old 01-02-2007, 01:03 PM   #15 (permalink)
chris
Is that alfalfa or grass hay? i guess we (I) kinda hijacked this thread. [img]/ubbthreads/images/graemlins/blush.gif[/img]
Bone Stock
