Old 05-18-2006, 11:22 PM   #1 (permalink)
Blowing fuse #4 - "Trailer Tow Park Lamps"
I have a 1999 F350 and I pull a 2004 Open Road Travel Trailer. On my trip this weekend, which was 3 hours one way, I blew this 20 amp fuse 3 times. I have not figured out a pattern as to when it blows. I was wandering if there was a known issue out there with this circuit. My trailer has 13 marker and clearance light and one license plate light. The bulbs in the marker/clearance lights are #194 and I think they draw about .3 amps each. So I shouldn't be having an issue. Again, are there any known issues with this circuit?
TIA,
Greg
Early '99, 4x4, Crew Cab, LWB, SRW, FPR mod with gauge, A/C Heater Bypass mod, Ford AIS Intake, DP Tuner F5 Chip, FTVB, Hughes Transmission Pan, Additional V-10 Tranny Cooler, 3 Gage Pod, Amsoil Lubricants throughout, Rebuilt Ford torque converter at 120k to get rid of the noise, Brake Master Brake Controller
gmelton2 is offline
Old 05-19-2006, 02:38 PM   #2 (permalink)
Re: Blowing fuse #4 - "Trailer Tow Park Lamps"
Sounds like you have an intermittent short in your wiring. It would take a heck of a lot of lights to blow a 20 amp fuse. You probably have a wire rubbing on something and has worn through the insulsation.
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
Down South is offline
Old 05-19-2006, 11:45 PM   #3 (permalink)
Ditto what Down South said.
Is this a new trailer for you or have you recently done some interior work? If so, check to see if maybe someone didn't put a screw, staple, or nail through a wire. I pull camper commerically and this is a common manufacturing problem. I have a auto-resetting ciccuit breaker switch installed on both running light and 12V power circuits on my truck. Fuses are expensive.
Hope this helps and good luck.
'03 Arizona Beige F-350 DRW CC 6.0L, TQShift, 4.10 ls rear, 01/21/03 eng, 01/23/03 build.
Mileage as of 08/10/07: 386,350
alfalfa44 is offline
Old 05-19-2006, 11:53 PM   #4 (permalink)
Hey Alfalfa, good call on the circuit breaker.
2006 F-250 4X4 Lariat, C.C. / SWB -- Torreador red
PerryB is offline
Old 05-21-2006, 09:39 PM   #5 (permalink)
The trailer is about 2 years old and there hasn't been any recent construction. It doesn't blow the fuse every time it is connected to the truck, but the frequency has been increasing.
Did you replace the fuse with a circuit breaker or run a new circuit for the trailer lights with a circuit breaker?
Thanks,
Greg
gmelton2 is offline
Old 05-23-2006, 10:30 PM   #6 (permalink)
ponyboychris's Avatar
My 4-wheeler trailer had a wire rub through and blew my park lamp fuse a few times recently. Didn't do it all the time. Drove me nuts. There was a sharp bend in the wire harness at the back that was factory. Took me a while to find it but it was near the rear taillights. I guess they never thought that trailers bump around a lot and wires could rub on sharp metal. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2002 F350 XLT, 7.3L, 4x4, LB, SRW, Crew Cab, 3.73's, BTS Trans "BTS BUBBA" , 6.0 tranny cooler, DP Tuner NS, stock, 60HP tow, 80HP econo, Autometer Ultralites on pillar & cubby, Ford AIS w/Zoodad, '08 Aluminum Diff. Cover, 4" MBRP Exhaust, Heated Tow Mirrors, Warn Premium hubs, AIH Delete, Go's Headlight Harness, IC Foil Delete. The Silver Bullitt
My Truck Pics
2000 24' Tahoe 5'er W/4 wheelers in tow
2003 Explorer XLT - Mom's Taxi
1990 Honda - the 27 MPG daily beater
1967 Mustang FB on blocks - my other toy
ponyboychris is offline
