I have a 31' TT and I have yet to experience a blowout while driving. I take good care of the tires and have changed out tires that have had nails and other road junk in them before the trip. So, I wonder how a truck and trailer act during a blow out? I don't expect one, just want to have an idea of how to safely handle the situation should it arise.
2003 F-250 6.0, slushbox, no muffler
2003 Focus ZTS ebony quad eyed carbon fiber fetishist(if that wasn't a word before,it is now) street legal like the pope is a card carrying satanist.
I had a blowout with my old 27' TT ...didn't feel or hear a thing...a few passing cars got my attention and I looked in the rear view to see sparks flying everywhere...I thought the door/ramp broke, opened up and was dragging on the road...I found a place to pull over and realized it was a blown tire...
Luckily it didn't cause too much damage to the trailer...the tire and rim were toasted!...the biggest thing to check would be your electric brake connections...I had a wire ripped loose by the tire flapping around inside the wheel well...luckily I carry around extra self sealing wire nuts...
Also...I wouldn't trust the tires that come on the trailers from the factory...I've had several friends blow fairly new low mileage"stock" tires...including myself...even if they look ok...I'd replace them with the best quality trailer type tire I could get...
05 F350 Lariat,Tow Boss,Fx4,CC,DRW,8'Bed,White with Tan int.
Stock...
I appreciate the feedback. I hope to never experience it, but good to know.
On a multiple-axle trailer, chance are you will never even feel it. It may sway a little when it happens at first, but not too badly. Unless you hear or see the tire blow, you may not even know it happened until you get there and your rim is toast...
'99.5 PSD 6 SPD 4x4 Extended Cab long Box F-350
AFe Stage 1 intake, Marinco Block Htr Plug Mod., Hutch in-Tank Pickup Mod, $10 AIC, Walker BTM, Edge Juice with Attitude, and that is all, FOR NOW!!! Next mod = Regulated Return???
Old Truck - '95 PSD 5 spd 4x4
Haulin' a 11.5' camper, an '85 Bayliner Capri 20' boat w/ Chevy 350, and a flatbed w/ two big quads.
2004 Grizzly 660 Yamaha (For Me)
2004 Polaris 500 HO (For the Wife)
Spokane, WA
"I don't ride bulls, but I have fought some men" Hank Williams, Jr.
"Sie vie pacem, para bellum" (if you want peace, first prepare for war...)
5 times for me and someone always honks and points or you would never know on a dual or triple axle trailer.
2001 7.3L F450 4x4 CC Automatic Fontaine Conversion 4:30 Limited slip Reyco Granning Full Air Ride Supension, Transfer Flow Fuel System, 4" MBRP turbo back, gages, pryo pre turbo.
Build Date 03-12-01 in KY. Towing a 34 foot Thor Tahoe toy hauler 5er.
2004 F250 CC SB XLT 6.0 Automatic Gauges Big Walker Truck Muffler towing a 23 foot American Freedom with a buggy inside
Thanks for the replies. I feel better. I always try to prepare for the worst and hope for the best. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Depends more on the road surface that your on at the time of blowout. One time I put the third axle of a 4 axle trailer off the road edge and blew a tire on the third axle passenger side tire. I had no problems feeling that blowout.
On my TT, I blew out the drivers side rear tire on back axle in a construction zone. I didn't feel that tire until I got back up to road speed on a smooth surface and then only because I seen smoke from the tire before I felt the trailer.
If you playing close attention to the way your trailer is pulling, then you can feel it pretty good.
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run Define Union: A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
I had a blowout on my truck while towing the trailer. Right inner. I heard it, but with the dually's I never felt it. I simply pulled over and changed the tire. (after I unhitched the trailer.)
Best indicator of a blow out on trailer is passing car honking and pointing. Other one is if you happen to look in mirror and see tire going everywhere. The hard part is changing it when it is 118 out. Been there done that. Then of course there is the damage in the wheel well.
LeRoy
Y2K F-350 Lariat SRW SC LB PSD 4X4 Man Hubs, Auto, Leather, Harvest Gold. 50 gal in the bed xfer-flow fuel tank. Banks exhaust and stinger kit. AIS cold air intake
My last trip from Western New York to Indiana with my gooseneck trailer I lost 2 tires. One on the way down and one on the way back. It was the last 2 of 4 general tires I had. I lost all of them in a 1 year period.
If you have more than 1 axle you may not immediately notice the problem. If you have a sudden blow out you may hear it, or as 2 of my generals did they blew off the tread and flapped around long enough to to damage my fenders. That was very easy to notice!!! I tow heavy and My biggest concern is losing one tire then another from running on only 1. If I lost 2 I would not have enough spares. I am thinking of taking 2 spares with me but have not done so yet.
I just got new rims and Goodyear "G" rated 110psi tires. Needed new rims to be rated at 110 psi. Ran to PA & back and they seem fine. 3 stops to check the lug nuts in a 4 hour trip, and they do need to be checked with all new rims and lug nuts. I was amazed that they needed to be tightened so much.
The new tires even though they are listed as 235/85 16 the metric number is a little different from a standard 235/85 16. The tires are lower profile and a little wider.
WFTREE
PS These tires are not cheap!!!
__________________ NEVER FORGET, NEVER RELENT, NEVER DISPARAGE 09-11-01
1999.5 F450 CC 4x4: 315 RWHP 710 TQ 6 speed with BD short shifter; 60"CA; South Bend clutch; Ported BB turbo; Spearco 6.0 charge air cooler; pop off valve; dieselsite I/C boots; 203 degree thermostat; pillar mounted pyro, boost coolant temp guages; engine mounted fuel pressure; HX hose; shimmed regulator; Tymar intake; zoodad; Banks brake; 4" DP to 4" exhaust to Aeroturbine muffler to 4" chrome stack; diesel power flip chip, 85 gallon aux fuel; Dahl 100 heated fuel filter; in tank mod, Hella FF driving & fog lights,
I just blew the second of four factory tires and did replace them with trailer rated 14 plys.
I have a friend with a shop and he order the tires and I did the work at his place. Just the weight diff of the tires was enough to tell me that anything over about 10k gross needs trailer rated.
A lot of manufacturers are sending out trailers with light truck or worse and unless you are very particular about load distribution and carry light loads I would not trust them.
Next new trailer I buy I will probably trade the tires back before it leaves the lot.
Also get high press. stems when you change out tires. My new tires are 100 psi and that is what I have been advises to run them at.
Hud
95 F-350 cc xlt 4x4 srw
tymar air filter
4" exhaust with dp
gutted ebpv
kitty gone
3 position chip from Tymar, stock, tow, race.
300,000 miles in 10-08
99 F-550 xl 2x4 drw
12' Johnie Gregory Dump
six speed
stock with 230k
