Old 07-06-2009, 05:10 PM   #1 (permalink)
Bolt for trailer light housing ?
My F350 seems to be missing one of the 2 bolts that hold the 7-way/4-way trailer light plugs in place. So when I plug my light cord in, it tends to slide. Anyone know what size bolt this is ? Or a part number ? I would take the 1 bolt off, but then my light plug would be dragging behind me to the dealer
Montano is offline
Old 07-06-2009, 05:25 PM   #2 (permalink)
what year is your truck? All of mine 99-05 only have one bolt, but also have a locator tab that fits in another hole. Every now and then the 14mm bolt will losen up and the whole bracket/plug is loose and moves around. 3 minute fix, just crawl under and tighten.
2003 BLACK Excursion Limited 7.3 4x4 w/DVD entertainment center, rear captians chairs, 3.73 limited slip. 4" MBRB Stainless Exhaust, AFE stage II intake, DP F5 Tuner, 4.5" Donahue lift, Rolling on 18" Jesse James Lawless 8's wrapped by 35" Toyo Open Country Mud Terains and airbags, Prodigy brake controller.
2002 BLUE F350 XLT 7.3 4x4 Crew Cab short box, BTS Tranny, 6.0 tranny cooler, 4" Silverline Stainless exhaust, S&B intake, DP F6 Tuner with 9 tunes. Line X, B&W turnover ball, Prodigy brake controller.
1968 Chevy C-10 Short Bed PRO-STREET 500+CI BBC
1991 Honda CRX-SI (Black Also)
2002 John Deere Gator Diesel 6X6
2003 Limited edition Cannondale Cannibal- With colors that woulnt run, RED, WHITE and BLUE #0000016
Owner and Dad of Godspeed MX racing. #269
1BADF350 is offline
Old 07-07-2009, 07:50 AM   #3 (permalink)
Then I'm missing the locator tab. The bolt is as tight as I can get it. My truck is a 2004. Any place online to buy the locator tab ?
1999 F350 XLT CrewCab Dually | 7.3L Powerstroke
4 Speed Automatic | 3.73 Limited Slip
Montano is offline
Old 07-08-2009, 11:18 AM   #4 (permalink)
The tab is made onto the bracket, all they did was punch out a u-shape on the steel plate and it folded over 90degrees to mountinto the hole.
If it's gone, just tap the frame hole that it mounts to and put in a another screw? Just a thought.
1BADF350 is offline
