It should be under the cover below the steering wheel, pull that down and look up and to the right, kind of behind the factory radio location. The plug on my brothers Ex. was attached to the bracing under the dash in that location. Hope that helps.
2001 Ford F-350 drw 4x2 auto,4.10 gears,Turbonetics ball bearing turbo, ceramic coated up-pipes and exaust manifolds, DIY Tymar, 4 inch exaust turbo to tip, Isspro guages EGT,Boost, Trans temp from DieselManor, 6.0 trans cooler, AIH delete with boost attachment, ITP Regulated Fuel Return kit,hutch and harpoon mod done, ITP in tank and prepump mod kit, Rotella ELC, 203 Stat.
DP Tuner-no start, stock,40,60,80E,120
BTS Transmission,(BTS-BUBBA)
Toys: 03 Screaming Eagle Duece Harley
37ft Cyclone by Heartland 5th wheel toy hauler
