Old 08-09-2005, 08:13 PM   #1 (permalink)
xtremefreerider's Avatar
Brake Controller?
I'm looking to purchase a GN and brake controller for my IDI. I think that I have decided to go with the B&W but was wondering what controller I should go with. The weight of the loads I pull varies along with terrain.
I am looking for something reliable, easy to use, easy to adjust, and nothing special other than I will be purchasing on a college students bugget so if its too pricey I will have to cut my daily meal of beans and water down to every other day or go to bread and water.
thanks for any input.
-Brian
1990 F-350 REG CAB LONG BED, 7.3 IDI, '95 ZF-5, LUK CLUTCH W/ SINGLE MASS FLYWHEEL, 87 BW 1356 T-case, FOUR GAUGE PILLAR MOUNT W/ AUTOMETER BOOST, PYRO, OIL PRESSURE AND WATER TEMP, BANKS SIDEWINDER WASTEGATED TURBO, EAGLE 16.5" WHEELS, 4 INCH SUPERLIFT, 35/12.5/16.5 BFG Muds, Eaton Rear End (7/05), Blown Motor (9/05), New motor, trans and t-case (9/06), Custom 5" straight pipe (8/07) - Pics coming soon....odometer rolled for the second time...although I don't have the correct spedo gear and the spedo/odo didn't work for 15-20k miles
MY PHOTOS
The Goat - 2008 Dodge 2500 CC LB 4x4, 6.7L Cummins w/ 6sp manual. So far bone stock except a leveling kit
xtremefreerider is offline
Old 08-09-2005, 08:27 PM   #2 (permalink)
My Photos: (5)
Re: Brake Controller?
SmokinIDI, I use a Teckonsha Prodigy, works great, not too complicated of an installation. It will run you just little more than a Benjiman (do a froogle search, that' how I found agood deal on one). BTW I also use the B&W turnoverball, it works excellent, a worthy upgrade for any hauler.
6.9L (from an 87 F250)powered 83 FJ60 LandCuiser
A few other 4x4's and a bunch of other toys/junk
sixniner is offline
Old 08-09-2005, 10:22 PM   #3 (permalink)
The Prodigy is an excellent controller. You should be able to find them for just over $100. There are cheaper controllers, just don't buy one that is time based (like I did) and shoot for digital if you plan to pull more than one trailer.
pressgrove is offline
Old 08-10-2005, 05:23 PM   #4 (permalink)
If you are planning on towing loads of a varying weight, the Prodigy is definitely the way to go. It's so nice to get the controller "dialed in" for a lighter trailer and then utilize the boost feature when towing heavy. Plus it's nice being able to see the actual voltage being applied to the trailer. We go nuts putting tons of gauges on every measureable temp/pressure on our trucks. It's nice to see how hard the trailer brakes are coming on too [img]/ubbthreads/images/graemlins/wink.gif[/img]
Early 99 F-350 PSD XL, 4x4,6spd, SPA Digital Gauges, A Pillar install, Swamp's F*ME Injectors, Hypermax H2E Turbo, 4" Exhaust, Chrome Single Stack, Upgraded PCM (DAC 3) <font color="red">
6pos Chip w/ Swamp's Custom Programming </font>
High Flow Fuel system, Regulated Return Fuel System and Upgraded Fuel Feed Lines, Custom AfE PG7 Intake, South Bend FE Clutch, Turbo Temp Minder, ESP Performance Pre Luber, PSC Delphi Steering Pump, Fabtech 3.5" Hanger Kit, Pro Comp ES9000 Shocks, Dynatrac Superduty Hub Conversion, Warn Premium Locking Hubs, Daystar Polyurethane Bushings, 315/75 BFG All Terrains, CCV Mod, AMSOIL Synthetic w/Remote Bypass Filter, Harpooned Tank, Aux Batt on Isolator, Espar Hydronic 5 Coolant Heater (Money Well Spent!!), Stainless Braided Brake Lines, LineX Bed Liner, Tekonsha Prodigy Brake Controller, B&W Turnover Gooseneck Ball, B&W Tow&Stow Hitch
eng211ine is offline
