Old 05-10-2006, 02:00 PM   #1 (permalink)
Brake controller and brake wiring questions
1) How do I wire the brakes on my trailer? Previous owner put mobile home axles on the trailer. Brakes were bad and the local trailer shop wanted to much money to repair them. They were afraid of them locking up on me so they cut the wires. Last was last summer and I just got in some new 6K axles with new electric brakes. Can anyone explain how to wire them up?
2) Setting up the brake controller. Previous owner of the truck had a TAP Brake Master controller installed. I know nothing about it and very little about controllers in general. The only adjustments I see are a slide for time on the side, slide for power on the top, and a spring loaded slide in the front. What do I need to do to set it up properly for the load I'm carrying?
1999.5 F250 PSD, 4x4, Auto, BTM
98 XJ Sport: 8" lift, 36 TSL's, D44/9", 5.13's, Detroit/Spool, Custom LA's, homemade winch bumper, XD9000i, CO2
Gotta keep that diesel truckin', just put that hammer down and give it hell - Cledus "Snowman" Snow
xj4life is offline
Old 05-10-2006, 06:57 PM   #2 (permalink)
Re: Brake controller and brake wiring questions
Brakes coils/solenoids should be wired in parallel - meaning if you can visualize two vertical wires all the brakes/soleniods just connect across to each wire. For simplicity, you should only have 2 wires going to the left side (brake controller output and ground) and 2 wires going to the right side (brake controller output and ground) and should be exactly the same. The output from the controller should connect to these sets thru the 7 pin connector.
See if these help:
http://members.cox.net/bruce.wittmei...rsSummary.html
http://www.marksrv.com/wiring.htm
http://www.etrailer.com/faq/wiring.asp
http://users3.ev1.net/~crossstitch/RVWiring/wiring.html
Not knowing for sure what controller you have, it sounds similar to the Activator II. 1 adjustment is the max output amount, the other (side) is the time it takes to reach that preset output amount.
There is no magic or crystal ball that determines a setting...every one must be set based on the Tow Vehicle, trailer and road conditions. Just trial and error.
Bruce & Carolyn Wittmeier
bruce.wittmeier@cox.net
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, Chrome Step, Line-X bedliner, Reese 16K slider, Jordan Ultima 2020, AirLift Airbags, Sunnybrook
Are you over weight?
wittmeba is offline
Old 05-11-2006, 06:45 AM   #3 (permalink)
thanks
xj4life is offline
Old 05-12-2006, 10:42 AM   #4 (permalink)
i checked the trailer last night and the previous wiring was one line on the left side coming off the bundle. that line splits off into to lines, one to the right side (split again for front and rear axle), and another one to the left side brakes (split again for front and rear axle). then each individual brake is grounded to the trailer frame.
does this sound right?
xj4life is offline
Old 05-13-2006, 12:39 PM   #5 (permalink)
That sounds correct. What that means is when you put power to the 1 wire at the connector, you should have 12 VDC at each brake - the cut wires hot side - all at the same time. Thats what you want.
If there is a second wire or neutral it should be hooked to ground.
Are the new axles installed on the trailer? If so, and the wires were cut at the brakes or that area, you should be able to connect the new brake/axle wire to the cut wires.
Post back if there are more questions.
wittmeba is offline
Old 05-13-2006, 07:45 PM   #6 (permalink)
I don't know if this is the right way to set your controler or not but it's how I do it: before I start out driving, I'll stop a few times (like in the drive in front of the house or the parking lot) and see which setting on the controler feels like it's stopping the trailer the best.
2k F250 XLT CC 6sp PSD, 3.73 LS axle, Superchip, W-D Turbo Brake, Memphis speakers & 5ch amp, WD-Pyro & Boost gauges, Rechargable MagLite, quick disconnect jumper cables, CAT batteries, ARE tonneau,
"unaable" on the tailgate!! New door actuators!!
T-304 Stainless exhaust turbo back, Southbend clutch
Tina is offline
Old 05-14-2006, 10:28 AM   #7 (permalink)
Most definitely. The road is the true test. Prodigy suggests just this - go to a parking lot where the brakes can be tested, locked and calibrate with 'your' setup.
I do this same with the Jordan...work the brakes a few times while exiting storage. Then with the truck stopped and brakes firmly depressed - dial in the number (usually about 9.5 - 9.7) with the ability to reach 12 with more pedal pressure.
wittmeba is offline
