Old 06-02-2005, 03:04 AM   #1 (permalink)
Brake controller not working????
Does anybody have a clue as to why my brake controller no longer works.
I unpluged it last year (working fine) and plugged it in this year and it's not working.
All my trailer lights work, turn sigs, brake, running lights everything works but the controller. The light is out (on the controller) and it doesn't brake my trailer. I see no inline fuses on the controller, since the fuses are intergrated in the main fuse box under the hood (replaced them)
I replaced all the fuses, checked the ground (still attached), checked the wiring,(looks fine), and still the controller is dead.
Am I missing something? or is the controller just bad (dead)? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Y2K Ford F350 7.3 PSD C/C LB 4x4 Auto truck with 138,586 miles, Gulf Coast oil by-pass filter Mdl 0-1, Mag-Hytec Differential cover, Mag-Hytec Transmission pan, Tricumulator springs and Sonnax valve. DELO 400 5W-40 synthetic Motor Oil.
ArmedSoldier is offline
Old 06-02-2005, 03:25 AM   #2 (permalink)
My Photos: (10)
Re: Brake controller not working????
You also have a fuse in the fuse box under the dash
j_apetersen is offline
Old 06-02-2005, 03:36 AM   #3 (permalink)
Any Idea which one,, I don't see it in the manual and I've looked at everyone (by pulling them) and I see no burned fuses,,,gee's I'm at a loss here.
Old 06-02-2005, 03:41 AM   #4 (permalink)
My Photos: (10)
let me go get my manuel.
Old 06-02-2005, 03:51 AM   #5 (permalink)
My Photos: (10)
Im sorry 28 in the out side fuse box 30 amp. Are you getting power to but not working .
Old 06-02-2005, 10:56 AM   #6 (permalink)
What brand and model brake controller is it? It sounds like a bad connection somewhere. I'd check all the splices under the truck if you made any for the brake controller there. Many times if the wires aren't soldered together there then it's easy to have a bad connection.
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
Down South is offline
Old 06-08-2005, 01:44 PM   #7 (permalink)
Powerstroke2000's Avatar
My Photos: (17)
Would like to know if you found the problem on this one...as mine isn't working either! Seemed fine all year (at least the light would come on) as I don't unplug mine..and leave it plugged into the truck all year.
Go to use it...and no trailer brakes! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Let us know what you find out!
Dale
IDM mod
TYMAR intake
Amsoil dual by-pass
Precision Ind triple disk Torque Convertor & Pro build tranny
Transgo Tugger shift kit
Ford AIC & full gauges
Mini-Me/SWAMP 250cc Hybrid 530 injectors
17° HPOP
5" custom exhaust
Superduty Intercooler & GTS pipe kit
CCV mod
TS 4 position Flip Chip
<span style="color: blue"> My truck </span> & <span style="color: blue"> Dual Idler Tensioner mod </span> , <span style="color: blue"> Superduty HPOP & Mini-Me ~ Swamp Injectors </span>
Powerstroke2000 is offline
Old 06-09-2005, 12:19 AM   #8 (permalink)
Dale:
Now is the time for that BrakeSmart, eh?!! (A good excuse ALWAYS comes in handy with the Mrs.!! [img]/ubbthreads/images/graemlins/tongue.gif[/img] )
Lura
'96 F250 PSD 7.3 XLT/4X4 /AutoTranny /4.10 /Crew Cab /SB
Tymar Intake /Optima Red-Top's /Gutted Kitty /Tru-Cooler 4590 /Magnefine /Filler Neck Mods
Phantom Autometers /Pyro & Temp 2 pod /Dwnpipe mod
4" LiftKit/ AirBags/ LineX /SuperChip /HPX /203*f DieselSite.com
BrakeSmart/ I/C /Amsoil 5w-30
Rear Mount ATV BedRack
DslLvrLdy is offline
Old 06-09-2005, 02:04 AM   #9 (permalink)
I found the problem.
1) I checked all the fuses #16 and # 28 and two relay fuses. All located under the hood on the drivers side near master cyl/brake fluid.
The larger fues box has the 16 &amp; 28 fuses and the small one on the side of it has two relay fuses.
I didn't find any burnt fuses but replaced the 16,28 and replay fuses anyway.
As before the trailer lights worked, turn sig, brake light, running lights,,,,but no trailer brakes.
2) I looked at the "Tekonsha" brake controller for an in-line fuse but it has none so I assume the fuses ford supplies are the in-line fuses.
I un-wrapped the black elec. tape on the controller wires and everything was fine. (still nothing)
3) I went to the 5th wheel Pig tail in the bed of my truck and followed it to the splice under my truck and un-wrapped the tape on all the wires and "WA-LA" found a Blue cooper wire that was spliced to the trucks trailer connection (the one on the bumper)that was completely corroded in half.
I cleaned and cut off the bad section of the blues wires (one for the pig-tail, one (cut in two)for the trucks OEM wire and re-spliced them together and everything works again.
4) What I found while doing this!...wires will get water on them and corrode under the truck if not tape extremely well.
Thx all for the help and direction, and it was nothing more than a corroded wire and bad connection. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
