A friend is buying a 26' 5th wheel camper. He also has a four horse tandem trailer that he wants to pull behind the 5th wheel and will haul a mule and a horse. With the weight of the pony hauler on the back he would like to have the brakes on both trailers doing some work. Is this possible? If it is, how would he go about it?
The things to consider would be that the brake controller is rated for the number of axles with brakes and that the wire used in the harness appropriate for the total length and amperage. There is a calculator located here that might help. http://www.wranglernw.com/wire/ I'm sure there is a better one on the interent somewhere.
04 F-250 6.0 CC SB (Jeep Hauler)
Might also want to look at being over length. I'm not sure what the DOT lets people pulling doubles run, but I've never even seen the Featherlite hotshoters pulling that much stuff. a 26' '5er plus a 20 something horse trailer is going to be a bit long. On the brake controller side, I'd want all 4 axles to have them. Just look for one that'll handle 3 or 4 axles. Most have a rating for the number of axles on them
Aaron SEIA
My Truck:
97 F350 4 door dually, E4OD, DIY intake
only exhaust is stock DP
flatbed
gutless wonder, I want my 94 back!!!
Well, he would want a controller that will handle 4 axles or 8 brakes, but if I were doing it, I would rig a second brkae controller for the second trailer. That way you could adjust on-the-go how much braking that rear trailer is doing compared to the front one. That would be handy if he started out a trip with a lot of hay and water, and ended empty. Or if sometimes he leaves one of the two critters at home, etc.
I just like to customize my stuff my way, I guess. Maybe it would be overkill. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
99.5 F550 4x4 XLT--BD Power tranny, auxillary tranny cooler, inline tranny filter, 203* thermostat, 75# fuel reg mod, 4" AFE SS exhaust, DIY air intake, Edge Evolution, and Timbren Load Boosters
When pulling two trailers It is adviseable to use two brake controllers.and set the rear trailer gain a little higher than the first.Most states say that when pulling doubles that the first must be a 5th.trailers 27 27.
Thanks for the replies. I was thinking the dual controller route would be best, just didn't know how well it would really work. He shouldn't have an overlength problem, he'll be pulling with a regular cab pickup, that's why he's limiting himself to the 26' 5th wheel.
I don't think that combo would be safe at all!!! A 4 horse pumper pull is very nose heavy! haven't seen one that wasn't! There made to really be towed behind a motorhome not a pickup even. this has the potential to turn into a real wreck. With the really nose heavy horse trailer trying to push the 5er down its going to try and unload the rear wheels of the truck. IF he really is only going to haul two horses then he might be able to get away with this and a 2 horse trailer.
Another thing you have to remember is this is a LIVE load not a static load say if the horses get really cranky they have the ability to really make a hairy situation really bad in nothing flat!
Personally I don't think this is a good idea AT ALL! And potentially dangerous! I have seen when horse trailers have been involved in major accidents and its not pretty in the least!
00'F350 psd CC Drw 2wd Bright Amber Western Hauler, exhaust brake transfer flow 50 gal tank tool, 30K Cody goose neck hitch, hawk pads, cryo'ed rotors, stainless lines, 380,000 miles
02' Psd Excursion Limited ultimate Estate Green 7.3L Auto 2x4 hellwig swaybars and rancho 9000's. 381,000 miles.
1993 F-superduty (F-450) 7.3L Gutless non turbo 2x4 Auto, Tire eating S.O.B. 12,750lbs 80,000miles lincoln Vantage 500 Duetz bolted in the back.
1994 7.3 I.D.I.T. factory turbo, auto 2x4 DRW with lots of upgrades, 11 transmissions under 100K factory warranty. 280,000 miles Currently Cavitated and parked.
96 F-800 24'flat 5.9L cummins, 4spd allison juice brakes.
89 F-800 6.6L 5+2 27,00lbs light weight with National 556A crane behind the cab.
2006 T800 KW 550 C-15 18spd 22K front, 52K rears murray ramps, 195" W.B. CA spec heavy haul SOLD
2006 Murray 16 tire professional lowbed SOLD
1996 fetherlite 4 horse GN, Walton 18' 14K tag tilt equipment trailer.
