Building trailer from trailer house frame/axles, have a few?????'s
Alright, I am building a few trailers from some mobile home frames that were given to me. I have just the I-beam frames, one is 60' with 3 axles, the other is 66' with 4 axles. My plan is to cut each of them down, and make several 25'ish trailers... Though I will need to get some more axles, I want to have 3 axles per trailer..
Now, before anyone tells me about using these as trailers, let me be clear on what they will be used for...
I own a firewood bundling business. We get in 10-15 cords of wood per day, most of it sits for several months, and then is split. Once split, it is stacked on trailers, and brought in the barn to be bundled. So, these trailer will be used to transports stacked, dry wood a distance of less than 1/2 mile round trip... So, I am just trying to stay cheap with them. They will never hit the road.. and they get beat up, so I don't want to invest much in them..
My question is.. I move trailer with a skidsteer or a pick-up, I can push or pull a whole lot of weight, but tongue weight may be an issue. How do I know where to locate the 3 axles to give the best pull, and have a manageable tongue weight??
2002 F-350 CC Lariat 4x4 Dually PSD Auto
2000 F350 red crew cab, longbed, 4x4, regency conversion (billet grill, center-console entertainment center w/t.v. vcr, rear passenger stereo). TS 6-pos. flip chip, AFE Magnum, Autometer Pyro/trans/boost on pillar, 4,5" Edge w/bilstein's, ***For Sale***
1995 F350 Powerstroke, Flatbed, 8' Western, Swenson V-Box ***For Sale***
1997 F350 - Finally SOLD
1998 INTERNATIONAL 4700 DT466E
1999 International 9200 N14
1995 F800 Bucket truck, 5.9 cummins
***Looking for crewcab F450 or F550 with dump, and pref. 4x4*** Help me find one. greg bottlefed89@hotmail.com
Re: Building trailer from trailer house frame/axles, have a few?????'s
I would just go and copy the dimesions off of another trailer made by a large company. Have you looked closely at the frames on the mobile homes. The I beams are the thinnest I beams made. I used one a couple of time for a pull off at the dump with chain run around a 4' section, and the thing bent. I wouldnt trust them with very much weight. Remember those m-homes are only thin wood walls -- very light.
Current 2002 F-250 Crew Cab SB 7.3 Auto 4x4 White FX4 131k
2000 F-250 7.3 Auto Shorty Extended Cab 4x4. Bought brand Spankin new. Zoodad, Hypertech tuner, straightpipe. Sold @ 69k miles. Bought New in 2000 sold 07/03 to get a 2003 Crew Cab. Needed room for the baby.
03 F-250 Crew Shorty Torqueshift 4x4. Bought 05/03 brand spankin new, Traded in 10/06 As of 10/06 111k Tuned by Innovative, Mbrb Turbo back with extra whistle, Airraid intake, Guages. **Update** 10/06 Oil cooler sprung a leak and caused the entire cooling system to fill with oily water. Dealer quote -- 4900.00. Injectors were missing on cold start sometimes took as long as 5-10mins. for them all to start firing. Come on ford! Traded truck in one week later for 2007 Dmax/Allison LBZ
2007 Silverado Classic Duramax LBZ. Bought brand spankin new. 6 speed ally, crew, Longbed, 4x4 charcoal grey. Stock for reliablity. Sold (Crew Cab Long Bed is impossible to drive in town, and missed the fords. 7.3 here i come)
Have you considered setting your trailers up like hay wagons? That is with a tongue that basically has no weight and is connected to the front "steer" axle. Sure they won't pull as nice as a regular trailer, but you said you were only moving 1/2 mile or so. Also backing the trailers won't be as easy, but with a little practice you can get the hang of it.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
I would agree with barrelhorses here. If you use a trailer style setup tongue weight is going to be a constantly moving target as the trailers are loaded and unloaded. If you don't want tongue weight you need to consider a wagon style instead. I suppose another option would be to put a self steering dolly wheel at the front end that would carry the tongue weight and still allow trailer style maneuvering.
as far as the Ibeam goes if it is W12 x 4" than the lightest it could be is 14# per foot and for a 25' trailer that is ok, most trailer mfg outfits use 14# I beam on a 20+5 wether it is a dual or single, you will want some tounge weight or the trailer might want to start to fish tail on you at speed. I know it is for off road use but it will inevidably see pavement and at least 55 mph,then you need to figure out which axles you will use and set the frame up to mach the spring centers on the axles, tandem dingle is at 60" wide, tandem dual is 51" wide hope this helps.
Hi Bf,
Here's a few considerations.
A tri-axle trailer has no load sweet spot like a tandum axle. In fact on a surface other than flat, you will apply reverse torque to the tongue of the trailer so severe that with 4000lbs of load weight on the tongue, I snapped a 1/4" chain holding the pintel to my ball while on a "gentle" rolling surface.(I didn't have a pintel hitch built for my receiver when I bought my tri-axle, hence the 1/4" chain use). This is due to the way a tri-axle suspension works. So if you can't hold downword tongue weight, you sure can't hold the upword tongue weight and the trailer will eat you alive when you try to move it fully loaded on a uneven ground surface. I will never buy/build another tri-axle trailer!
A tri-axle takes special spring hangers and equalizers, about $50 in the Dexter tri-axle hanger kit and you can NOT use tandum equalizers as they won't load the springs correct.
You can buy a new 6-ton ag-wagon frame complete (tires, alxes, frame) for about $1500. This will let you move 12,000lbs at under 15mph and twice that at 5mph. This way you will have no tongue weight to contend with. I think the 10-ton ag-wagon frames were under $2000.
Tying to place the axles at 50% of overall length would mean you would always have to unload the back of the trailer first without creating to light of tongue weight as the load weight is removed as it would pick up the moving vehicle off uneven ground.
The correct axle placement on a tag trailer, is real close to 66%, that is of over all trailer length x 66% is the distance from the pin/ball to the axle center line. On a tri-axle design then the center of the second axle would be 15ft 10-1/16" on a 24ft trailer.
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run Define Union: A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
I agree wagon idea sounds best. Slightly higher bed height but otherwise. I looked in local (farmer to farmer) type paper and trailers go for $300 with imp tires (add said no cracks in tires) and a 8 ton trailer. I have a couple trailers for moving stuff. Kinda handy.
You could buy an old running school bus about $300 and convert it to a trailer. Most all our homemade bale trailers were school buses at one time. One fellow I know just removed from the driver back and still uses the engine and drivetrain to haul heavy loads.
Farm technology.........
You could buy an old running school bus about $300 and convert it...
This is not a bad idea, but why convert it to a trailer, just strip it down to a chassis cab and use it as a self propelled unit. Or, strip it down to the frame and leave the axles on it and add a tongue to the steering wheels. The bad would be that the height of the frame might be an issue.
Old cotton trailers would be what you would be looking for around these parts. These on eBay are located at Frogmore, LA which is about 25 miles from me. Cotton Trailers
GOD BLESS OUR TROOPS!! - GOD BLESS AMERICA!!
