Bumper pull to fifth wheel adapter - Diesel Forum - TheDieselStop.com
Old 09-10-2009, 01:50 AM   #1 (permalink)
oldbronco's Avatar
Question Bumper pull to fifth wheel adapter
There was a company a few years back that made a bolt on adapter to use a fifth wheel or gooseneck hitch with a bumper pull trailer. They went in a different direction and quit making them, and I was wondering if anyone knows if another company is making something similar. I would like the option of being able to use either style hitch depending on the truck I'm using at the time.
Thanks,
John
John
04 Explorer Limited
06 F-450 4x4 CC Lariat
85 Ford 4610 tractor
08 Polaris RZR
oldbronco is offline
Old 09-10-2009, 03:44 AM   #2 (permalink)
why wouldn't you just use a normal hitch? most trucks have them.
formula racer is offline
Old 09-10-2009, 06:42 PM   #3 (permalink)
oldbronco's Avatar
For the most part, I prefer the way a fifth-wheel pulls and rides.
John
04 Explorer Limited
08 Polaris RZR
Old 09-10-2009, 07:30 PM   #4 (permalink)
RatherBNtheWoods's Avatar
I don't mean to question you, but are you sure?
I can't even picture what it may look like. Seems like it would have to an addition to the trailer or something. TT to goose/5er? hum.
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
Old 09-10-2009, 07:50 PM   #5 (permalink)
468LC's Avatar
Yeah, I am not following this either. I have seen a few fifthwheel to bumper pulls but never a bumper pull to fifthweel.
Steve
2006 F350 Lariat, 6.0 PSD CC LB 4X4. 77k miles.
Wix/Baldwin coolant filter, Dynomax Ultraflow exhaust, cat mod, Edge Insight CS/with EGT.
Mag-Hytec trans pan, 08 Diff cover.
2" leveling kit. RS9000 Shocks. B&W Turnover Ball/ Companion Hitch. Airlift 5000 airbags.
LineX, 20% tint, Weathertech liners.
2006 Forest River Sierra 5th wheel. 31' @ 11k pounds.
468LC is offline
Old 09-10-2009, 09:13 PM   #6 (permalink)
My Photos: (60)
I have been trying to find a write-up I recall of someone who did this for a flatbed. It actually made the deck area more or less the length of the bumper pull from coupler to tail when it was hooked up for the fiver.
I can't find it, I will keep looking and post if I do.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 09-10-2009, 09:57 PM   #7 (permalink)
See Product Specifications and Information
FairfaxF350 is offline
Old 09-10-2009, 09:59 PM   #8 (permalink)
that converts a fifth wheel trailer to a bumper pull; not what the OP was looking for
Old 09-10-2009, 10:36 PM   #9 (permalink)
My Photos: (60)
I found the thread but, unfortunately, it relies on photographs to demonstrate a lot of how it was done and none of the photos anywhere in the entire thread are hosted anymore. Really too bad, I recall this being a well done design and execution. When hooked up as a gooseneck it was hard to tell the base trailer was a bumper pull unless you looked pretty close. Built by a member here, but he has not posted since June of 2008 so I imagine it would be pretty hard to run him down.
LINK TO THREAD
Anyway, proof it has been done. The builder can use the trailer as a bumper pull (he used a 16000 lb 20' flatbed) or bolt on the gooseneck adapter and have an 8 ton gooseneck. It would be no big deal to build it as a fiver instead of a gooseneck.
Dave / Believer45
Old 09-11-2009, 01:01 AM   #10 (permalink)
oldbronco's Avatar
This is what I had in mind, although not folding. I found this online after about an hour of searching.
John
04 Explorer Limited
08 Polaris RZR
Old 09-11-2009, 11:34 AM   #11 (permalink)
88beast's Avatar
ya they usually are custom made i remember the one dave brought up it was a good design and a little crazy but worked well
on edit fairfax
those things are unsafe they do not give enough weight on the bumper to safely pull a fver or gn trailer
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 10-01-2009, 05:59 PM   #12 (permalink)
Looks like it would be more trouble than it is worth. Just my 2 cents
stinger254 is offline
Old 10-02-2009, 11:14 AM   #13 (permalink)
Originally Posted by 88beast View Post
on edit fairfax
No personal experience with one, but I think that dolly should be "safe", and here's why. The insert goes into the truck's receiver hitch in a solid mounting manner. There is no pivot or turn between the wheels of the dolly and the drive wheels on the truck. In other words, the dolly's wheels and the truck's wheels are always on the same plane, so the dolly becomes an extension of the truck, much as if you added an extra axle to the truck's frame. If you did add an extra axle to the truck, it would have springs and be allowed to go up and down, and the dolly allows that too.
Where I see the problem with this set up is in tight parking lot corners, where the dolly and drive wheels have to scuff sideways. I know how hard that is on a multi axle trailer, and would expect the same from this.
If there is a pivot or hinge in the dolly's insert for the truck's receiver hitch, than disregard all the above, but I don't think that is the case.
boatpuller is offline
