i want a trailer and i need to haul junk cars and backhoe type equiptment.
my truck has the hitch for any weight needed or i can buy a gn hitch if needed. what would you guys recomend i get?
i was looking at a diamond c trailer with 2 7k axles and a tilt deck
is that too much ?
and is steel or wood better for stuff that will cause damage. i thought the wood can be replaced if needed but the steel is really strong, maybe it wont get beat as much as i thought.
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
<span style="color: red">i have created a website for old ford diesels please check it out and tell me what you think</span> http://oldforddiesels.googlepages.com/home
There are a lot of factors to think about. If you are going to be hauling 12k+ most of the time I would get a gooseneck trailer. Otherwise, I would get a bumper pull with a good w.d. setup. I like wood decked trailers, but they will get scratched and beat up quicker, but replacing the deck is a piece of cake compared to a steel deck. Wood will be cheaper, but the trailer might not be as stiff with wood. I would just make sure the trailer has 16" o.c. cross members or tighter.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
i want a trailer and i need to haul ... backhoe type equiptment. ... trailer with 2 7k axles and a tilt deck
is that too much ?
Not enough. Backhoes are a lot heavier than most folks would guess.
That's only 14k GAWR. A full-size backhoe weighs around 17,000 to 19,000 pounds. For example, John Deere's smaller full-size backhoes:
310J = OPERATING WT, 16,900 lbs.
410J = OPERATING WT, 19,000 lbs.
So your trailer needs, as a minimum, two 10k axles to haul the backhoe plus the weight of the trailer without being overloaded. If you have a choice, you want a gooseneck trailer. Here's my choice:
Yes, those are dually trailers. The tandam axles with single wheels are fine for hauling cars, but not for heavy stuff such as a backhoe.
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; TurboRamAir intake and 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and TTM; AIC. I special-ordered it new and plan to drive it until it quits.
wow ok smokey not that hardcore ill have to be more specific rental stuff maybe a bobcat (i meant it to be taken as small equiptment). but id also haul large stone thatd need to be rolled off thats why i was pushing the tilt
Bobcat skid steer loaders come in several sizes, but common is the S220 at about 7,500 pounds. The Bobcat T250 track loader weighs 9,350. So a trailer with two 7k axles would handle those fine - as long as you didn't try to haul two at a time.
That trailer is certainly not overkill, but it will probably be okay as long as you don't try to haul something that weighs over about 10,000 pounds - such as a 17k backhoe.
But caveat. A 7k axle with single wheels means a tire rated at 3,500 pounds. That ain't no ordinary tire. So pay attention. They are available, but not cheap. For example, the Goodyear Unisteel® G614 RST®: Goodyear RV Tires || Unisteel® G614 RST®
let me ask this then smokey (or others) where/ what axle combo will get me more common tires? i know i paid a pretty penny for the tires on my truck i dont also need to pay that much for them on a trailer too
Have someone custom build a trailer for you. I needed/wanted something similar to what you describe, so I built a 30ft half tilt bed half flat bed gooseneck. Two 7500lb axles, 8 lug rims with 16" E tires. Loaded correctly it will hold 18K lbs. 15 on the axles and 3 on the ball. The back half is metal floor tilt bed and the front half is wood and flat. I can load one car/tractor on the tilt then drive/move it to the front and load another on the tilt and leave it there. You could load a big rock, roll it to the front, then load the skid steer on the tilt bed.
12injectors so far
1 FICM
8 glow plugs
1 glow plug control module
1 HPOP
2 EGR valves, plus(cleaned 6 times)
EGR cooler
buzz flash replaced with
heat flash(seems to work quite well)
2 Batteries
8 Tires
Rear brake pads,,,At 105,000 miles.
Enough Rotella to float a boat!
New flywheel/clutch assy(possibly not needed)
Death wobble-FIXED!!ihope
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear,captains chairs, polished forged wheels, sunroof, tow mirrors, tow command brake controller, skid plates. Built May05. 4" turbo back w/modded OEM CAT,turboflow muffler, 100gal aux fuel tank, low profile black toolbox,5th wheel/gooseneck hitch, LineX(hate it), GlowShift fuel pressure gauge and fuel crossover tube. A real pig from a stop, but give me 10' and she'll lite'em up. 88K troublesome miles. Running fairly well for the last 20,000( Let us pray.....).
You can use that same axle and wheels, but simply mount cheaper tires. You won't still have 7k GAWR though. Ordinary LT235/85R16E tires have a weight capacity of 3,042 pounds, so two of them would be 6,084, so basically you would have two 6k axles instead of two 7k axles. And that will give you a trailer GVWR of around 13,000 pounds.
You can probably buy Wal-Mart brand LT235/85R16E tires for around $100 each. You can buy General Grabber AT 2 for $111 at TireRack.
would duals on that work better for load i dont mind going over what i need just dont like under rated (cheap tires)
To convert the trailer to a dually, you'd need two 10k axles as well as new wheels and the tires to go with them. That's quite a bit of spare change - around $3,000 - from Trailer Axles that carry 20,000 lbs.
Then don't go with cheap tires. The best in size LT235/85R16E for 6k axle rating would be Michelin XPS at over $200 each. Or the Goodyear RV tires in load range G to retain the 7k axle rating would probably not cost much more than $200 each.
