Old 03-06-2005, 08:47 PM   #1 (permalink)
Can i tow 10 tons?
Me and some neighbors are going to get some gravel for the alley way and i have access to a dump trailer. I have no idea what the capacity of the that trailer is, but if it will hold 10 tons, can i haul it about 15 miles, mostly flat ground and about half of it interstate?
2000 F250 Xcab, 4wd, auto, PSD
Chrome bed rails, chrome nerf bars, 285's, gooseneck, flowmaster exhuast system, K&N drop in air filter, superchips tuner, tranny temp and oil pressure guages.
1997 Ford Explorer with a solid front axle, 35's, locked front and rear, Warn M8000 winch, custom front and rear bumper, rock sliders
joshc is offline
Old 03-06-2005, 09:08 PM   #2 (permalink)
Re: Can i tow 10 tons?
can the truck tow it, yes. would i want to, no. yer lookin at 10 ton plus the trailer and probably 8,000 for the truck, that's alot of weight to stop. if it wasn't for the highway "I" would do it, but that doesn't mean that you should [img]/ubbthreads/images/graemlins/wink.gif[/img] in order to haul 10 ton the trailer would have to be at least a tandem duall dumper. i think for that distance it wouldn't be much of a hassle to make 2-3 trips.
<span style="color: #FF0000">#18</span> not all trucks are created equal
THE COWBOY'S CADILLAC,<span style="color: #FF0000">my pics.</span>, 96 F-350 XLT SC DRW PSD, 4x4 conversion(D60),more oil than you, auto tranny by faubion motorsports, tuned by a backwoods hack(thanks tony), 230cc injectors, D66 turbo, head studs, 910 valvesprings, open element intake, homebuilt fuel system, 3-4"DP, intercooler with homemade spider and piping, 5" chrome stacks with turnouts, front hitch(for my weight bar), member of the <span style="color: #FF0000">WNYPA</span>
on the way: more power
bullridin_fool is offline
Old 03-06-2005, 09:11 PM   #3 (permalink)
It is a tandam axle trailer and it will be 2 or 3 trips with that size load. lol
I don't have to take the interstate at all, just figured that would be easier. Doesn't matter anyway.
I'm interested to see how it would pull a load that size. Only thing i've put behind it is my explorer which is between 4-5000 lbs plus my car trailer.
joshc is offline
Old 03-06-2005, 09:27 PM   #4 (permalink)
yes it's a tandem axle, but do the axles have dualls on them. not counting what the trailer wheighs thats 2500 # on each tire if both axles have dualls, if it doesn't have dualls that's over 5,000# on each tire.
Old 03-06-2005, 11:50 PM   #5 (permalink)
Is the trailer rated to haul a load that big? Do you have a weight dist hitch? Does it have good brakes? If you said yes to all those, you can pull it and if you use your head you should be safe. The overall weight isn't a big deal. My father croses the scale at almost 38,000 lbs with a gooseneck in a 1990 F250, so your truck can pull it.
Trinity
Early 99 6spd (Eaton Fuller Knob), 285x75 MTR's, DI 4 POS Chip, Walker BTM, listening to XM Delphi skyfi, pulling 24 ft full of Mechanical Bull, heading to a bar near you!
Truck pics
tsaelens is offline
Old 03-07-2005, 12:54 AM   #6 (permalink)
Q1. can you pull it?
A1. probably. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Q2. can you stop it?
A2. maybe. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
i am more concerned with the questions surrounding Q2
2003 Ford F350 Crew Cab Long Bed 4x4, 6" Edge all spring lift with Adjustable Panrod Bar and Dual Steering Stabilizers, 37" BFG Mud Terrains, 4.56 Richmond Gears, DPPI Turbo Back Dual Exhaust, Autometer C2 Gauges on A Pillar, aFe Proguard 7 Intake, Reese Titan V Hitch, B&W Turnover Hitch, BrakeSmart controller, ORU Air Overload System
My truck pictures
double is offline
Old 03-07-2005, 05:55 AM   #7 (permalink)
Ok, i see now, sorry about that. It is not a dual.
Like i said in the first post, i don't know what the rating of the trailer is, i just wanted to know if i could do it if the trailer could handle it.
I do have a weight distrubution hitch system.
As for stopping it, i don't know. I would assume that if the capacity is with in what i dump in it, then the brakes would handle it on the trailer. I don't know if it is hydralic or electric, i'll try to stop and look tonight coming home from work.
joshc is offline
Old 03-07-2005, 07:38 AM   #8 (permalink)
Sounds like the trailer is a light duty dump trailer if it is a 8lug axel then the gvwr is around 14k. [img]/ubbthreads/images/graemlins/confused.gif[/img] 8 lugs are usually a 7000 lbs axel. the trailer probably weighs around 3200 lbs. So even with the 7000 lbs axels you have a payload of around 10500 lbs. [img]/ubbthreads/images/graemlins/eek.gif[/img] HALF of what you are looking at towing. I have towed 15k with a f-150. I am not proud of that but I did do it. It really depends on the weight the tires will allow because that is what will fail first. From whaat is sounds like your trailer is even smaller than the one I speced above. Good Luck and be safe. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Nick
2005 F-350 Lariat 6.0 PSD CC Dually 4x4
Big Black Beast
Born 2/14/05 delivered 2/28/05 Purchased 3/1/05
2000 X Limited PSD 4x2 Stock. SOLD
Nick_Kowal is offline
Old 03-07-2005, 08:21 AM   #9 (permalink)
I don't think its rated for that much we have dump trailers at work and ours are rated for 4 ton and theres another size bigger rated for 5 ton.
I'd just split that in half and make a day out of the project.
2003 F-250 ext cab 7.3 Powerstroke
Sport Package
Stock for now [img]/ubbthreads/images/graemlins/wink.gif[/img]
Derag2 is offline
Old 03-07-2005, 08:27 AM   #10 (permalink)
BJS
Yes it will pull it, Should you? not really.
Your trailer sounds very similar to the one I have. Double check the weight rating plates on the trailer, more than likely it's a 14kGVW trailer. The trailer alone will weigh in around 4k. It will more than likely have electric brakes. The one I use has them on both axles and I really don't like the feel of it w/ 5 tons (10,000lb) in the trailer. I had ample power and COULD have pulled more though I'd be concerned with stopping it.
For me the quarry is about 15 miles from the house mainly side roads, w/ a little on a 4lane state hwy. When I sat down and calculated what it cost me to haul it myself, counting only fuel, I was within $20 of having it delivered. Check with some of the local trucking companies and you might surprise yourself. Your average tandem axle dump truck carries in the neighborhood of 17 tons. For me here anything I was looking at was about $10/ton out of the quarry. Delivery ended up costing me about 40 over the cost of the product.
95 F350 Centurion Conversion Bronco E40D (Crew Cab SRW) 4X4 4.10, Boost, Pyro, & trans temp on the A-pillar, BDP Stage 1 injectors, Open air intake, Dpp Downpipe, TS chip.
BJS is offline
Old 03-07-2005, 08:52 AM   #11 (permalink)
I wouldn't do it. Find a smaller trailer.
The bad outcomes FAR outweigh the good outcomes. Overweight tickets among them.
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
16' American Hauler tandem axle cargo trailer
NRA Life member
Wobblin-Goblin is offline
Old 03-07-2005, 09:48 AM   #12 (permalink)
My Photos: (13)
Can you tow 20K? Yes, no problem.
Can you stop 20K? Yes, no problem if you keep it under 50. I think lots of folks assume you'll be driving 70.
Can you haul 20K on the trailer you describe? Nope
Ag__Teacher is offline
Old 03-07-2005, 10:00 AM   #13 (permalink)
NO!
Make two trips.
http://community.webshots.com/user/roadfrog
Cheers,
Chris
FOR SALE! 2002 F350 CC 4x4 SB Lariat Blue & Silver, General AT2 295/75/16's on 16x8 Panther Rims, KYB Monomax Shocks, Euro Style Tail Lights, billet fuel door, Putco chrome handles, Autometer Z Gauges & Pillar Pod, Billet Grill, Bullbar, JVC KD-AR870 head unit, Sirius, MEI Reference Series 600 Watt amp with 6.5" Alpine DD Drive F17C components front, 6.5" Jensen components in rear, Better Built truck box, auxiliary backup lamps, acetoned badges, blacked out lower weld seams, Dodge auto-dimming rearview mirror, Avital alarm system, heater by-pass mod, in-tank, harpoon and pre-pump mods, 5" SS exhaust tip.
2002 Acura el (only available in Canada)
2002 Fleetwood Wilderness 31G
1988 Campion Allante, 19.5' w/ Merc 5.7 litre
Roadfrog is offline
Old 03-07-2005, 06:39 PM   #14 (permalink)
I have no idea what the capacity of this trailer is!
I stopped to look at it this afternoon. It's a dual axle, dual wheel, goose neck all electric. It's kept at a friend of mines and he has no idea what the capacity of it is.
Like i said earlier, i have no idea if this would even haul that much (before i stopped to look at it) and i was just curious that if so, would the truck haul it.
Yeah 50 would be tops. No way would i put that kind of weight behind a pick up truck and try to do 70 on the highways.
I did call today about getting gravel hauled here and it was suprisingly cheap. 35 bucks for a dump truck load, between 17-20 tons. So that's great. I'm sure i'll end up doing that, but it would be fun to see how well the PSD with that kind of weight! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
joshc is offline
Old 03-07-2005, 10:22 PM   #15 (permalink)
If it is a dual tandem goose then it is prob. rated at 20,000. That means the thing probably weighs about 6000-7000 anyway. So you could only put about 14,000 of stone in it. If you do it make sure the brakes all work properly and drive defensively. Oh yeah, don't forget your CDL.
1996 ext. cab, long bed, 4x4, 5spd. PSD, 3.55LS, Ford AIC, drainplugged Dana 50, EBPV brake, tranny cooler and gauge, Tymar intake, Tymar 4" downpipe and 4" exhaust. No kitty.
Nick_Kent is offline
