Old 09-28-2008, 07:31 PM   #1 (permalink)
can i tow this?
39ft. toyhauler 5th. wheeler. light weight is 13,000. almost 3000 hitch weight. or should ilook for lighter one. can pick it up for a good price. my truck hauls my 27 komfort fine, but its only around 8000 loaded up. thanks yu guys. my truck is 2002 f350 no duellys. wish it was now.
2002 f350 crew cab short box 3inch tuff country level kit 315 toyo mudd terrains on 8 inch nitto rims afe stage11 intake with pre filter window tint leer canopy auto meter quages . 4 inch mbrp exhaust. superchips 1805 tuner. towinn our 2004 27 ts komfort tt.
http://community.webshots.com/user/rws444psd
rws444psd is offline
Old 09-28-2008, 07:44 PM   #2 (permalink)
IMHO, With 3000 lb hitch weight you don't need a dually. You should be OK. Just keep your tire pressures up. You might need air bags to keep it level.
'08 F350 Lariat CC DRW 4.10 4x4 manual hubs and 62 gal fuel tank.
rskeans is offline
Old 09-28-2008, 08:32 PM   #3 (permalink)
You're asking alot out of your truck. You'll be running at max weight, and if you ever have to swerve or anything those single rear wheels aren't going to help you one bit. If the light weight is 13k, what is loaded weight? That is really what matters. You can put alot in a 39' trailer.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
NickKent is offline
Old 09-28-2008, 09:32 PM   #4 (permalink)
Hi rws444psd,
Can you pull it ?? YES
But should you ?? NO
You will not be towing it empty, thus more weight than your truck rated for ??
Your lift will make emergency control even less than you have at stock height.
Your lift may make it impossible to run the trailer at level, if it ain't level -then even more emergency control problems.
Safety should be your primary concern, and that of anyone within a couple of blocks of you on the road. That setup just won't be safe if anything at all goes wrong. Tire blow, bearing failure, break failure, trany failure, avoidance maneuver, etc.
Not to mention the increased stress to the Trany, and every other engine, driveline, suspension component, and brakes, especially up and down in any mountains. With that system, a dually is a must minimum.
Don't even ask how much you'll loose in gitty-up-go and fuel mileage, with that much extra weight and height.
Stay lighter, like as you are. Much safer and less expensive. IMHO
02 F250 PSD, 4WD XLT, 3:73 Ltd.slip, White, 4Dr-XTCab Short Bed, TT Mirrors, Trailer Tow, Camper & Off Road Pkgs, Adj.Pedals, OEM Running Boards & Rr.Sliding Window, Brake Controler, GasMagnum Shocks, Garmin Nuvi 200W GPS, Reese Kiwi Manual Sliding hitch, NAPA 6637 air filter, Xtra leaf in both FR & RR springs, Edge-Juice/Attitude, T/C lock-up switch, CCV Mod, Fog Lites/Hi-Beams Mod, Pre-pump mod, Intake Heater delete, Dynomax Race Muffler, "Zoodad Air", heater by-pass, Bug Deflecter, Husky Catch-all Floor Liners, Ventshades, hard rubber fender flairs, Rino Liner, X-Tang Soft Tonneau, brighter lites & fogs, Cobra CB & K40 Ant., Dynamat Extremed interior, 2005 26' CrossRoads Crusier 5th wheel, other goodies coming. Variable 10K Mod with On/Off.-[color:"red"]Pics.[/color]
PSDSKATER is offline
Old 09-28-2008, 10:22 PM   #5 (permalink)
I'm with PSDSKATER. Yes you can tow/move it, NO don't for safety reasons. 13k empty means 15-16+k loaded.
Most RV advisers state that the average "load" of kitchen utensils, clothing, bedding, food, water, batteries, propane, folding chairs, etc., run 1000-1500#s. With a toy hauler you can add the weight of your toys, tools, and fuel.
My 34' fifthwheel is 14k loaded, with 2650#s pin weight. I removed the 4" rear blocks and installed the F250 2" blocks to level the trailer and give my self 6" bed rail to under side of trailer clearance. Then added air bags.
It tows fine, but I wouldn't want to go much more.
Your tires are taller (bad for power) and your brakes are smaller than 05+ Superduties. Since you live in western Washington, I know the roads/highways/mountain passes that you will probably traveling. Your going to be hurting for enough power and wanting better brakes coming down the off the passes.
Best advice I can give is lighter trailer or bigger truck.
Good luck.
05 F350 Lariet SC 4x4 6.0/auto lgbox
gmoore is offline
Old 09-28-2008, 10:45 PM   #6 (permalink)
SmokeyWren's Avatar
My Photos: (33)
39ft. toyhauler 5th. wheeler. light weight is 13,000. almost 3000 hitch weight. ...2002 f350 crew cab short box 3inch tuff country level kit 315 ...
So you have a GVWR of 9,900 pounds if you don't have CA emissions. And your GCWR was 20,000 pounds before you reduced it with a lift and big tires.
Your truck is going to weigh around 8,500 pounds before you tie onto the trailer. That leaves you a max available payload for hitch weight of about 1400 pounds before you're overloaded over the GVWR of your tow vehicle. With 3,250 pounds of hitch weight, you're going to be about 1,850 pounds over the GVWR of your tow vehicle.
A similar Weekend Warrior toy hauler has a GVWR of 18,000 pounds and with a loaded hitch weight of around 3,250. That trailer will severely overload a 2002 dually. Even a new F-450 chassis cab truck would be overloaded with that monster trailer unless the F-450 has the optional high capacity towing pkg that raises the GCWR over 26,000 pounds.
So no, you can't tow that monster trailer with your current tow vehicle without endangering you and yours and everyone else on the road with you.
But you can tow that trailer in relative safety with a 2008 or newer F-450 pickup with the diesel engine. It has plenty of GVWR and GCWR to tow that loaded trailer without overloading the tow vehicle.
So if you want that trailer, first you need to trade pickups.
SmokeyWren is online now
Old 09-29-2008, 07:41 PM   #7 (permalink)
thanks guys, no way iam sellinn my truck, iam stickinn with my 27 komfort tt for now.
Old 09-29-2008, 08:11 PM   #8 (permalink)
Hi rws444psd,
Definitely your safest, and cheapest, decision.
Harold
Old 09-29-2008, 08:36 PM   #9 (permalink)
SmokeyWren's Avatar
My Photos: (33)
You said that TT grosses about 8,000 pounds, so that's a hitch weight of about 900 to 1,000 pounds. You have available payload for hitch weight of around 1,400 pounds, which is a tripple-axle TT of about 12,500 pounds gross weight. Your receiver is rated for 12,500 pounds with a weight-distributing hitch, so that's not your limiter. So why not look at bumper-pull toy haulers with a GVWR of not more than 12,500 pounds?
I looked at the Komfort RV website, and I don't they make a TT toy hauler. But several other bands do.
For example, the 2009 Weekend Warrior model WLFSC2800 has a GVWR of 12,385 pounds. Just what you're looking for. If you load it to 12,000 pounds, you'll probably be over the GCWR of your truck by several hundred pounds, but that's just a performance problem. If you need to climb mountain passes, you'll probably wish you had more power or shorter tires, or both. But you should make it okay.
Weekend Warrior 2009 WideLite
Old 09-30-2008, 04:15 PM   #10 (permalink)
Send a message via AIM to BlueMuleTrucking
Going with a truck that has a 26K or over, here you either need an RV over 26k endorsement or Class A CDL.
Evan-
2003 Ford F-350 Crew Cab L/B/Dually XLT FX4 7.3L/Auto- Gooseneck Hitch Fifth Wheel Rails, Firestone Air Bags/ Toolbox
BlueMuleTrucking is offline
Old 10-01-2008, 09:42 PM   #11 (permalink)
Weekend Warrior is in receivership, look elsewhere...
FS
'01 X 7.3 to tow my racecar...
AIS w/ sleeve
S.S. HX(removed for now)
4" MBRP
FPR shim
TransGo shift kit
Hellwig rear bar
Landyot's Radius Rods
DP Tuner-80E, Hi Idle, 60 tow
EGT, Trans temp, boost gauges
'99 E350 Snake Oil Wagon, 200+K, doesn't burn oil, lives on the bump stops & has a hard life. Runs like new.
'91 Spec Miata
All vehicles full of BG Synthetic Fluids
fastersteve is offline
Old 10-01-2008, 09:58 PM   #12 (permalink)
i have the same exact truck and i pull my 39' fiver with no probs...may need airbags.
2002 F350 Lariat CC SRW 4x4 LB , Shadow Gray, Edge 4.5" w/ dual bilsteins up front/ Toyo Open Country M/T 315-75-16. Stock Motor 7.3, dual alts / 3 guage pillar pod, Auto Meter/ 5" turbo back magnaflow exhaust w/Aeroturbine muffler & 6" Jardine tip/ Husky 24k 5th wheel / Air Lift Bags.
John Wood Transmission / DP tuner / 08' rear diff cover
2005 40' Weekend Warrior 5er, SLC 3905
1977 Tahiti 21' / Berkeley Jet Daycruiser/ 455 Olds.
2000 Sandcars Unlimited / Turbo VW 2275
1988 Ford Thunderbird Turbocoupe 2.3
415_dezl is offline
