Old 08-21-2007, 07:00 AM   #1 (permalink)
Car carrier
I'm going to be using the truck in my sig to travel up to Waterbury, CT to pick up my uncle's Suburban. I'll be using a 16' car trailer. I've never towed this kind of weight without a WD setup. How can I be sure that I'm loading the car properly so that I don't have a sway issue coming home?
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
Gun Control means using both hands.
Stewey is offline
Old 08-21-2007, 08:16 AM   #2 (permalink)
Re: Car carrier
Load the trailer properly with the correct amount of tongue weight, or a little heavy. Then just drive slow. Does the trailer at least have electric brakes?
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
NickKent is offline
Old 08-21-2007, 08:30 AM   #3 (permalink)
Re: Car carrier
You're going to get a suburban on a 16' trailer? [img]/ubbthreads/images/graemlins/eek.gif[/img]
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 08-21-2007, 10:20 AM   #4 (permalink)
Re: Car carrier
Are you sure a suburban will fit on a 16' trailer? You'll certainly have several feet of overhang off the back, and there will be no adjusting for tongue weight, as you'll have no room to shift the suburban fore or aft. The Suburban is only a few inches shorter than your Excursion.
But beyond that, my last Suburban was 7000 lbs, and I suspect it was heavier in the back than in the front. Therefore, you won't need to worry about WD hitch, as I doubt you'll have enough tongue weight as it is.
Were it me in your shoes, I'd try to rent a longer trailer, maybe from an equipment rental store instead of a u-haul or ryder type store. Or, drop the drive shafts and use a tow bar to pull it on the flat. Or, if you have to use the 16' trailer to haul the suburban, with the rear tires just catching the last of the trailer and the last few feet of the Suburban hanging off behind, I'd go REAL SLOW and do it in the wee hours of a weekday morning. Good Luck.
boatpuller is offline
Old 08-21-2007, 03:07 PM   #5 (permalink)
Re: Car carrier
Make sure you have 5000lb+ axles if you're hauling a Suburban. They aren't light.
2002 F250 7.3 PSD XLT 4x4 EXT Cab Shortbox - EVO2, AIS w/Zoodad, MBRP 4" 409SS, 08 rear diff cover, Heated tow mirrors w/signals
1988 Mustang GT 9.71 @ 143 (1.43 60ft)
Blk88GT is offline
Old 08-21-2007, 03:52 PM   #6 (permalink)
Re: Car carrier
For sure, and also check the weight rating of the tires. Most 16' flatbed trailers Ive seen have 2 3500# axles and usually the 15" tires are rated under 2000# each.
You may be pushing the envelope! [img]/ubbthreads/images/graemlins/eek.gif[/img]
Is driving the 'Burb an option? Better safe than sorry..........
'06 Ram 3500 4X4 QC CTD 6sp LB
'01 F350 PSD 4X4 6sp Crew Cab (sold)
'68 F250 C/S 4X2 C6/428PI
Stidham 24' enclosed car hauler
Bunch of big old cars
In theory, practice and theory are the same.
In practice, they are not.
Packard8 is offline
Old 08-21-2007, 04:35 PM   #7 (permalink)
Re: Car carrier
actualy, you probably will have a bit of adjustment on a 16 foot trailer.. the have a slightly shorter wheelbase than a long box truck. I've seen a long box truck on a 12 foot trailer a few times, but there is only maybe 1-2 inches of adjustment front to back with it..
In all reality, I'd be more worried about weight than length with a 16 footer.
88' F-350 reg cab, SRW, 4x4.
7.3/ZF5, 4.10's and 33's, rear locker,
banks turbo, 3.5" straight pipe, pump maxed, and advanced 2 degrees.
89' F-150, 351, 435, dual T-cases, rear discs, front electric winch, PTO winch rear, OBA, 40's
Jrod13 is offline
Old 08-21-2007, 06:20 PM   #8 (permalink)
Re: Car carrier
Sounds as though I should verify the length of the trailer. [img]/ubbthreads/images/graemlins/blush.gif[/img] I was so darned happy just to find one that I could borrow for nothing, I didn't even think that length might be a problem.
Stewey is offline
Old 08-22-2007, 01:28 PM   #9 (permalink)
Re: Car carrier
The suburban has a wheelbase of under 11 feet. You will have NO problem loading it on a 16 foot trailer.
Your weight will be fine too.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
Old 08-22-2007, 01:53 PM   #10 (permalink)
Re: Car carrier
The length shouldn't be an issue, but absent any knowledge of the axle and tire ratings I'm not sure how you arrive at "your weight will be fine too".
The guy asked a question and I don't consider advising him to stay within the rated capacities as being wrong.
Packard8 is offline
Old 08-22-2007, 08:04 PM   #11 (permalink)
JimTJr's Avatar
My Photos: (6)
Re: Car carrier
I think we are going on the assumption that this is at least a 12k or 14k lb trailer, 2x 6 or 7k lbs axles. He should be fine with that. IT can be loaded far enough forward to give him plenty of tongue weight to I bet. (The bumper can hang over the nose some, if the tongue is long enough on the trailer) A 'Burbon only weighs maybe 65oo? Maybe 7k,,,,
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 08-23-2007, 03:48 PM   #12 (permalink)
Re: Car carrier
I wouldn't assume anything. We haven't heard if this is even a tandem axle trailer or a single axle.
OP, if you attempt this, make double sure you pull the truck straight on so the engine is nearest the tow vehicle. In this situation you definitely want as much weight as possible on your rear bumper. If the engine weight is turned the other way you'll sway to the point of losing control of your vehicle.
Just eating rainbows and butterflies
01 F350 dually 4x4 CC auto.
311 hp 610 torque a while back.
My Pickup
Some Photos and Sound Clips
Diesel Power & Performance Derby Ks.
#46
Kanman is offline
Old 08-23-2007, 04:55 PM   #13 (permalink)
Re: Car carrier
It's a tandem.
Stewey is offline
Old 08-23-2007, 05:00 PM   #14 (permalink)
88beast's Avatar
Re: Car carrier
my 2 cents is just dont go over the weight of the trailer you go over the truck they will only know if you get pulled over so tie down engine front and stay the speed limit or maybe 5 under mostly these trucks can haul something like that if its just under the trailer weight empty the tanks in the burban to prevent sloshing and use tire tiedowns and also tie down the frame to prevent bouncing you should be good ca to ma [img]/ubbthreads/images/graemlins/smokin.gif[/img] i think if you could take some pictures to show off the setup of a large surburban on the small trailer
onl last thought do you need flags? for over the end of the trailer i no you need them in pa if its over on a truck ex:10' board in 8' bed
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 08-23-2007, 05:16 PM   #15 (permalink)
Re: Car carrier
It's a tandem.
Do you know the weight rating of the trailer? Look at the wheels...if they are 15" 5 lug it probably has 3500# axles, if 6 lug 15" wheels it is likely a 5000# axle, if 16" wheels usually a 7000# axle.
The trailer probably weighs 1500#, the Burb from 6000-7000# (C/K1500 or C/K2500) equals gross tow weight around 8000-9000# minus the tongue weight of maybe 600-800# means approx. 7000-8000# on the axles & tires.
If the trailer is rated for it and you load it as suggested above should be okay.
Be safe!
Packard8 is offline
