Old 06-13-2005, 06:10 AM   #1 (permalink)
ironsideconst's Avatar
Carlisle Tires? USA or China? HELP!!!
I've got a 2001 30' TT w/slide rm approx. 8K empty. It seems to be time to buy new tires and I need help. I replaced one tire last season because it had a big bubble in the sidewall, now I have another tire with the same problem. Should I replace the other three tires to match the one I put on last year? I seem to remember some discussion here about Carlisle tires some being made in the USA and some in China, but I don't remember which one was better or should I buy 4 new of another brand and keep the one I bought last year for a spare? The one I bought last season was made in USA, the others I have had problems with were made in China. If I should get 4 new what brand does everybody endorse? The tires are (Radial Trail/Load Range D/ST225/75R15) Tanks in advance. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Early 99 PSD (born on date 04/98)
F250 Super Duty,SC,LB,XLT,4x4,373gears,Cobra 29LE peaked to 40watts w/echobox and talkback,Bilstien shocks,no cat.,10K MOD,Custom Zoodad MOD,Homemade CCV MOD,3.5" Turboback w/Walker BTM,Edge Evolution on 80hp,Dipricol Gages,Boost,Trans,EGT,ProPod A-pillar mount, Fumotoed,Sonnax/Tricumulator,SUV Light harness w/.35$ Brightbox,203 T-Stat,FPR shimmed to 69psi,Pre pump mod,In tank mod,Harpooned,Tow 30' Cherokee TT w/super slide room.
ironsideconst is offline
Old 06-13-2005, 07:54 AM   #2 (permalink)
Re: Carlisle Tires? USA or China? HELP!!!
I would seriously consider replacing all the tires with another brand. My preference would be the Cooper, Titan, or Greenball trailer tires. All three of these companies offer tires in the size and load range that you currently are using. All three of these companies have web sites where you can look at their products.
I have not heard a lot of good comments about the Carlisle trailer tires.
George Hilton. '01 PSD 6 spd, Hensley Arrow, Airstream. Life is good.
georgehilton is offline
Old 06-13-2005, 08:41 AM   #3 (permalink)
I found a set at Discount Tire they are (Greenball Transmaster load range "E") is this a good replacement? They also have (Goodyear Marathons)???
Old 06-13-2005, 11:34 AM   #4 (permalink)
Come on people somebody else has to have an opinion on these tires [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Old 06-13-2005, 12:00 PM   #5 (permalink)
Can't help you much with the Greenball's. I've never heard of them (doesn't mean much).
I have a set of Marathon's on my 24' enclosed car hauler and absolutely love them. Iand I don't baby them either.
Had those crappy carlisle's on my open car hauler and had nothing but trouble with them. Constantly blowing sidewalls out.
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 06-13-2005, 03:26 PM   #6 (permalink)
Just say NO to Carlisle. If you buy them don't complain, you have been warned.
2000 Excursion Limited 2x4, 3.73 LS,PSD/Auto,ATS turbo shroud,Badging,BullyDog 4" exhaust,AIS,HX crossover,ISSPRO gauges/A-Pillar,SuperChip 1705, Pre-Pump & In-Tank Mod,Banks TransCommand, ZooDad, Baldwin Oil ByPass,Ford AIC, F350 rear springs, Helwig Rear Sway Bar,Michelin's LTX MS
2003 Sunnybrook/Mobile Scout & Hensley Arrow
sail684 is offline
Old 06-13-2005, 04:05 PM   #7 (permalink)
Dump the Carlisle's--they are bad news big time! My 5th wheel has Goodyears on it and rides smooth as silk with no problems.
2004 F350 Lariat 4WD SRW CC 6.0 PSD Dark Toreador Red/Arizona Beige, Leather Every option but Moon Roof & Kitchen Sink, Fumoto valve, Wildcat 31QBHS 5th wheel
Mike_Costello is offline
Old 06-13-2005, 04:42 PM   #8 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
I got Goodyear Marathons and no problems. Think they had a bad batch a few years ago but haven't heard anything negative lately. Just run them at max side wall pressure.
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum.
Winter Operation (How I Do It)
Hard/No Start? Check here first
2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
Old 06-13-2005, 04:55 PM   #9 (permalink)
Hi ironside,
In 15" there's only one true choice as far as I'm concerned and that's Cooper. I went thru this problem for the past 8yrs and Cooper solved the problem.
I will never put Carlisle on anything I own as there junk tires and a waste of money. Titan's are not much better. Goodyears are over priced.
If you can, I would consider changing too 16" as then you have such a wide choice of tires.
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run
Define Union:
A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
T_Bone is offline
Old 06-13-2005, 08:03 PM   #10 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Another vote for Cooper. My 5er came with Marathons. Blew out three of them in short order. Replaced all 5 with Cooper ST225/75R15D on 6" wide rims. That was about 4 years ago, and I've put about 60,000 miles on those tires up until last month. Then I replaced 3 of them with Coopers, put the spare on the ground, and put the best of the 3 old ones on the spare. Heading out on a 5,000-mile round trip in a couple of weeks, with no trailer tire worries.
Click here for Cooper Custom Trailer Plus ST225/75R15D
My Cooper dealer is proud of them. This year I couldn't get him down below $120 out the door per tire. Four years ago they were less than $100 out the door (taxes, mounted, balanced, enviromental fees, etc.)
Note the Custom Trailer Plus doesn't have Cooper's name anywhere on it. But it's a Cooper. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
SmokeyWren is online now
Old 06-13-2005, 11:31 PM   #11 (permalink)
BOATS! here in Indiana... used 3-4 months out of the year, and parked in garage for the rest.
2001 Rinker Captiva, replaced 3 of the 4 original carlisle tires, at different times due to tread bubbling up and pieces flying off of the tire. Just did the 3rd one this weekend. tires are 4 years old.
1994 Mariah, still has original good years on it. couple of them have been patched from protrusions, but they're still lookin good. 11 years old!
only time these tires aren't garaged is when they're at the lake
maybe this will help?
-Andy
2003 [color:"red"]RED F-250 Lariat FX[/color][color:"gray"]4[/color]
SC/SB
6.0/TS
Chrome Steps
My Additions:
<ul>[*]Fast Idle Mod
Cab Marker Lights
Smoke Bug Shield and
Smoke Ventvisors from AutoVentshade
QMI Chrome Fender Trim
Weatherguard Diamondplate Saddle Box
DeeZee diamondplate tailgate guard
Diamondplate mud flaps from Deflecta-Shield
Rhino-Lining
Kenwood KDC-MP528 CD Receiver
Sirius Direct Connect for Kenwood
Kenwood iPod Interface
Access toolbox-to-tailgate tonneau cover
Garmin Nuvi 350 Navigation
Cobra CB/Wilson 2000 Toolbox mounted trucker antenna
MagLite Rechargeable Flashlight
Floor mounted DOT approved Fire Extinguisher[/list]12/15/07 70,000 happy miles
andrewbalser is offline
Old 06-14-2005, 01:47 AM   #12 (permalink)
My Photos: (10)
I do not have Carlisle tires but have read quite a bit about them on rv.net in the 5th wheel section. Go <font color="red"> here </font> about some recalls or just do a search for Carlisle in the 5th wheel section. Probably the same type of discussion in the trailer section also.
Linc
2003 F450 CC 6.0L Auto 4.88 4x2 Dark Shadow Gray - Douglass RV bed
Prodigy Controller - 1999 National Seabreeze 5er 2037
4five0 is offline
Old 06-14-2005, 06:28 AM   #13 (permalink)
Thank you to all that posted [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] I did get a new set of tires yesturday on the recomendation of one of the posts. I had to get something because I'am going on another trip next week thru the 4th. [img]/ubbthreads/images/graemlins/grin.gif[/img] I bought the Greenball Trailmaster 225/75R15 Load Range "E"
$95.00 each mounted/balanced/disposal fee, out the door. They seem to tow nice so far but I only took it about 6 or 7 miles down the freeway, only time will tell. Tanks again for all the help [img]/ubbthreads/images/graemlins/grin.gif[/img]
Copyright ©2000 - 2008, Jelsoft Enterpri
