Old 07-03-2007, 01:25 AM   #1 (permalink)
Carlisle Trailer Tire Concerns
I bought my 21' car hauler in 97 or 98 new. Came with car tires and the originals did me pretty good til 05 when I started to have tread seperate... Note: that was after two ALCAN highway trips and ALOT of additional mileage. Skimped along and before this trip up the ALCAN, I bit the bullet and purchased new D rated Carlisle ST225/75D15 tires. Figured I could now afford them and they would give me satisfaction/security going from VA to AK...... NOT!!!
A mere 6000 miles and 2 tires are shot [img]/ubbthreads/images/graemlins/vomit.gif[/img], with what I think are broken belts and a third tire tread is fine, but has a big split, so it is shot too. God only knows what the 4th tire has in store.
So *** is going on. I was not over loaded 7500lbs total including the trailer... I plan on calling them and raising heck. Doubt I get anywhere, but wanted to get you all thoughts and/or warn you all.... [img]/ubbthreads/images/graemlins/mad.gif[/img] [img]/ubbthreads/images/graemlins/mad.gif[/img]
In Edit: It was the front axle that the two shot tires were on and looking at the load and the springs, more weight was on the back tires... confirming they were no way overloaded. Also checked hubs and tires on EVERY fuel stop and tires were never hot... Lost a bearing in Laramie, WY though... Yea for me...lol
97 F350 Crew Cab/Auto/White. Skyjacker add-a-leaf / 33 BFG all Terrains / spray-in liner / visor / Leer Cap / Runnin Boards / WARN-Manual Hubs / 4:10's / Lots a extra Lights / 10K Mod / 140K
bbess00 is offline
Old 07-03-2007, 02:21 AM   #2 (permalink)
Re: Carlisle Trailer Tire Concerns
Yep, SOunds like Carlisles. And the best part is, they will say you ran them flat, even if you take it into the store with a thrown tread and fully inflated. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
New addition:
2006 f-550 service body with a 20 foot stellar crane.
Arrest me red 2006 F-250 6.0 Even more loaded
Black 2000 F-250 4X4 PSD Lariat, loaded.
Green 2001 4x4 Excursion Limited with PSD, loaded
White 2004 F-250XL, it is loaded with just a LS. I can't find the other options.:P
Just how many superduty's does a guy need?
The-washer is offline
Old 07-03-2007, 11:15 AM   #3 (permalink)
My local tire dealer tried to put Carlisle's on my 5'ver several years ago. They were made in China. I refused the tires and he re-ordered Denman's.. 15" E rated. I, too, took the Alcan and everywhere in between. I just put on my 2nd set of Denman's and believe they are best trailer tires around.
My 2 cents.
Florida Ed
2001 7.3 F-350 Dually Lariat CC LWB 4X2 Dark Green 4.10 4R100 5'ver Hauler (32' Montana 2 slides 10,500# - 2,000# tongue weight), 106 gal aux tank, 112K miles, nephews arguing over who will inherit it 'cause I'm gonna' drive it 'til I die. Bone stock.
2001 5.4 Gasser F-250 XLT Crewcab SWB 4X2 3.73 4R100 67K miles headed to 150K (wife's vehicle on the "junk-iron" theory of vehicle safety....most junk iron wins in a crash) stock as the day it was made
Before these: '00 F-250 CC PSD, '97 F-250 CC PSD, '94 Ford F-150, '91 Ford E-250, '81 Ford E-150, '66 Ford F-100 (cars not included)
FloridaEd is offline
Old 07-03-2007, 03:30 PM   #4 (permalink)
I have a 5th wheel that had Carlisle 225/75/15 "SPORT TRAIL" tires on it, I had one blow. I called Carlisle Warrenty line and they essentially sent me 7 new tires, basically no questions asked. Unfortunately the ones I had were made in the states and the new ones were made in China. We will see what happens. It is also a 2007 so I think that there warrenty states they will cover the mounting and balancing for the first year. I just can't remember where I saw it.
first_ford is offline
Old 07-03-2007, 07:21 PM   #5 (permalink)
busbreath's Avatar
Good luck with the Carlisles! I have my spare mounted now as one blew up and trashed up the side of my trailer. It only went from my home to storage - about 10 miles. It blew up while covered and parked in storage. There is a hole you can put your fist thru across the tread. Denmans on the way! No more Carlisles - no way no how - not even as a spare!
Enjoy!
Doug
97 F-250 extra cab 2WD. K&N FIPK, 410 gears, Pace Edwards roll-top bed cover, Reese 16K 5th wheel hitch, defender trans cooler, 81K orig! New to me 10/2003. Pyrometer and trans temp pillar, boost gauge, SCMT, exhaust brake & t/c lockup, Hypermax downpipe/tymar out 4", ATS Intercooler (Thanks CaryT)
Mother is the Necessity of Invention!
busbreath is offline
Old 07-04-2007, 03:38 AM   #6 (permalink)
Bill1013's Avatar
I would'nt have a Carlisle anywhere near my trailers. Bought a 6 X 12 cargo trailer with them on, got 85 miles to the 1st blow out, then 125 to the second one, then 5200 to the 3rd. LOL Trailer was loaded way under capacity.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB dually Banks turbo US Gear O/U ENGINE IS SHOT !
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors Beru GP's New radiator & hoses New WP
Dual Exhaust 3"X18" resonators
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Toys: 1984 Coachmen Leprechaun F350 Chassis 460CID 92K miles.
30 ft. Jayco Jay Designer 5th wheel.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is offline
Old 07-04-2007, 03:57 AM   #7 (permalink)
Wish I would have known you alls troubles before now.... I 'll update post after I call on the 5th and raise heck. Gonna call the installer in VA to let him know in case he wants to try and make it right first.......
Game on...lol
bbess00 is offline
Old 07-05-2007, 03:50 PM   #8 (permalink)
Re: Carlisle Trailer Tire Concerns **UPDATED** Happy Camper
Well I can't gripe or complain as of now... Just called Carlisle customer service and they are sending me 4 replacement RADIAL trailer tires. Then will also reimburse me for the mounting and balancing. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Normally you have to take them in for dealer verification, but no dealers here in AK I guess, so they are sending tires right to my door! [img]/ubbthreads/images/graemlins/cool.gif[/img]
bbess00 is offline
Old 07-14-2007, 04:46 AM   #9 (permalink)
Well they did it, I got my new tires today. D rated radials. I think the ply is lower, but no long trips planned for me so I am satisfied!!!!
bbess00 is offline
Old 07-19-2007, 01:15 AM   #10 (permalink)
Should known I coulda looked here for info when my 2 tires busted. My 5er had 225/15 D tires fairly new and had about 1000 miles when the 2 rears blew, 1 about a month after the other. They made the 2 good with warranty from discount but also had them upgrade to E and pro rate the 2 front. This was back in Nov of 06. Maybe I should try going back and have'em swap for Denman?
2001 F350 7.3 6spd 4x4CC LWB Lariat ALL Stock!
bullwinkl is offline
Old 07-19-2007, 08:21 AM   #11 (permalink)
88beast's Avatar
yes swap away if there the china ones i wouldnt even use the trailer till i got another tire on them
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 07-19-2007, 11:04 AM   #12 (permalink)
I have been well known information in the RV world for a number of years that these tires are NOT the best.
2003, F250, Super Duty, Super Cab, 7.3, Auto, 4X4 Silver, 2" lift in front only, 46 gal fuel tank, Billet Grill, 285X75X16 BFG MT, Bilsteins, Firestone Air Rear, B&W Gooseneck, We call it the "Silver Knocker"
reba is offline
Old 07-19-2007, 11:19 AM   #13 (permalink)
I'm glad they took care of you, and you are happy. I have gone thru 2 sets of Carlisle tires on my Toy Hauler. Neither set had more than a
couple thousand miles on them before they blew out. I would suggest taking the new replacements and try to sell them at a discounted price, use the money to off set the cost of some better tires. I also have had Titan load range E trailer tires that were not any better. As suggested above look at RV.NET and see the tire reviews there. I finally went to a Toyo load range E this summer, not enough miles as of yet to tell if it was a good move or not.
Good luck either way!
mbcolorado is offline
Old 07-19-2007, 01:02 PM   #14 (permalink)
I went with Tow Master tires.
They have been used on the trailers from the factory that the ysell to haul Bobcats and tractors.
Had lots of experience with them doing that, so I put em on the Travel Trailer. Getting ready to head out for a 2,500 mile run so well see how they.
Mine are 14" so a ***** to find.
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 07-20-2007, 12:56 PM   #15 (permalink)
That's a nice thing of them to do.
With that said..........I will NEVER, NEVER, NEVER run that brand of tire again!!!!!!!!!!
I ran them for 4 years on a 6x10 trailer that ran at MOST 1/2 payload.
Went through 8 sets of tires in that time period (2 runners and 2 spares comes up to 32 tires total).
Thought it was an axle issue or inflation issue or possibly heat related (I drive through deserts frequently). One of my friends and I were discussing a shredded tire mounted on my spare rack and he simply said "Carlisle brand.......right?" (we were not close enough to it to see the brand name). Found out quite a few friends of mine had been having the same issue as me. Went to store after that trip was over (and........seriously.......2 more tires gone) and purchased a different brand for all four wheels (2 runners and 2 spares). Went 3 more years on that set of tires with one blown tire.
Might be wise to "bite the bullet" and change to a reputable brand of tire before you become stuck in the middle of nowhere on a couple of bad tires (worth the expense to me for piece of mind anyway).
Good luck with it and safe travels. [img]/ubbthreads/images/graemlins/smile.gif[/img]
99 7.3L PS E-350XLSD with Ambulatory roof.
(((XM))) Satellite Radio
4" turbo back Diamond Eye exhaust (portadiesel)
Pair of K&N High flow filters
HPX Hose from D.I. (blew out.....pulled it and plugged now)
In-tank and prepump mods (homemade version)
203* thermostat (dieselsite)
Tru-Cool 4739 MAX Transmission cooler (dieselsite)
Boost Relief Valve (dieselsite)
Pillar mount Di-Pricol gauge set
Sonax/tricumulator (Black Cloud)
Jody flashed econo tune PCM (DP-Tuner)
Van specific regulated fuel return (ITP)
70k miles driven annually...mostly pulling 8 1/2 foot tall 7x14 enclosed trailer
Cruise on at 61mph and 1736rpm's I don't stop 'till she needs more go juice!
stroked_van is offline
