Change a pintle eye to a receiver that takes a ball? - Diesel Forum - TheDieselStop.com
Old 05-10-2009, 10:13 AM   #1 (permalink)
Hey Guys, I have a trailer that has a pintle eye setup. I am trying to see if I can take that off and mount something so I can use a standard ball receiver set up. Does any thing like this exist?
Thanks!!
Bltfordtough is offline
Old 05-10-2009, 11:23 AM   #2 (permalink)
chuckster57's Avatar
I know they make replacement ball hitches for the trailer side. I used to have a boat that the trailer side of the hitch twisted and I just replaced the whole assembly. I would think it would depend on how the frame of the trailer is shaped. Mine was a V so it was an easy find.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 05-10-2009, 01:30 PM   #3 (permalink)
burnetma's Avatar
I bought one from eTrailer that was a four bolt.
2008 F350 FX4 Crew, 4x4, 6.4L, Torqueshift, 4.30, tow command, leather, power everything. 75k+ miles. Built 4/17/2007 (Job 1), Purchased used 3/16/2009
2010 Mustang GT Premium - 4.6L-3V, 5 Speed, Grabber Blue - Now this is FUN!
1997 F250 EXT Cab, 4x4, E4OD, 4.10, 273k+ miles.
Modifications: Pyro & boost guage, 202 T-stat, transmission cooler & Tymar - SOLD!!!!!!!
2004 John Deere 5420 MFWD Utility Tractor with 541 MSL Loader.
burnetma is offline
Old 05-10-2009, 07:50 PM   #4 (permalink)
Thanks!!
Etrailer.com had just what i was looking for which other sites did not have.
Trailer Coupler 2-5/16" Adjustable (15,000 lbs.) 80281 : Trailer hitch bike rack and trailer hitches - etrailer.com
Ryan
2002 F-250 DIT Standard Cab Auto
1994.5 F-350 DIT Crew Cab 5-Speed
Old 05-11-2009, 06:40 AM   #5 (permalink)
burnetma's Avatar
Good deal! Glad I could help.
I converted from pintle to ball so I could add weight distribution and sway control. Is that your intention also? It is a noble quest. My trailer was very unruly with the pintle hitch, but got manners with the WD and sway control.
burnetma is offline
Old 05-11-2009, 09:25 AM   #6 (permalink)
You know I was thinking about getting sway control but to be honest I have not heard of weight distribution. I would guess it does what the name says but im not sure how it works.
Ryan
Old 05-11-2009, 09:13 PM   #7 (permalink)
Weight Distribution Trailer hitch bike rack and trailer hitches - etrailer.com
Great info. WD is essential in towing anything over 5000lbs. Check out your hitch, it will amaze you how low the rating is on your hitch w/o WD.
sinner in need of The Savior.
2001 F250 Extended Cab 7.3L Superchips. Air Raid Intake. DieselSite 203* T-stat. DieselSite AIH Delete. Dieselsite Valley Boots, DieselSite Turbo Master, Tekonsha Prodigy. B&W Turnover Gooseneck.
WVO conversion, installed and then removed.
Wife's= 2002 VW Jetta TDI. Coolant Heater.
YergInGA is offline
