Old 03-01-2007, 07:44 AM   #1 (permalink)
Charging Batteries on 2007 Cimarron Trailer
Should the factory installed RV plug on the truck in my sig--charge the batteries (not the emergency brack battery) on my new 2007 Cimarron Horse trailer with Living Quarter--that has a 12 volt system to run lights in the LQ area and the load lights?
03' 7.3L 4X4 Crew Cab F-350, SRW, Lariat, Automatic, Fumoto, Ford AIS, Front Grilleguard, Rhino Liner, Sirius Sat Radio
07' Aluminum Cimarron 3 horse Gooseneck with 10 ft Short Wall LQ--Double Duty Conversion
03' Chevy 2500 HD 6.0l Ex Cab, Sirius Sat Radio--236,000 miles and counting
russm1208 is offline
Old 03-01-2007, 09:11 AM   #2 (permalink)
G BURDICK's Avatar
Re: Charging Batteries on 2007 Cimarron Trailer
Yes it should providing that you are not using more amps than what the truck can put out.I don't know what the amp output is,but I believe it is protected by a 30 amp fuse.
example output 10 amps and draw 12 amps
2001 F350,XLT,CC,4x4,PSD,6-SPD,SRW,156"WB,OFF-ROAD,LS,PTTTM,AIC,HAYES GENESIS BRAKE CONTROLLER,BILSTEIN SHOCKS,BRIDGESTONE DUELER A/T REVOS,POWERSLOT ROTORS AND HAWK LTS PADS,PML REAR DIFF COVER,RHINO LINING,GARMIN STREETPILOT 2720,SIRIUS RADIO,TRUE BLUE
2006 F350,XLT,SC,4x4,6.0L,TORQSHIFT,SRW,142"WB,FX4,LS,E SOF,TOW
COMMAND,UPFITTERS,LINE-X,WEATHERTECH MATS,GARMIN GPS V,DARK GREEN SATIN W/SILVER
G BURDICK is offline
Old 03-04-2007, 03:23 AM   #3 (permalink)
I dont know if your truck is connected to the trailer all the time (most are)meaning that the 12v charge is just straight to the battery, hence if you run down your trailer battery while still plugged in you run down your truck too, i installed a solenoid relay on the line from my battery and connected it so that the relay is on (and charging the trailer) only when the ignition is on, easy to do and saves a dead battery at a campsite
Learned that one the hard way...
1995 F-350 Powerstroke 7.3 300000 miles
neepsjeeps is offline
Old 03-04-2007, 10:45 AM   #4 (permalink)
Thanks for the tip--but since this is a horse trailer with a LQ--when we camp, the truck will be unhooked...Thanks though
Old 03-09-2007, 08:03 PM   #5 (permalink)
The battery terminal through the plug is dead when the key is off.
I have found battery life is pretty poor with that set-up, the battery gets charged during the drive all the time. Whether or not the voltage reg senses that I don't know, but I've gotten much better battery life by charging with a charger/convertor and not via the truck.
'96 Red & White F250 XLT 4x4 PSD 4R100, a 4R100[/i] SC LB 4.10, Banks Stinger, BD Torque Convertor, Isspro Pyro & trans guages, 230k
'01 F250 4x4 Crew Shorty, DPPI 4" SSTL Exhaust, DP Tuner 80hp tow, Monster Box, Firestone Ride-Rights, Regulated fuel return and Cooper ATR's
3h Featherlite GN with Tennesse Walkers inside. Wyndancer Gordon Setters
Dan V is offline
