Hi,
I'm getting ready to install a 10,000lb winch w/battery on my flatbed gooseneck, and was wondering where I might find a schematic to set this up to charge from my trailer wiring without drawing on the truck batteries while using the winch. Anybody know of a good source/design?
Thanks,
[img]/ubbthreads/images/graemlins/shrug.gif[/img]Tom in MO
OK, after reading some of the other recent posts, I'm getting the impression that all I have to do is hook the positive side of my trailer battery to the center of my trailer plug and all is well as long as I don't use the winch with the ignition on? Any recommendations? Thanks!
Tom in MO
Black 1999.5 F250SD XLT AUTO 4x4 reg. cab(6/99), Pre-pump & Tank Mods, AFE Intake, Racor Filter/Separator, HX Mod, ZooDad, WW, Power-pedal Mod, Pop-up gooseneck ball,Brush Guard, 3.5" lift, BFG Commercial AT tires (265/75), 65hp ATS chip, and #2 cologne. Ball joints replaced, and thinking about a BTM and shocks....!
i don't think its the center pin.....google wire dagram for a 7 wire trailer plug....usually the center one is for back up lights
1997 f-350 4X2 7.3 PSD E4OD AUTO 4.10 Rear CC Dually Run Rotella Synthetic Oil, 150,000 +/- Miles...Came with a Superchips 1705 programmer....Things I've had to do ....Left Front Ball Joints, Air and Fuel Filters, Rear Fuel Tank, CPS, MAP, Cleaned EBP Tube and Sensor Replaced FPR Screen New 3" Downpipe and 4" Exhaust. Shimmed FPR Modified Air Box, Trans Temp Gauge, Boost Gauge, 8 New Glow Plugs. Not Sure What Else Yet...Any Ideas???
2004 Jayco Jayflight 26.5 5th Wheel (Truck pulls it like its not even there)
I would say so from that link but i've never used a 6 pin set-up
You may not be happy with how little current the trailer charge line puts back into your winch battery.
I power my TT from an inverter in my camper. With the regular charge line, it would take driving all day [img]/ubbthreads/images/graemlins/shocked.gif[/img] to recover the two Trojan T-105 house batteries (read "winch battery") from a discharge to 11 volts. The charge line supplies less than 10 amps, IIRC.
I changed to an Avalanche Diode battery isolator <font color="blue"> (For Example) </font>, and now at 11 volts, I get 80 amps (limited by the wire size as recommended by HT) to the house battery when it's down to 11 volts.
Try the trailer charge line first to see how you like it, but do look at the Hellroaring web site. There are other avalanche diode isolators. I liked all the tech stuff on the HT website. (I use the <font color="red"> RV Starting Battery Isolation </font> configuration.)
I've done it direct [img]/ubbthreads/images/graemlins/frown.gif[/img], with conventional diode isolator [img]/ubbthreads/images/graemlins/bleh.gif[/img], and with avalanche diode isolator [img]/ubbthreads/images/graemlins/smokin.gif[/img]. Avalanche is the best of those choices, hands down.
There's a pic in my mod photos in sig.
Let us know how you make out.
Art
2000 F350 7.3 PSD 4x4 six-pack dually. All Stock.
Ride Rites with "Big Red" on-board Compressor.
DynaTrac Free-Spin conversion.
Hellroaring Battery Isolator for house batteries.
Flex-A-Lite 900 CFM tranny cooler (for those special 100 Deg./5 MPH-traffic
Florida days) with Magnefine filter.
FleetGuard coolant filter. Mod Photos AE Plots
Sun-Lite slide-in camper Plus 31-foot Holiday Rambler TT.
The standard trailer tow package supplies up to 30 amps thru the charge circuit provided you have the TT relays and fuses installed, when ever the truck is running.
2001 F-250 (pcm PMT2) ISS Pro EV tranny, boost, pyro gauges. TS Performance flip chip. Banks MONSTER exhaust, Maghytec rear diff cover, ITP H/X kit, Whelan 52" Strobe Bar, Fisher 8.5' Snow Plow, 3 Weatherguard tool boxes. HUTCH fuel tank mods, REMANFACTURED Ford transmission.
Sorry I took so long to get back to the thread, [img]/ubbthreads/images/graemlins/blush.gif[/img], I'm on the road.
I think the stock charge line only provides the max current when the engine battery is calling for high charge. Apparently when the engine battery is charged, the excitation to the alternator drops off, and the trailer current goes down.
I've done it both ways with the exact same (Trojan T-605) batteries. When discharged to 11 volts, I drove all day and the trailer (camper, in this case) batteries never got much above 12 volts with the engine running. Not good, because it was cold and I couldn't use the furnace after the first night.
When I put in the avalanche-diode isolator (configured with the alternator going to the camper batteries first--see This), the camper batteries charged at 80 amps until they reached the switching voltage for the isolator (13.4 VDC is the standard setting, but you can specify an external sense resistor and set it where you want it). See This, scroll down to the BIC 75150 features.
At the switch point the engine and camper batteries are connected together by the diodes. The voltage drop to the engine battery is only a few millivolts--much less than simple diode-isolator circuits.
I stress that it was the same truck, alternator, engine batteries, and camper batteries in both cases. I should also point out that there are other good suppliers of avalanche-diode isolators, as well as one that was sorta snotty when I talked to them. [img]/ubbthreads/images/graemlins/vomit.gif[/img]
My 2 cents.
Art
