I have an '08 F-450 4x4 KR w/ 4.88s. I tow a 13K boat/trailer regularly. First question - the tow hitch under the bumper has a sticker saying it's a class V hitch. And, the sticker also gives max towing weights, one is 16K with a WD hitch, and the other is 8K with a WC hitch. I'm assuming the hitch on the truck is a WC hitch, but why does the sticker list both types of hitches instead of just the one that's on it? And, based on the weight of my boat/trailer, I'm assuming I should be using a weight-distributing hitch. Where are you guys getting your WD hitches from? There are many out there, just dont' know what to look for... Or am I the only one using an F-450 for conventional towing? Thanks!
The reciever that's on the truck can be weight carrying or weight distributing depending on what hitch you insert into the reciever. It will accept either type of hitch.
The weight of the boat and trailer isn't that relevant to needing a weight distributing hitch. The tongue weight is what matters.
__________________ Mark Former Automatic Transmission Engineer 1988-2007
A former co-worker worked for Reese as an internship in college. He told me that Reese, Drawtite, HiddenHitch and one other have been acquired by a single company, but retain the different labels. IE: Same metal, same process, same people, same paint, different label. Some things are only available under one name, some under another, but they all come from the same people.
'96 F250 XLT, PSD, 4x4, ExtCab, LB, Auto, 3.55.
11-06: DIY Open Element, EBPV & TC exhaust brake.
02-07: 40 gal '05 F550 aft-axle tank = ~60 gal total.
03-07BTS downpipe & 6pos chip.
04-07: ]226,000mi 277HP, 543TQ, Graph
05-07: EGT, Boost, Trans from Tymar
06-07: 4" exhaust, 31 row 6.0L trans cooler
08-07: BTS Transmission.[/url]
09-07: 80.76 @ 16.527
Do you live any place close to Chicago ... northern Illinois?
There is a trailer place there that has a 3D shop as well as one on Ebay. Hitches that regularly sell 3D/Retail for $350.00 selling for $175.00.
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
>202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203º T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
I ordered my weight distributing hitch from napa a while ago. Works good.
1996 F-350 7.3 2WD Crew Cab Dually. 128,xxx miles, 2nd owner, PO was Lead Diesel Tech @ a ford dealer with flawless maintainence records.
K&N FIPK2 Cold Air Intake - Now with Napa Paper Filter, no more sandblasting my turbo wheel!
Diesel Turbo Lifesaver
Brite Box
4" MBRP with Missing kitty, no muff and 3" downpipe
Upcoming:
EGT, Boost, Trans Temp Gauges
99-03 intercooler *acquired*
with GTS or banks install kit
CCV Mod
EBPV into DIY Jake Brake
Custom Chip
D66
Built Trans
I would get one that would allow the instal of the reese dual cam sway control if needed.
Camping World seems a good spot for these, and they are all over, and ship if you order on line.
