Old 12-14-2005, 06:40 AM   #1 (permalink)
DZLJIM's Avatar
Disadvantages with using a Pintle hook trailer.
I have the chance to get a very nice box trailer, but it has the Pintle hook on it, not a ball hitch. I've towed equipment trailers in the past with Pintle hooks and never had a problem, really. Just wondering on a trailer that might be used for long hauls, would the Pintle hook be OK, or should I consider a 2 5/16 ball hitch?
Thanks.
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB
DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
DZLJIM is offline
Old 12-14-2005, 01:18 PM   #2 (permalink)
Re: Disadvantages with using a Pintle hook trailer.
The disadvantage I can think of is stopping and taking off. You get a nice heavy trailer hammering on your rear end when you goto stop. Then you take off and it slams again. Though I've only towed a pintel once, but thats what I noted; the extra wear and tear.
2005 Excursion Limited; build date 09/04. MBRP T-304 Turbo Back Exhaust. Sickening monthly payment.
rcdallas is offline
Old 12-14-2005, 04:15 PM   #3 (permalink)
SteveRacer's Avatar
Location: Rockland Co. NY KC2JLJ on 147.165 MHz Design Engineering Machine Shop Owner
I can't stand the banging. I'm such a nut about it that every one of my ball mounts I added that threaded insert and the threaded pinbolt that locks the ball mount to one side of the receiver tube. If I had to suffer a pintle hook trailer, I'd probably machine a teflon or delrin sleeve to try and take up any slack.
On the 5er I put really heavy grease on the pin. I need to get one of those teflon slip plates to see if that helps as well.
-steve
SteveRacer is offline
Old 12-14-2005, 07:41 PM   #4 (permalink)
Hi Jim,
If you use the pintel with surge brakes then you will have a maximum 2000lbs of tongue weight as that's common rating for surge brake couplers.
I used a 40ton pintel coupler off a semi that uses a air operated luna eye shoe to keep the slop out of the hitching. I just made a mechanical linkage to replace the air shoe and I get a very quite ride.
I like my GN dual tandum 100% more than my tri-axle pintel tho as there's just no comparrision between the two types of hitching. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run
Define Union:
A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
T_Bone is offline
Old 12-14-2005, 07:57 PM   #5 (permalink)
The Pintle hitch was developed for off-road articulation more so than for highway use; such as crossing ravines and cresting rises that would twist a normal ball or clevis hitch off the frame.
This is why most military trailers employ them.
They would not be my choice for highway use.
1985 F-350, 6.9 4spd, Hypermax, 3.55 rears
BullHauler is offline
Old 12-14-2005, 10:17 PM   #6 (permalink)
Location: park hill, ok usa/us army who knows where tomorrow or today?
ins companys consider a pintle safer than goose and charge less
also you can have a straight(stake bed) truck for cheaper ins than a tractor with same gvw.
i have a 55,999 gvw truck and trailer for very little more than 1 ton [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
BOOB man - Brotherhood of Oil Burners RWoodys Pics
2001 f-350 4 dr short bed loaded PSD 504,000 miles
rwoody is offline
Old 12-15-2005, 08:35 AM   #7 (permalink)
My trailer is a pintle for easy of hookup and drop off (no binding) untill I go on a long trip then I change to the 2 5/16 ball the trailer "behaves" better with the ball hitch.
01 250 PSD SC 6sp camper pkg -5.6k to 25k pot- AIS- Reese Titan - SC max tuner- Rhino lined-
73 Pinzgauer
78 toylet (chevota) cruiser 12 years of mods
05 disco (wifes car)
Overload is offline
Old 12-15-2005, 11:09 AM   #8 (permalink)
Believer45's Avatar
My Photos: (17)
Having towed with both I will say the pintle hook / lunette eye is easier to hook up, can usually carry AND tow more weight (provided the truck and such are up to the task), as mentioned above handles articulation better and is considered safer in most applications.
On the down side they do hammer a bit. If your prospective trailer lunette eye is bolted on (as many are) you can get a bolt-on 2 5/16 hitch ball that will go into the same track like <font color="blue">THIS ONE</font>
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
Believer45 is offline
Old 12-15-2005, 05:40 PM   #9 (permalink)
My 5 ton Hudson came with a lunette which I promptly changed to a ball. couldn't stand the noise, etc.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford06 is offline
Old 12-15-2005, 07:55 PM   #10 (permalink)
Super Duty John's Avatar
My Photos: (55)
I've towed my 14,000# equipment trailer for a while with a pintle hook, as stated above, it'll drive you crazy with the bang and slam that it does. It can't be good for any transmission. I switched it out pronto!
John
2008 Job 2 F-350 4x4 Crew Cab SWB dually
Lariat with the chrome package.
Super Duty John is offline
Old 12-16-2005, 06:58 AM   #11 (permalink)
DZLJIM's Avatar
Holy Cow!
Thanks for all the great info.
[img]/ubbthreads/images/graemlins/cool.gif[/img]
DZLJIM is offline
Old 12-16-2005, 09:46 AM   #12 (permalink)
I use a pintle type hitch for my hay/equipment trailer and it is VERY noisy when empty, once I get a load on it with sufficient tongue weight the noise goes away and life is good. If you pull empty a lot, it may not be the best choice. It rattles bad enough empty to wear through the hinge pin in the top part of the pintle, last time I arrived in Yakima the trailer was just sitting on the hook part and the top was GONE [img]/ubbthreads/images/graemlins/shocked.gif[/img]
2004 F350 Lariat CC LB FX4 Auto, camper package, superhitch, rear susp air bags, Rancho 9000 shocks, 800W/1600W 115v power converter, Ultralite gauges in overhead 4 gauge pod, 04/04 build and engine Reman shortblock at 34,000 Due to oil leaks, MBRP turbo back, SCT extreme street by ID
10.5' camper, 20.5" Bayliner Cuddy 5.0 V8
1999 Kawasaki ZRX1100
rubystargoats is offline
Old 12-17-2005, 08:43 AM   #13 (permalink)
Our equipment has nothing but pintles. So does my car trailer. I use the combo ball/pintle hitches on our trucks. They have a "pocket" the eye drops into, much quieter then a standard hitch. Another good option is getting a Hammerlock combo hitch. That design locks the eye in place, reduces the rattle to almost nothing. I sell those to my customers everyday, they love em....
Scott
99 F250/PSD/SC/6Spd/chipped/K&N Lovin life
2004 F250/6.0/CC/Auto... Not exactly loving life anymore, gave back to momma ford..
2005 F350SRW/6.0/CC/Auto/FX4... OOPS, I left it on his lot. NO tolerance for stealers that try and screw me..
06 F350SRW/6.0/Auto.CC/LWB/4x4 ordered 5/4/05.. VIN recieved 5/17/05. Truck on the dealers floor 6/15/05
5/18/07 49k FLAWLESS miles.. I love this truck [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
11/17/07: 59k miles: EGR hiccup.. Still love this truck [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Scott B is offline
Old 12-17-2005, 08:26 PM   #14 (permalink)
I pull a 12k dump trailer, a 12k equipment trailer and a 6.5k chipper and all three have pintle hitches. I've made out fine with them. I've never thought much about the banging and just accepted it as the cost of doing business.
1987 Ford F-350 FWD 4spd. 6.9L International Chipper Dump w/tool boxes for Arboricultural work.
1983 Ford F600 Allison 545 Auto 8.3L Detroit Diesel w/15ft. Chipper Dump.
1985 International S1900 DT466 5spd 2spd rear
1996 Dodge 3/4 Ton 4WD extended cab 5.9L Cummins Auto Trans.
Two stump grinders with 58/75hp. Duetz diesels.
Bandit chipper w/116hp. Cummins 4BTA diesel.
Bobcat 7753 with 46hp Kubota
DanNelson is offline
Old 12-18-2005, 08:06 PM   #15 (permalink)
We got a tri-axle pintle in exchange for $200 worth of straw. First thing we did was change to a ball hitch.
Pintles beat the heck out of the tow vehicle IMO.
-Dan.
2005 F-350, Lariat, PSD, 4x4, Crew-cab/shortbed, Escort Passport 8500, straight factory exhaust, Diprocol guages in overhead pod from dieselmanor.com, SCT from ID Econ/Tow/Xtreme Race.
*TOTALED*
Early '99 F-350, PSD, Lariat, 4x4, ext. cab, long bed, Tymar, Donahoe 2", 33" Goodyear AT/S, Bilsteins, Cobra Classic 29, Wilson 5000, Garmin GPS, Edge EVO set on Race, Pioneer H/U, Boston Acoustic speakers, (2) JL Audio 10"s,
1987 F-250
1987 Jeep Wrangler
DEERSNIPER is offline
