On the livestock, horse, and equipment trailers I have the ground from electrical cords are all tied to trailer chassis and the grounds from brake circuit twin lead is also connected to chassis for grounding.
From my perspective brakes grounded through chassis have two chances to be grounded (wire in plug plus chassis through ball coupling) and ones isolated and only grounded through the plug have only one chance. Two chances sounds more safe to me.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
It sounds like I will need to install a new controller on a separate line and mount it in the bed of the truck. Since I have a 2008 F350 does anyone know if I can just unplug the factory brake controller and plug in a controller that will work with disk brakes?
Don
I am in the process of buying a new fifth wheel from Hitchhiker and wanted to add the disc brake option. Got a email back from HH yesterday and they told me that went to their local Ford dealer and borrowed a Ford F450 with the IBC. They use both Dexter disc brakes and Kodiak disc brakes. The Kodiak disc brakes worked fine but the Dexter disc brakes did not work. So it gets down to which brakes system you are using.
Don
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Donr827</div><div class="ubbcode-body">I am in the process of buying a new fifth wheel from Hitchhiker and wanted to add the disc brake option. Got a email back from HH yesterday and they told me that went to their local Ford dealer and borrowed a Ford F450 with the IBC. They use both Dexter disc brakes and Kodiak disc brakes. The Kodiak disc brakes worked fine but the Dexter disc brakes did not work. So it gets down to which brakes system you are using.
Don </div></div>
Don, did they tell you how to determine which ones your trailer would come with? David
2009 F450 Pickup Lariat Plus w/Nav, 4X4 Off-Road Pkg, Rhino bed liner, 50 gal Transfer Flow fuel tank, 24k Reese Signature Series 5th-wheel hitch.
2011 MS 36RSSB3
The last disc brake trailer we built had Dexter 12 elec over hyd disc brakes,I believe the Carslile booster is compatable with for factory controllers, that is what we used and my truck ('05 F 250) operated the trailer perfectly. I have the factory Brake system. Unfortunatly I don't know about the new '08 models.
Carlisle controller is not compatible with Ford 2008 ITBC. I've contacted Ford and Carlisle with no success in finding a solution to intermittent "Trailer Disconnect" error on Ford DIC.
__________________ 2008 F450 Lariat Crew Cab 4x4
Shadow Grey w/Black Accent, Medium Stone Interior
TorqShift, 4.30 Gears
Job1 14,500 GVWR - 29,000 GCWR
Reese Signature 24K, Line-X, Trucks USA Roll Cover, Leer 100XQ Topper 2007 DoubleTree 36TK3 Mobile Suite
18.5k GVWR 2007 Mirage Enclosed Cargo Trailer
7.0k GVWR
David, sorry for not replying earlier to your question. You can email Nu-WA Hitchhiker and give them the model of the trailer you want to order and they can tell you which disc brake system come with it. You might be able to request the Kodiak system. I saw a thread yesterday where Dexter claims that their disc brakes are now compatible with the Ford IBC.
Don
Good afternoon MY NEW FRIENDS as you can see I an brand new to this site and have been reading your posts on elect/hyd brake systems, I have just purchased a 2009 f550 4x4 supper duty, it did not come with fords IBC ,I have bought the ford IBC parts to be put on tomorrow at a ford dealer. I have a 2007 32ft tandem goose neck that I will be hulling 20,000 lbs honey bees from northern new York to south Carolina the trailer has dexter hyd disc brakes HELP!!! is there a marriage ????
I have a 2007 32ft tandem goose neck that ... has dexter hyd disc brakes HELP!!! is there a marriage ????
Maybe, maybe not. Ford does not say the Ford integrated brake controller (IBC) will work correctly with electric over hydrailic brakes.
If it were me, I'd not install the IBC and instead find a controller that Dexter guarantees will work with your electric over hydraulic brakes.The $500 BrakeSmart controller will work with your electric over hydraulic brakes. Dr. Performance - BrakeSmart
Originally Posted by BrakeSmart FAQ
BrakeSmart® - FAQ
Will the BrakeSmart work with my trailer?
The BrakeSmart is compatible with any trailer that has electric brakes. In addition, it is one of the only controllers that will work with electric/hydraulic brake actuators. It will work with any trailer out there, from one axle to four and even more with reprogramming. ...
Reason: add BrakeSmart
The last communication I read was Ford does work but they hadnt tested and/or did not want the liability at that time. Almost all current modern controllers will work with the Brake Actuators - providing a PWM (pulse width modulation) output. The only one Ive heard that didnt was GM (might be a specific year) - I dont know why.
went ahead and had all the parts for the ( IBC ) I had purched for my 2009 f550 4x4, The dealer had quite a time getting there computer to talk to mine in the truck and had to call tech support , so between all the grate minds the marriage was made and consummated. I pulled my first load of honey bees and had around 18000 lbs , between the auto down shift and the new (IBC) wow how SWEET IT IS!!!!
