Old 06-21-2006, 08:54 PM   #1 (permalink)
My Photos: (28)
Do I even need airbags?? (semi long)
I am buying a new 5ver, Dry pin weight is 2273, empty weight is 12840, gross 15,500. Would airbags be needed?
We are buying it to use occasionally, and live in for 6 months to a year while we build our retirement home, and then have an RV after our house is done. We will probably drive 2500 miles or less per year on it, and that might be a very high estimate.
I know I have put 3000 pounds worth of concrete in the bed before and it just brought the truck down to a level stance. But airbags would provide stability correct? I know it wont squat my truck down, I am just looking for the best stable platform in the truck I have.
I know, I know, get a dually. That will probably be next. Right now I have to dance with the one I brang.
So anyway, Airbags before I pick up the trailer and drive it home (1000 miles) or can they wait?
2007 GMC 3500 4x4 Dually Duramax/Allison
Sold F350 6.0L TS SRW SWB 4x4 King Ranch FX4 Loaded 409SS MBRP Cool-Duals Isspro Pyro
2005 VW Passat TDI Wagon
2006 VW Jetta TDI
My Truck
My 67 RS/SS Camaro
My Day Job
Armypilot is offline
Old 06-21-2006, 09:11 PM   #2 (permalink)
Re: Do I even need airbags?? (semi long)
Do you NEED them.....probably not (probably get away without them).
Are they super nice.....yes.
I just put airbags on mine and we used them with the TT last weekend. The truck is night-and-day better with the bags while traveling down the road. For $250 you can have a set on there, I highly recommend them and wish I'd had done it long ago.
05 F-350, PSD, 4x4, Crew Cab,6-Speed
2" Front Level Kit, Pro Comp ES9000 Shocks
Firestone Model 2400 Airbags (horrid engineering)
Tow 30' Toyhauler
*-Friends don't let Friends run Crap-lisle Trailer Tires
Rich807 is offline
Old 06-21-2006, 09:25 PM   #3 (permalink)
My Photos: (28)
Thanks Rich, I just needed to hear it from someone else to confirm my thoughts.
2006 VW Jetta TDI
My Truck
My 67 RS/SS Camaro
My Day Job
Old 06-21-2006, 09:28 PM   #4 (permalink)
No problem, just would've saved me a mouse click or 2. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Tow 30' Toyhauler
Rich807 is offline
Old 06-22-2006, 12:57 AM   #5 (permalink)
I love my airbags. We often take extra potable water and firewood in the back of the truck and its nice to air it up a little to get a level stance. Based on the weights you gave (dry and gross) I would suspect your actual pin weight will be a few hundred pounds heavier than advertised by the maker. We have an '02 Hol.Ramb. 30 RLD which is actually 32'6" w/2 slides. It has a GVWR of 12,000 lbs. and a typical road weight in the mid to upper 11's depending on how much of the kids' junk were packing. We also have a genset in the basement. My actual pin weight runs about 2350 lbs. P.S. -- I think your avitar is hilarious, Which probably doesn't reflect very well on me but, oh well! Perry.
2006 F-250 4X4 Lariat, C.C. / SWB -- Torreador red
PerryB is offline
Old 06-22-2006, 10:08 AM   #6 (permalink)
I got air bags on my 3/4 but that was to take the squat out of it when loaded.
They will stiffen up your ride when unloaded. Look at it this way. Most people say you let the air down to 5 psi and there ain't no difference. Well would you venture to put your toe under and air bag and then have someone put 5 psi of air in it?
My 3/4 rode like a log wagon empty before the air bags and now it rides like a big log wagon [img]/ubbthreads/images/graemlins/shrug.gif[/img] I didn't really expect anything different.
And i did mount the bags exactly as per the instructions.
HenryE is offline
Old 06-23-2006, 07:47 PM   #7 (permalink)
I pull a 33' 5er toy hauler. I could REALLY tell the difference after I had the air bags put in. I'm very happy with them. I pulled the trailer for a year without them with no problems, but the air bags took alot (if not all) of the bounce out.
Brian
2000 PSD Lariat 4x4 SC,, 111k miles, AFE pg7 stage II w/outerwear, ATS turbo housing, Wicked Wheel, gutted EBV, Banks BHA, 4" turbo back exhaust Aeroturbine , A-pillar gauges, Swepco in the tranny, BD torque lock, FTVB, 203* T-stat & billet housing, DP Tuner Tuning (4 pos; stock, econo, tow, perf), AIH plug, Powerslot Rotors & Hawk pads, Ride Rite air bags, PML rear diff cover, Filters: Dahl fuel, Dieselsite tranny & coolant, Amsoil dual remote oil. Rancho 9000's w/in cab controller(that needs install) on board air & horns,, done!!
I believe in Santa!! He drives a Big Brown Truck and wears a Brown shirt and hat!!!
All this to tow the 33' toy hauler loaded with fun!!!
dunesday is offline
Old 06-24-2006, 02:11 PM   #8 (permalink)
My Photos: (28)
Well I just installed the airbags this morning. Ride Rite kit #2400 inboards went smooth. About 1 1/2 hours.
Thanks for the input.
2006 VW Jetta TDI
My Truck
My 67 RS/SS Camaro
My Day Job
Old 06-24-2006, 05:45 PM   #9 (permalink)
My Photos: (11)
When I dont have a trailer behind my truck it rides like crap. Even with the air bags at the lowest PSI.
1995 F-350 DRW Supercab 7.3 Turbo 5spd
Mozz is offline
Old 06-24-2006, 07:34 PM   #10 (permalink)
Roy_Boy's Avatar
Try running the pressure HIGHER, I know it doesn't make sense, but I've been running mine at 15- 20 PSI and the ride seems better [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Roy
2004 F350 super cab short box dually
One of a kind
6.0L, 6speed, 4x4, 3.73 axles
US gear exhaust brake
Custom SCT,tuned by Tadd
Engine#3- 6398 miles (still running great)
Haulin' More than most of y'all
02 VW Beetle TDI 5 speed
Roy_Boy is offline
