Do I need a CDL? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-14-2005, 07:06 PM Thread Starter
Do I need a CDL?
After all the CDL talk I'm wondering if I need one. I pull a 3 horse gooseneck (6,000 lb.) with up to 3 hoses (say 1,200 lbs. each) and maybe 300 lbs. of tack & misc.. Total would be around 9,900, I pull with a 99 F250 (say 7,200 lbs). Gooseneck is about 26 feet long but about 5 feet are over the bed. Am I legal without a CDL in Ohio?
dwelch250 is offline
post #2 of 5 (permalink) Old 03-14-2005, 10:09 PM
Re: Do I need a CDL?
I guess it varies a little from state to state, but the general rule is GCWR of 26000 or less no CDL needed. You are of course over your GVWR with that load and a 18% tongue weight. I'd be more worried about that than the GCWR.
1996 ext. cab, long bed, 4x4, 5spd. PSD, 3.55LS, Ford AIC, drainplugged Dana 50, EBPV brake, tranny cooler and gauge, Tymar intake, Tymar 4" downpipe and 4" exhaust. No kitty.
Nick_Kent is offline
post #3 of 5 (permalink) Old 03-14-2005, 10:37 PM
Many rules and each state has its own variations (it seems) Here is what I see... IF you own all the horses are NOT pulling for hire (even one horse) you SHOULD be ok without CDL.
Want real fun? My cousin's wife could LEGALLY drive a semi with 80k lbs total weight loaded with her basic lic IF it was their hay/grain/machine on the trailer. No training needed. Same if it is a RV. Tons of rules the only way to know for sure is go to DMV get books THEN ask questions and get answers written down/signed by them. (good luck)
larry_minn is offline
post #4 of 5 (permalink) Old 03-14-2005, 10:44 PM
haul_n_horses2's Avatar
My Photos: (17)
[/ QUOTE ]Probably could only do that within 150 miles of the "farm". Any further away than that and she would need a CDL A probably with air brake certification.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #5 of 5 (permalink) Old 03-15-2005, 12:50 AM
Probably not since any blue hair can hop in a Prevost Coach pulling a full size suv on a trailer without a CDL. The key is "not for hire"
2003 4x4 crew cab 7.3 4x4 auto ,203* thermostat w/billet housing, Bob Riley Water filter, Magnaflow XL 4" exhaust, HX mod, DI 4 Position Chip(stock /40/80/100),AFE series 1,
intank / pre-pump mod , intake heater delet ,
shift kit, DiPricol gauges, DI regulated return, Retrax Bed Cover
cjheap is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
