I bought a '93 F250 and I just remembered that when I bought one of my Dodges the maual said to run a relay if I'm running more than a few trailer lights. I ran a seperate switch to the trailer plug on my '00 Dodge. (they said it could burn up my headlight switch)
So both of my trailers have about 25 running lights, do I need to use a seperate switch to protect my head light circuit from being overloaded?
'93 Ford F250 w/ 7.3 IDI diesel (no turbo) E4od auto. SC/LB 2WD, but hey, got 3 attenas. retired government vehicle.
'26 tall T coupe on '67 scout frame w/400 Ford/C6
'00 Dodge Ram 1500 SC/SB w/318/5spd 4X4 3" SkyJacker lift 33-12.50X15 Perreli Scorpions
'01 Dodge Ram 1500 Quad cab/SB w/360/auto 4X4 NO LIFT!!! Running 33-12.50X15 Hi-Tech-Retreads with Green Diamonds (alternative to studs!) on saw blade chrome wheels.
'62 Caddy 2dr, "slammed" with air bag suspension. I can literaly set it on the ground!!!!
'48 CJ2A w/'61 over head valve engine
'77 Chevy Caprice, rare 2 door! Built 350 4 bolt mains. Weyand high ram intake, Headman Headers, dual glass pack "cop callers", TH350 with high stall converter and B&M "street/strip" kit (churps the tires hitting 3rd @ 90MPH!!!!)
'84 AC 5040 w/ loader
'71 Dodge D200 w/'69 vette 327 & powerglide
'97 Morgan built 20' tilt car hauler
'01 Morgan built 16'cattle trailer
Ford 9N
Ford 8N
JD model 40C crawler
Yes with that many lites you have to be drawing atleast 15 amps[unless they are led] and with the length of wire feeding the circuit I bet closer to 20 amps.Run another switch or relay.I have replace more than one hdlite switch because of horse trailers looking like a Xmas tree going down the road.Stan
Alright, I wasn't sure if Fords came with the relay or what. I guess Dodge does IF it is a factory tow package.
Ford 9N
Ford 8N
