Old 06-23-2006, 01:28 PM   #1 (permalink)
Mik
My Photos: (15)
do trailer tires need to be balanced??
just bought new 15" wheels and ST225/75-15 Carlisle tires for my 2000 24' FW (dry weight 4700lbs) the tires are load range D and have a 2540lbs capacity, 10,160lbs total capacity (i am hoping the extra capacity over my trailer weight will compensate for the Crap-lisle quality (i didn't read the tire posting before buying)
the axles/wheels where out of alignment and the old tires very worn and unevenly worn
got alignment done, bushings, brakes
i wanted the tires balanced but the tire shop said that the stiff sidewalls of trailer tires makes it unneccessary to balance them
so they are not balanced
is it neccessary? should i get them balanced?
My Gallery
'85 F250 XLT Lariat 4x4, 6.9 E/C, 4sp, straight pipe, 254,000km, 18mpg, parked for rebuilding.
'84 F250 XLT Lariat 4x4, 6.9 E/C, C6, 4" straightpipe, Rancho RS9000x, 84-1
'91 E-350 rv-hauler 7.3L, NA, tranny cooler, 250,000km, 3.54s 91 RVhauler
'89 Supercoupe, 5sp, loaded.
wife's car: 97 Jetta diesel turbo non-TDI
my other IH: Farmall Model M
Mik is offline
Old 06-23-2006, 02:01 PM   #2 (permalink)
Re: do trailer tires need to be balanced??
Need is often used as an auxiliary followed by an infinitive with or without to, meaning "to be obliged, must". Most trailer tires are not balanced. Some people don't balance their truck tires.
toalpi is offline
Old 06-23-2006, 02:25 PM   #3 (permalink)
My Photos: (33)
In my opinion they run cooler wear better last longer if there balanced. Also less ware and tear on the trailer.
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Dualie is offline
Old 06-23-2006, 03:42 PM   #4 (permalink)
Teebird's Avatar
Mmmmmmmmmmmmm! Shiner Bock!
Ohhhhhh. When I have my trailer tires replaced, they'll be balanced. However, it seems as though you purchased bias plies, no R in the size, so maybe it is not as important as it is with radials.
2003 F250 XLT 4x4 Sport Crew Cab,
Built May '03, Bright Red, 6.0 Auto, ESOF 4x4, 3.73LS, 4.5" Edge Lift, 315/75-16 BFG KO A/T's, Polished/Clear Powder Coated Diff Covers, Weld Cheyenne 8 Wheels, Line X, Overhead DVD, Torza Tonneau Cover, 30' Fleetwood Gearbox Travel Trailer
Teebird is offline
Old 06-23-2006, 05:17 PM   #5 (permalink)
My Photos: (33)
I remember reading some where that bias ply tires arnt actually "ROUND" something about they way there made that makes them have flat weird flat spots all the way around. Might be crazy here I don't know.
I do know that our boom truck with bias steer tires will pound your kidneys for the first couple of miles on a cold morning after sitting until the tire starts to warm and round up.
Dualie is offline
Old 06-23-2006, 06:08 PM   #6 (permalink)
SmokeyWren's Avatar
My Photos: (33)
I have 4 trailers.
Two are used for low-speed, short-distance hauling such as running to the lumber yard or the landfill. The tires on those two trailers are not balanced.
But my RV and the tag trailer I often pull behind the 5er on long trips at interstate speeds have all the tires balanced.
Out-of-balance tires cruising at my normal 62 to 68 MPH will shake the reefer and other appliances in the RV trailer to death in a short time. And the generator and handicap scooter and other stuff in the tag trailer don't take too kindly to constant shaking and jolting and vibration, either. And probably cabinets and other parts of the RV will live longer without all that vibration caused by unbalanced tires.
So you can bet that I insist that my tires are balanced on those trailers.
It's easy to check. Have the tire guy mount the tire/wheel on the balancing machine and see how much weight it will require to balance the combo. If it's more than the size of a double-ought buckshot, then you decide. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
SmokeyWren is online now
Old 06-23-2006, 06:35 PM   #7 (permalink)
Awe Mik, I'm sorry....ANY tire but Craplisle.
I've been down that road....didn't work. I went from General Ameri-trailer load range D tires (that came on my 26 TT) to craplisle E rated. I never had a flat or blowout on the lower-rated Generals but within 6 months I had a craplisle E rated grenade on me and tear up my trailer. They wouldn't even reply to the web email claim I filled out. I've since swapped them all out for Greenball E-rated 225/75-15s and have been happy with them.
I know most toyhauler companies will not put craplisles on their products, matter of fact I couldn't find one with craplisles on them while recently out looking at the new toyhaulers.
But, to answer your balancing question I say most definetly yes on getting them balanced. I've seen plenty of trailers tearing themselves by wheels out of balance banging around at hwy speeds.
05 F-350, PSD, 4x4, Crew Cab,6-Speed
2" Front Level Kit, Pro Comp ES9000 Shocks
Firestone Model 2400 Airbags (horrid engineering)
Tow 30' Toyhauler
*-Friends don't let Friends run Crap-lisle Trailer Tires
Rich807 is offline
Old 06-23-2006, 10:17 PM   #8 (permalink)
Yes, balance. I had the Crapisles, the same ones you have, almost had a blowup!! Traded(Discount Tire) to BFG Commercial T/As load range "E" in 16" wheels and tires. Had issues with Goodyear Marathons too.
Keep a sharp eye on them as I did everything right and still almost had trouble. I too was well under the weight cap of the tires.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 06-25-2006, 08:36 AM   #9 (permalink)
Yes. Balance your tires. RV manufacturers & dealers do not have the tires balanced because you will never feel the vibration of unbalenced wheels from your seat in the tow vehicle, but the vibration in still threre. Counting the thousands of RVs sold every year and assume thar each one has four tires you can imagine how much money the RV industry saves every year by not balancing tires & wheels. You will save much wear & tear on your tires, wheels, suspension, trailer & RV applianced by balancing your wheels.
2005 F-350 Lariat, 6.0 PSD, Torqueshift auto trans, crew cab, SRW, short box, FX4, ESOF, limited slip dif., tow command, upfitter switches, 6 CD changer, Lariat Lux. package, camper package, engine block heater, adjustable pedals, reverse sensor, triple A-pillar gauge set (Autometer) with pyrometer, trans temp & voltmeter, MBRP 4" cat back exhaust w/5" dual wall chrome tip, dark shadow gray/ med. flint interior.
2008 Big Horn fifth wheel by Heartland RV model 3670RL. 38' long, 4 slides and all the goodies.
wpetko is offline
Old 06-25-2006, 11:32 AM   #10 (permalink)
I've never bothered. If I was riding in the trailer, definately. As for wear? Maybe... but these tires don't last long anyways. "Pounding the trailer to death"? I'd be more worried about the hwy expansion joints, potholes, etc than an out-of-balance tire.
http://community.webshots.com/user/roadfrog
Cheers,
Chris
FOR SALE! 2002 F350 CC 4x4 SB Lariat Blue & Silver, General AT2 295/75/16's on 16x8 Panther Rims, KYB Monomax Shocks, Euro Style Tail Lights, billet fuel door, Putco chrome handles, Autometer Z Gauges & Pillar Pod, Billet Grill, Bullbar, JVC KD-AR870 head unit, Sirius, MEI Reference Series 600 Watt amp with 6.5" Alpine DD Drive F17C components front, 6.5" Jensen components in rear, Better Built truck box, auxiliary backup lamps, acetoned badges, blacked out lower weld seams, Dodge auto-dimming rearview mirror, Avital alarm system, heater by-pass mod, in-tank, harpoon and pre-pump mods, 5" SS exhaust tip.
2002 Acura el (only available in Canada)
2002 Fleetwood Wilderness 31G
1988 Campion Allante, 19.5' w/ Merc 5.7 litre
Roadfrog is offline
Old 06-25-2006, 11:54 AM   #11 (permalink)
Sidewall stiffness and balance have nothing to do with each other. An unbalanced tire with stiff sidewalls will vibrate as badly as any other tire. I choose to balance the tires on my trailer as I figure it sees plenty of other road related stresses and doesn't need another.
2006 F-250 4X4 Lariat, C.C. / SWB -- Torreador red
PerryB is offline
Old 06-25-2006, 05:35 PM   #12 (permalink)
My Photos: (27)
I agree, plus badly out of balance tires will start to cup and wear faster.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 06-26-2006, 09:53 AM   #13 (permalink)
Mik
My Photos: (15)
thanks guys
sounds like i got screwed
i asked this fella over the phone half a dozen times "are these radials? this quotte includes balancing?"
My Gallery
Mik is offline
Old 06-26-2006, 10:57 AM   #14 (permalink)
SmokeyWren's Avatar
My Photos: (33)
It's easy to tell by the tire size. You said "ST225/75-15", but that's not exact.
Bias ply tires will be size ST225/75D15
Radials will be size ST225/75R15
Old 06-26-2006, 09:01 PM   #15 (permalink)
Albin's Avatar
My Photos: (24)
Any reason that 4-6 oz. of antifreeze wouldn't work to balance 15" trailer tires? At $12 a pop, I'd rather spend the $48 on something else right now.
Al
'06 F-350 SRW 6.0 PSD
Albin is offline
