Old 08-02-2007, 12:31 AM   #1 (permalink)
do you think this winch is a good buy?
im looking into getting a winch, and i dont want to spend a lot of money. You think this will work decently?
http://cgi.ebay.com/NEW-ELECTRIC-15...1QQcmdZViewItem
1996 Ford F350, 7.3 PSD, crew cab, 8ft bed, 4x4, 5 speed manual, 4.11 gears. 184,000 miles. 3x4" down pipe, 4" exhaust with 5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers,garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
gilroyracing is offline
Old 08-02-2007, 11:26 AM   #2 (permalink)
Re: do you think this winch is a good buy?
Am assuming you mean this:
Winch
Without knowing what you will use it for it's not that easy to say. However, the "15000 pound" capacity is deceiving, as the fine print says "marine power", whatever that means. You're actually getting 5000 pounds of pull with the cable completely extended 28 feet. The more cable on the spool the less the pulling power.
The other issue is being able to mount the winch securely to your trailer. If the mount is week the winch can break either itself or the mount when pulling heavy.
02 F350 7.3SD Crew/LB/SRW DP-F5 (stock, 60t, 80e), Fumoto valve, gauges on A-pillar, XM Radio, Happijac tiedowns
99 Jeep TJ / lockers / 37s
KVOM is offline
Old 08-02-2007, 01:17 PM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
If you don't double the weight of your truck with what the winch can pull you will not be happy.
I have a 15K warn I would part with.
MarkEkberg is offline
Old 08-02-2007, 09:41 PM   #4 (permalink)
No, I think it would be a wate of your money. If that is a 15,000 # winch I can fly. 1500 # maybe, but not 15,000.
joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
Old 08-02-2007, 09:57 PM   #5 (permalink)
My Photos: (33)
there is no way in hell that is a 15,000 Lb winch! NO Way! That appears to be 1/4" wire rope.
It says it has a 3,000 lb dead pull and a 15,000lb marine pull.
Unless your truck is perfectly floating in a pond that wont move it very far if at all.
I wouldn't put anything less than a 12 K winch on a 3/4 ton truck. And then I wouldn't use it to un stick said 3/4 ton truck with out having a snatch block with 2 parts of line running from a dead man back to the truck.
I pride myself on being smart enough to know where NOT to put one of my trucks somewhere there going to get stuck. My friends NOT SO MUCH.
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Dualie is offline
Old 08-02-2007, 10:47 PM   #6 (permalink)
its for my car trailer.
Old 08-03-2007, 06:50 AM   #7 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I said I have a 15K I would part with, not the one advertised.
Old 08-03-2007, 07:50 PM   #8 (permalink)
JimTJr's Avatar
My Photos: (6)
IT may work for a ATV,,, does not look nearly good enough to pull cars up very often, (may do it a few times,) Get a decent winch,, Mile Marker, Warn, Superwinch, ect... durability, and quality is worth the money.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 08-06-2007, 08:52 PM   #9 (permalink)
one simple word. "No" It is not a good buy. If you do get it, at least put a block on it for double line pull. You will probably still hate it though.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
NickKent is offline
Old 08-18-2007, 02:13 AM   #10 (permalink)
I am interested in the 15K. Would you be willing to ship it to Texas? How much are you asking for the winch?
95 F350 7.3 CC DRW utility bed. :Personal money maker
03 F350 4x4 CC DRW King Ranch. :Soon to have a new utility bed with Autocrane. Then this will be my money maker!
Hardline43 is offline
Old 08-24-2007, 01:39 PM   #11 (permalink)
Marine power, means that it can pull a 15000 lb boat, that is floating on the lake onto the fully submerged trailer. Not a real hard feat since you can do the same thing with a hand crank winch on the front of most trailers.
You need something a lot stouter to pull your truck.
--------Robert
'92 F-350 7.3 5 spd, Crew Cab dually,ATS turbo, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
RLDSL is offline
Old 08-24-2007, 03:43 PM   #12 (permalink)
I bought one that looks almost identical at Harbor Freight for $49.00. It's okay for moving a dead car on level ground but that's about all.
'06 Ram 3500 4X4 QC CTD 6sp LB
'01 F350 PSD 4X4 6sp Crew Cab (sold)
'68 F250 C/S 4X2 C6/428PI
Stidham 24' enclosed car hauler
Bunch of big old cars
In theory, practice and theory are the same.
In practice, they are not.
Packard8 is offline
