We were towing a 6,000lbs excavator on a 12,000 lbs Bri Mar deck over trailer. The tongue snapped off and dropped the deck onto the road. After looking at the design it is very poor. I am stuck with this pieces of crap and will need to weld significant reinforcements to get it back into service.
I called Bri Mar and they told me to bad
I would stay far away from this manufacturer they make a dangerous product
mr smith
99.5 F450 4x4, CC, 6 speed, Luk Clutch, ported BB turbo, DP chip, Banks brake, Aeroturbine, 4" stack, SPEARCO 6.0 charge air cooler, Tymar intake, Dahl 100 filter, In tank & Pre pump mod, Zoodad,
Any way to file a complaint with the BBB in PA ? Also, I would think you should be able to file a complaint with the Federal Highway Commission or the Highway traffic Safety Board. If Bri Mar is as big as their website makes you believe they are, then I would complain as loud as you could until they hear you. imho
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2003 VW Jetta TDI auto, 90k miles, all stock, no mods, 41 mpg most days. A rocket in disguise...
Repairs: alternator, brake switch (x2), power window wire harness, #4 glow plug, glow plug wire harness -TRADED as of 11/24/2008
Newest purchase - 2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available yet)
threaten to make them lose business tell them youllpost here with pics of what happened and youll report them to consumer products
then speak with the presidnet of the co.
after this they should refund your money or replace it woth an upf
graded trailer and if not you can easily take their company down with that story
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
How much tongue weight were you rocking on that trailer when it snapped? Do you have any pics? I would love to see where it let go and how it is designed. Good luck getting it back up and running.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
Sorry but this type of thing has numerous trailers. It just show there is problems with everything people. I do have a bri-mar trail and is the best trailers i have owned and ever towed.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Markford14</div><div class="ubbcode-body">Sorry but this type of thing has numerous trailers. It just show there is problems with everything people. I do have a bri-mar trail and is the best trailers i have owned and ever towed. </div></div>Put the bottle down!
I have a Bri-Mar CH18 that I have been very happy with, FWIW... The construction seems more than adequate on mine. I looked at a lot of trailers before I bought it.
Steve
2004 Ford F150 FX4 SCAB, 2005 Volvo XC90 T6, and a bunch of Crown Victorias
this dont happen all the time yes failures but not the whole tounge breaking off like he said
yes pics please
When I called Bri Mar they began right away with " must have been over loaded" , "too much tongue weight" etc. I have had my tree business for over 20 years, I also haul horses over 15,000 miles a year for competition. Loading a trailer properly is not the problem and we never haul over 8,000lbs on a 12,000lbs rated trailer.
Since we are a business we use the trailer regularly, If you own one and haul twice a year your piece of junk may last forever.
IT IS A BAD DESIGN
Not running the channels that form the tongue farther under the trailer is the problem. Our other trailers both have the channels running 4 to 6 feet under the deck. not just butt welded to the front of the deck. When looking at a trailer to purchase keep this in mind
I wish I had pics of the scene in the middle of the road with the tongue on the ground and the back end of the trailer 6 feet in the air. I was only concerned about getting out of the road before a D.O.T. cop showed up to write tickets.
From what I can see in the pictures; I agree I don’t like the design either! But it also looks like a lot of salt damage. Did I miss it? How old is this trailer? When was the last time it was sanded down, and painted? I’ve heard some horror stories of pickup truck frame failures from salt damage!
Hard to tell from the pictures, but looks like you, (someone) has to cut a whole lot of material out to get back to good iron. Break out the torch, and get busy! [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
Why Chyrel? To quote the late great Johnny Cash!
"My name is Sue! How do you do! Now you gonna die!"
2007 Dodge 3500, 4X4 Quad cab SLT, with 6.7L Cummins / 6-speed Aisin, 4:10 gears, and 9 1/2-foot Aluma flatbed.
Long gone
2004 F-550, 6.0 PSD, Torqshift, 4:88 LS axle, Flatbed dump with a 10-ton Scott hoist. Autometer Pyro/trans/boost on pillar. Turbo lifesaver.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> Hard to tell from the pictures, but looks like you, (someone) has to cut a whole lot of material out to get back to good iron. Break out the torch, and get busy!</div></div>
Right, it looks far from new, who knows what's been on it in the past. But it's amazing how many people can make a "knowledgable" judgement and give out an opinion merely by looking at a computer monitor.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">I have a Bri-Mar CH18 that I have been very happy with, FWIW... The construction seems more than adequate on mine. I looked at a lot of trailers before I bought it. </div></div>
Yessir, I've always found there's two sides to every story.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: LMJD</div><div class="ubbcode-body">But it's amazing how many people can make a "knowledgable" judgement and give out an opinion merely by looking at a computer monitor. </div></div>
LOL! I’m one that has to touch it, to really see it. Can’t tell you how many times my mom slapped my hands in a store when I was a kid! [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
Long gone
