i have decided upon the need to sometime get a small backhoe and trailer now i need to know if anyone has had one of those dump bed kits? i am looking into one of those kits for like a 1000$ that will convert the stock bed into a dump. i will only need to haul a little at a time under 2 ton so since many are rated at 2 ton i should be fine but ive only seen a few. how well do they work? anything better for the same price? will that lower the amount the bed can haul without the use of the dump? any help would be nice thank you
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
That was discussed here a year or two ago. General opinion was the stock pickup box with a hoist is not strong enough to haul & dump heavier loads. You'll tear it up eventually. If Your going to install a hoist have someone install a small dump body or flatbed with sides on Your truck, hopefully it's a dually.
For comparison, the sheetmetal floor in a OEM pickup box is at most 1/16" thk. Flatbeds normally have 1-1/2" to 2" thk wood floors & dump bodies normally have 3/16" thk steel floors. The flatbeds & dump bodies also have steel rails running from front-to-back to support the floor when it's raised. The OEM pickup box only has supports side-to-side about every 1-1/2 to two feet.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
294,000 mi & NO Problems, LUK Clutch, and the Cat is buried in the back yard!
if u want to keep the oem bed, only reasonable way to keep it is to install the dump beds that fit inside the pickup bed. they are heavier steel but gonna be more than a $grand. if not a dually, look at Railer beds. good luck
2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
