Old 12-13-2006, 08:00 AM   #1 (permalink)
Early PSD rear springs
My 94 has had saggy rear springs for a while- especially drivers side sags like 1-2 inches more than passenger side. I carry a 1500lb. popup camper for months at a time. I have already tried a add-a-leaf and sag is the same. I am not real interested in airbags because I just dont want to have to deal with monitoring pressure, etc. plus I think the springs should be in good shape to start with. I see in several catalogs that the original 4+1 2800lb. springs can be replaced with 6+1 4200lb. springs. The salesman says the truck will have the same ride height-they are just arched differently to compensate. Does anyone have these or have an opinion? Would this be an easy bolt on job? Thank you
1994 F250, Tymar, Tuff country 2" lift
lomile94 is offline
Old 12-13-2006, 04:15 PM   #2 (permalink)
Re: Early PSD rear springs
lomile,
Make sure you do not have a leaf or 2 broken in your stacks. I had 2 cracked on one side and 1 on the other resulting in a sag. I had never been overloaded- the spring shop said it was likely bad springs combined with a lack of load causing a lot of bouncing that caused the problem.
Good luck!
99.5 F250 6 speed, SCMT 1705, LUK clutch kit and kevlar pilot, ProComp EGT and pyrometer, Leer topper
http://community.webshots.com/user/john_harrington
99_6speed is offline
Old 12-13-2006, 05:38 PM   #3 (permalink)
PSDfreak's Avatar
lomile,
Good luck!
Where had the springs cracked? Was it obvious by just looking at them?
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 12-13-2006, 11:29 PM   #4 (permalink)
Springs usually crack at the center bolt and usually easy to see.
Curt
1997 F350 cc/lb, 4x4, E4OD, 4.10, Pyro/Trans Temp/Boost Gauges. Torn apart- installing h2e, sd intercooler, bronco tank, bosch 044 fuel pump, dahl 150, regulated return, big oil, b codes.
CEMeyer is offline
Old 12-19-2006, 03:22 PM   #5 (permalink)
I dont have any broken springs. At one point someone said this problem is common in ford diesels due to twisting torque that somehow only affects drivers side. Anyway- I am still looking for comments on the thicker spring packs. Any reason not to besides it will ride a little stiffer I know. Thanks
lomile94 is offline
