Old 08-17-2005, 06:17 PM   #1 (permalink)
EGT gauge for engine longevity?
Relative newbie to the PSD world. Thanks to this site, I've come up to speed with a number of issues pretty quick.
I currently have no extra gauges installed on the vehicle. I tow a ~6K travel trailer primarily in Montana and Wyoming. The only thing I've really monitored was the engine temp using the message center trick.
It appears having an EGT gauge is pretty darn important. What I don't quite understand is the chance of doing damage to the engine, if I don't monitor these temperatures. Does the PSD sensors know when to reduce the fuel to the motor when the temps get too hot?
I'm mostly concerned about these temps on the mountain grades while maintaining speeks around 60-65.
Thanks in advance.
TroutGuy is offline
Old 08-17-2005, 07:43 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Re: EGT gauge for engine longevity?
It depends on your exact calibration (computer program) in your program control module (PCM). Most stock PCMs will not get the EGT hot enough to hurt anything. But a few will.
The only time you might get the EGT too hot when towing up a mountain pass with a stock engine is if you use the cruise control that forces "petal to the metal" up the mountain. Or if you drive without the cruise but mash hard on the footfeet to maintain your speed up the mountain.
If I didn't have a pyrometer (gauge for measuring exhaust gas temp, or EGT), and I had a stock PCM with no chip or programmer, I would not use cruise control for mountain climbing, and I would manually mash on the go pedal to only about 9/10th max. Then I'd be pretty sure that I wasn't cooking my engine, regardless of the calibration Ford programmed into my PCM.
But I can't imagine living where you live and towing where you tow with a stock PSD. So I have 4 aftermarket gauges - including a pyrometer. I have an Edge Evolution tuner in "tow" mode. Even with the best intake and exhaust available, I can still cross the red line on my pyrometer if I leave the cruise set on 60 MPH when towing up the mountain, or if I manually try to push the go pedal through the firewall to keep that darned Dodge from passing me. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
So my advice is to install a pyrometer, with the thermocouple (sender) before the turbo (pre-turbo), then use 1,250 as your red line. The International engineers tell us that if you have a tall enough mountain, you can cruise all day at 1,200º, but try not to let it creep over 1,250º.
Do that, and your engine will last a normal life. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
SmokeyWren is online now
Old 08-17-2005, 08:08 PM   #3 (permalink)
96STROKE's Avatar
My Photos: (6)
Well, both PSD I have owned, with gages but no chip, it was not hard to go over 1250 deg F pre turbo just getting on the freeway on ramp. IMHO, I wouldn't tow with out gages, even on flat ground!
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady
Photos
96STROKE is offline
Old 08-17-2005, 09:21 PM   #4 (permalink)
Old_Machinist's Avatar
You really will change the way you drive when you get a set of gages! I totally changed what I thought was being "easy" on my unit. Now I don't work it near as hard and it pulls like a freight train!
Grant
96 Ford Powerstroke, Centarus Converson CC, 4.10, Long bed DRW, 4 pos TWildman chip, SD HPOP, 6.0 Intercooler, 3.0 downpipe and Bully Dog 4.0 exhaust, AFE intake system, pyro (pre turbo),trans gage (located in test port), Custom Fabion Motosports Torque Converter, pump mods, Tugger trans kit, Torqueshift tranny cooler, Firestone air bags, Rancho RX 9000 adjustable shocks, and baby SWAMPS!!
Pulling a 2000 American Star, 34RLCK bedroom and living room slides, w/d stack ,12,640 lbs.
Total weight 19,300. New addition 20ft VIP Bowrider boat towed behind 5th wheel, total length 74 ft, 24,000 lbs!
Old_Machinist is offline
Old 08-20-2005, 07:52 AM   #5 (permalink)
Blue Water Runner's Avatar
I found out the getting a run on those long grades pays off in lower EGTs. Now I know why the big rigs are sometimes in the right lane even when they have more go pedal.
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Straight Pipe,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer
My Pictures
Blue Water Runner is offline
Old 08-20-2005, 08:52 AM   #6 (permalink)
Usually the big rigs are in the right lane because they ran out of go pedal. EGT's aren't usually an issue with the big trucks, at least not with me, although I'm a company driver and the trucks I drive aren't cranked up..............Dave
Dave
11
#3
FOREVER THE MAN
LEGENDS NEVER DIE
1997 F350 CC DRW 4X4, Black. Centaurus2 conversion. Banks IC & powdercoated tubes. Stage 2's by Full Force Performance,BDP Dom 66, BDP Fuel system , TS 6 pos chip with Bills & T Wildmans burns, AFE intake, 4" exhaust. Gear Vendor Overdrive. E4OD with Suncoast Pro-Loc TC, 4.10 gears. Sky's RSK, Kelderman air ride, Bilsteins, 40 gal Transfer Flow. Alcoa's. Pioneer stereo, full floor and overhead console.
As of now 391 & 740, Going for 400
pictures > http://community.webshots.com/slides...986&key=uYblzs
97Strokerman is offline
Old 08-20-2005, 01:21 PM   #7 (permalink)
During my trip out west this past summer, I was routinely getting to 1250 on EGT's. This was on big hills on the freeway as well as mountain passes. My truck is completely stock so having the gauge is a must. My X-Monitor also monitors boost and transmission temps. It holds all the high values untill I erase them. The highest trans temps I saw was 191 and boost shows a high of 38. The boost seems high. As Smoky Wren said, you can see high EGT's with the cruise contol and not paying attention to the gauges. I once caught 1341 degrees on the gauge and immediately backed down. The one good thing about monitoring EGT's is they go up fast but also come down fast so, normally your not at that high number too long unless your not paying attention. Good luck,
Mark
2007 F-250 King Ranch,Dark Copper, CC, 4x4, FX4, PSD, Torqshift, tow command, X-Monitor, Husky Liners, Vent Shades, Century Fiberglass Cap, Bedrug, harpooned, Fumoto Valve.
2005 Forest River Wildwood LE 29BHSS
mlabelle is offline
Old 08-20-2005, 05:10 PM   #8 (permalink)
38 psi boost stock??? [img]/ubbthreads/images/graemlins/confused.gif[/img]
<font color="red">2001 F250 XLT CC SWB PSD, White w/silver, 2WD AUTO, PRE-PUMP MOD, X-Monitor from DIS, ZOODAD, PMT2 to MNM1 reflash from Bill @ Diesel Power Chips , SP Power Box ,Walker BTM, Custom open intake, Sonnax/Tricum, DI in-tank mod, Ranger heater valve, FORD AIC, Hella Micro FF, Access toolbox tonneau, 4 position chip from Diesel Innovations </font>, and two German Shepherds hanging out the rear windows
Truck pics
fire1 is offline
Old 08-20-2005, 07:03 PM   #9 (permalink)
My Photos: (11)
TroutGuy,
All the previous posters to me here have great points and personally I think gauges are a "MUST" first mod especially if towing and you might be considering any mods in the future. At around $300 for a pre turbo EGT, tranny temp and boost gauge just makes sense and maybe even a fuel pressure gauge. Some will disagree on the boost gauge, but I use it a lot towing to get the most leg out of my engine before I have to drop out of either cruise and/or OD. Based on what I know now I'm not sure how important a coolant temp, oil temp, oil pressure, voltmeter gauges are [img]/ubbthreads/images/graemlins/shrug.gif[/img] They will not only establish a baseline for your truck and how you use it but can save an engine, tranny, etc. when somethings starts going South like a stuck EBPV or non functioning tranny bypass, etc.
On the longevity thing, I now have almost 50K on my PSD and have towed almost 55% of those miles and would say I have spent more time in those miles with my pre turbo either buried at 1250 or in excess of 1100 degrees than most F-series owners because of the lack of an intercooler in the Vans. So far the engine is running great and I have had ZERO engine or any sort of mechanical issues.
Larry
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 08-20-2005, 07:46 PM   #10 (permalink)
I know. Maybe it was a fluke reading?
Mark
mlabelle is offline
Old 08-20-2005, 10:40 PM   #11 (permalink)
I pulled my 12,000 lb fiver out west this summer also and my totally stock 05 F350 could only do 27 lbs of boost. Yours must be a special truck.
Joe
'05 F350 XLT CC PSD SRW Tow Command Auto 18" Al. wheels long bed Red!!
'05 Mineral Grey MUSTANG!!
'04 Open Road 357-5th Wheel
gilbert948 is offline
Old 08-20-2005, 11:49 PM   #12 (permalink)
I don't know about that but was just pulling yesterday and could get to 28-29 easily, according to the X-Monitor.
Mark
mlabelle is offline
Old 08-21-2005, 12:33 PM   #13 (permalink)
So you're running the X-Monitor by itself? No "goodies" under the hood? I didn't realize that could be done. I learn something new everytime I come to this site!!
Joe
Old 08-21-2005, 02:03 PM   #14 (permalink)
The X-Monitor is simply a digital guage set. I installed mine before any goodies. I love it.
Truck pics
fire1 is offline
Old 08-21-2005, 02:21 PM   #15 (permalink)
Did you go through the set-up for the x-Monitor when you installed it? It is programable for several different applications. Maybe this makes a difference [img]/ubbthreads/images/graemlins/shrug.gif[/img]
June 2004 F350 6.0L, 4 Door Supercab XLT SRwd Short Bed, Automatic, Deluxe Aluminum wheels, Class V Trailer hitch receiver, 3.73 standard rear end. Line-X bed liner, 5th wheel hitch, Brakesmart trailer brake control and powerlock starter interlock.
Larryect is offline
Search for used vehic
