Electric over Hydrolic Brakes & ITBC - Diesel Forum - TheDieselStop.com
Old 08-01-2005, 12:02 PM   #1 (permalink)
BWilliams's Avatar
Send a message via AIM to BWilliams
I can not seem to locate solid info as to if the new Integrated Trailer Brake Controller will or will not work with Electric Over Hydrolic Brakes.
Any solid info would be greatly appreciated.
Thanks !!
Bobby Williams
Director of Fleet Sales
Sunrise Ford Fleet 16005 Valley Blvd, Fontana, Ca 92335
(909) 822-4404 (909) 434-0543 Fax Number
Email --->bwilliams@sunrisefordfleet.com
2011 F450 Crew Cab 4X4 Lariat 6.7L / 6 Speed Auto Golden Bronze / Pale Adobe
BWilliams is offline
Old 08-01-2005, 12:25 PM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Re: Electric over Hydrolic Brakes & ITBC
Well Ford says it does not work but Dexter has a new pump/actuator that is compatible. Guess it depends on your hardware.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
Old 08-01-2005, 02:55 PM   #3 (permalink)
ford says yes/sort of for 2006
trailer life said yes
isnt life grand
Robert AKA# 12225
2006 Lariat "TOW BOSS"
Mods So far: Stopped counting
2002 F350 Larait Crew Cab Dually , (sold 65k Miles)
1992 F250 HD 4x4 Super cab 7.3 IDI W/banks(Sold 118k miles)
1988 F150 Short bed 4x4 (sold 45k miles)
Feel the Force of TDS
powerboatr is offline
Old 08-01-2005, 03:39 PM   #4 (permalink)
BWilliams's Avatar
Well, we ended up just hooking up the trailer up to my truck since I already have the gooseneck hitch in it and tried it out. It worked perfect !!
Bobby Williams
Old 08-01-2005, 03:47 PM   #5 (permalink)
My Photos: (10)
isnt life grand
A wise old man once told me it is not will it work or wont it work. but how do you get it to work with what you have.
As stated before electric over hydrolic needs a battery source close to the activator. If you put a 5 amp battery and use it for 6 mps then the last time you aint got no amps.trailer dont work.Brake controllers work about the same power in, brake activation in, ground and brake activation out. have nanual brake activation little lever on controller and a auto, when you hit the brake pedal.Big wire the longer the run the biger the wire needs to be. Trailer Brake activator some use motors to drive some use pumps,Master brake uses a motor to drive a piston into a master cylinder, 1600 psi for disk and 1000 for drum.Dexter uses a pump, 1600 psi for disk and 1000 for drum.
To hook up you have wire for 12 goes to a battery battery is charged off truck. groud goes to ground prefered to battery ground. the battery on the trailer and the truck ground in the pig tail.Then you have a brake activation wire that is the blue wire coming out of the brake cotroller. simple.Then you have one more wire that is the brakaway wire from the battery. sends 12volt to the unit and locks the trailer brakes. If all theses are present then the trailer brakes should work, depending on the controller in the truck and the amount of brake pads you have. Cheap dont mean good in the controller buisness.
A friend has a 2005 F-350 dully Pulles my 40 foot gooseneck trailer, electric over hydrolic trailer with disk brakes and it works great as ling as he is over 15 mph when braking starts.
Whith this said cant aint and wont has not ever done any thing. If you are taking it to a shop and they say it cant be fixed it is time to go somewhere else. If the mechanic dont know how it works go tosome one that does.I have yet to see a trailer that cant be fixed.
j_apetersen is offline
Old 08-01-2005, 04:32 PM   #6 (permalink)
The reason that Ford says it does not work is because the ITBC sends out a pulse periodically to test if the brake circuit is complete (i.e. the trailer brakes are connected and working). With electric/hydraulic trailer brakes, this signal is enought to activate the hydraulic pump, resulting in premature pump wear.
Newer electric/hydraulic brakes systems are designed to work with the newer TBC that send check signals and ignore the pulses. Chances are if the brake system was made in the last year, it will work fine with the ITBC, but check with the system manufacturer.
Cheers,
Tom
'05 350 XLT SUPERCAB 8' 4WD SRW 6.0
TBlough is offline
Old 08-01-2005, 10:50 PM   #7 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Bobby, if you want to "get smart" about the subject, pick up the August 2005 issue of Trailer Life magazine. It's usually for sale in RV stores if not at your newsstand. Or wait a couple of weeks, and maybe they'll post it on the Trailer Life website.
A teaser is shown in the August issue index, but the "Getting Along" article is not yet "turned on" so you can read it. http://www.trailerlife.com/output.cfm?ID=991495
SmokeyWren is offline
Old 08-02-2005, 10:24 AM   #8 (permalink)
BWilliams's Avatar
Thanks Smokey, I'll pick one up today [img]/ubbthreads/images/graemlins/wink.gif[/img]
Bobby Williams
Old 08-04-2005, 12:41 PM   #9 (permalink)
My Photos: (10)
Cheers,
Tom
that is funny brakesmart sends out a pulse to check the brakes and it works great with electrolic brakes.
Old 08-04-2005, 01:26 PM   #10 (permalink)
My Photos: (17)
Cheers,
Tom
[/ QUOTE ]It depends on the pump/actuator. Some pumps will not tolerate that and they had to add programming/menu options to turn that "feature" off so it would not damage the pump/brakes.
Old 08-04-2005, 01:59 PM   #11 (permalink)
my 2006 book says it should work with the brakes.
cant say for sure i still have the old relaible dinosaur brakes on both trailers
Robert AKA# 12225
