Old 11-19-2006, 09:56 AM   #1 (permalink)
Electrical problem?
The 30A maxi fuse in the power distribution box under the hood that, among other things, powers my prodigy brake controller blew while I was moving the prodigy to another location. I probably accidently touched the harness to ground at some point while the prodigy was disconnected. Found a 30A maxi at Auto Zone, but it wasn't until I inserted it that I noticed very fine print on the top of the fuse--it's a 30A,32V fuse. Will this be a problem? Everything seems to be working ok, but I haven't towed with it yet. If it is a problem guess I'll have to stop by a Ford store and buy the proper 12V model. Thanks for the help.
2000 PSD F-350 XLT Crewcab dually. BTS tranny, 4 position chip (stock, high idle, 60 hp safe tow & 80 hp economy), 3.73 with Mag-Hytek cover; AFE Stage II intake; MBRP 4" exhaust; EGT, tranny temp & boost gauges; HX oil line, gridheater delete plug, ccv mod, PacBrake, external coolant and tranny filters, J&J Stainless running boards.
OldSalt is offline
Old 11-19-2006, 01:16 PM   #2 (permalink)
Re: Electrical problem?
Thats the MAXIMUM voltage it will handle. Any thing less is OK. Leave it.
Partsman is offline
Old 11-19-2006, 02:03 PM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
It is fine.
MarkEkberg is offline
Old 11-22-2006, 10:00 AM   #4 (permalink)
Thanks for the help, guys. I really appreciate it.
OldSalt is offline
