Old 05-06-2005, 10:27 PM   #1 (permalink)
Enclosed trailer floor
I just picked up my new enclosed car hauler. I want to do something to finish the floor. I will also be hauling ATV's in the trailer so some mud and water might be an issue. Any ideas?
2003 F350 CC 6.0 4x4 King Ranch
blueovalkid is offline
Old 05-06-2005, 11:29 PM   #2 (permalink)
Re: Enclosed trailer floor
Rhino Line it, that would be way cool!
Just eating rainbows and butterflies
01 F350 dually 4x4 CC auto.
311 hp 610 torque a while back.
My Pickup
Some Photos and Sound Clips
Diesel Power & Performance Derby Ks.
#46
Kanman is offline
Old 05-07-2005, 12:10 AM   #3 (permalink)
The Rhino line idea is a good one. Expensive but good. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Is the floor painted? If not seal/prime/paint. Hopefully someone here will have some durable ideas. (for myself I would consider something slightly rough so floor not slick when wet/muddy/icy) There was (likely still is) a spray on plastic that was 1/4th the cost of Rhino liner for trailers/grain/dump trucks. They suggested spraying lightly/dust floor with (IIRC) chicken grit then spray for walking surfaces. It would be low enough not to bother when sweeping deck.
larry_minn is offline
Old 05-07-2005, 01:29 AM   #4 (permalink)
I bought a garage mat at Sams club and cut it to fit the floor of my sprint car trailer, works great. just hose it off with the power washer.
01 Ext.cab 4X4 DRW Edge Evo, Jasper Monster Box,Putnam hitch,auto meter gauges
ralphbaker is offline
Old 05-07-2005, 10:54 PM   #5 (permalink)
I power washed mine and sealed it with Cabot clear solution, the same stuff I use on decking to refinish them. It's a linseed oil based finish that penetrates the surface and doesn't leave residue to slip on. I power washed it to get the "mill glaze" off of the wood to allow the sealer to penetrate better. If you don't want to power wash you could use TSP and bleach (with water) and a scrub brush, then seal it.
If it's worth doing it's worth doing right!!
2002 F-250 PSD CC Lariat AIC, AIS filter, Cat delete, Coolant filter.
amb2958 is offline
Old 05-13-2005, 11:22 PM   #6 (permalink)
My Photos: (11)
I just bought a new haulmark in Jan. and wanted to do the same thing because I use mine for my lawn care buisness. What I did that turned out great, was to prime the floor, and then painted it my color of choice. Grey. I started at the front, painted a 4' section deep all the way across. Then, take some sand(the coarser the better, I used sand blasting sand that I had in the garage), and sprinkle that evenly onto the painted area. You can control how rough you want it. Then paint another row, and sprinkle more sand, continuing all the way to the rear of the trailer. When that is dry, come back with another coat of paint to lock in the sand and you have a great looking non-skid floor! And it's easy to repair/refresh when ever you need to.
<font color="blue">2002 F350 CC SRW 4x4 7.3 Powerstroke.
2 position chip from DP Tuner- 80 and 120!!
4" Exhaust, from the turbo, back to the 5" Chrome stacks!!!
4" Superlift front springs air bags in the rear and Bilstein shocks all the way around.
315 75 R16 Nitto Terra Grapplers on Ultra 181 Wheels.
Isspro EV Gauges...AIH delete...zoodad mod...Tymar air filter...FPR shimmed to 70 psi and a CCV mod. Custom $10.00 grill.
Cobra 29LTD Classic with a Wilson Trucker SW2000 mounted on a custom cowl antenna mount.</font>
My Pictures
wfdbackdraft is offline
Old 05-15-2005, 10:46 AM   #7 (permalink)
Take a look at THIS.
It's a lot cheaper than Rhino and will provide the protection that you desire. Plus, you can apply it up the walls a few inches to further seal the floor and it can be touched up if needed.
Capt Ron
May 2003 F-350, CC, DRW, 6.0L, 6sp man, LB, Al Wheels, Moon Roof, 52gal tranfer tank. Hitches: Draw-Tite 16K 4X and B&W GN, 8040lbs GVW. Towing 35' Newmar Kountry Star 5th Wheel Camper, 14,000lbs GVW, or Wells Cargo 24' Car Hauler, 12,000lbs GVW.
CaptRon is offline
Old 05-15-2005, 11:17 AM   #8 (permalink)
stickboy274's Avatar
We have a trailer we use for motorcyle roadracing. It gets 30 + weekends a year. We did the sand in the paint trick and it worked really well. You have to reapply a couple of times a year.
right now we have the wal-mart brand of roll in bed liner. It's not as good as the Hurculiner, but it's about a third of the price. The sand worked better though. It had better grip.
99 F-350 cc, dually, lb, 3.5" down pipe with 4" out to a ghetto 5" chrome tip. In tank mods, pre-pump, fuel lines, HX, open filter intake, reg. return. harpooned. 10k. Aux. trans coler with fan. Edge Evo 2
stickboy274 is offline
Old 05-15-2005, 05:20 PM   #9 (permalink)
THere are special floor paints available. You do not prime with these as the primer is too soft for it. I usually buy Benjamin Moore or Sherwin Williams. Otherwise, I bet herculiner would work great.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
