Old 11-26-2006, 08:45 AM   #1 (permalink)
Exhaust Brakes which one?
Ok, I've done some searching here but don't seem to find any specfic discussion related to exhaust brakes. So I'll pose the question who's using what brake and are they happy so far.
02 PSD crew SB SWR, Banks Monster exhaust Prodigy brake controller, 6gun tuner, Hypertech, air bags, Bilstien shocks, hauling 36' Tahoe Transport 14K 5er Toy Box
stevejd is offline
Old 11-26-2006, 09:44 AM   #2 (permalink)
Re: Exhaust Brakes which one?
I use the SP Diesel exhaust brake.
It works extremely well, have had it on since 03 with no problems.
I've installed four or five of these for friends and all are very happy with the brake.
It works very well with 15k+ on the back going down a 6% grade.
Saves alot on the brakes and the drivers seat with the pucker factor figured in.
I have nothing to do with the company other than being a very satisfied customer.
You can spend more on an exhaust brake but,,, why?
Later
Rich [img]/ubbthreads/images/graemlins/cool.gif[/img]
[img]/ubbthreads/images/graemlins/cool.gif[/img]<font color="blue">2K2 F450 CC DRW 430's, Auto, Manning Bed, Straight piped, 19.5 Alcoa, Grover Air Horns,</font><font color="red"> Isspro Digital Pyro</font>,<font color="green">Nordskog Digital Boost & Trans.gauges</font>,<font color="blue">DrawTite 5500 Digital Brake Cntlr.,Access Bed Cover,3" Level Kit, Xcursion Grill, TS Performance Flip Chip, Cowl Induction Hood, Car Wear Clear Tail Lites,Hayden Tranny Cooler,SP Diesel Exhaust Brake</font> Synthetics everywhere!! 41' New Vision Wide Body Toy Hauler,
01 Volvo 770 Toter
Fulltimer.[img]/ubbthreads/images/graemlins/cool.gif[/img]
http://enophile.blogspot.com/
Enophite is offline
Old 11-26-2006, 03:55 PM   #3 (permalink)
I was checking the SP site and I guess I don't understand how this is working. Is there no acutator valve that is place in-line with the exhaust? The pictures show only a circuit board and harness. Everything I've looked at so far as a valve system that is added.
stevejd is offline
Old 11-26-2006, 04:58 PM   #4 (permalink)
Without doing research, I would guess that they are using the back pressure valve to do the retarding. I had the Lang (sp?) kit on my 99 from about 5,000 miles until I sold it two weeks ago. I could gross 30-32,000# and come down the mountains 4-8% grades without ever touching the brakes. Remember that the retarding is in direct relation to the engine rpm's. Try to pick a gear that will keep the engine near the redline when you are using it to desend a mountain. That way you will get the maximum effect from the exhaust brake
2005 F-250 Torque shift, Hypermax programmer and 5" exhaust 70,000 basically trouble free miles
Sold '88 F-350 SRW 7.3
Sold 95' F-350 with 135K and 97 with 180,000K
Sold '99 F-450 with 130k Hypermax chip & exhaust
rrangus is offline
Old 11-26-2006, 06:34 PM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (33)
There are two basic designs for exhaust brakes.
The cheap kind are some electronic parts that let you close the stock exhaust back pressure valve (EBPV) to get some engine braking effect. These cost a few hundred bucks, depending on options, such as torque converter lockup capability. Examples are the SPDiesel exhaust brake already mentioned, the original design still made by TurboBrake - www.turbobrake.com - and the BD BrakeLoc. http://www.dieselperformance.com/for...oc&amp;tt=ford
The expensive kind have their own butterfly valve that goes into the exhaust pipe after the turbo. Those are great, but they cost over $1,000. Made by Banks, PacBrake, U.S.Gear, BD, and others. Here's the BD: http://www.dieselperformance.com/for...es&amp;tt=ford
SmokeyWren is online now
Old 11-26-2006, 07:24 PM   #6 (permalink)
So besides pricing what are the draw backs of the electronic versions verse's the Banks, BD etc which have been the ones I've been looking at.
stevejd is offline
Old 11-26-2006, 08:35 PM   #7 (permalink)
Cowcop's Avatar
Hope this helps....
When we used the electronic version that uses the warmup valve and were pulling our 7000 lb trailer , it worked ok. You would have to keep your rpms high to keep any braking effect. [img]/ubbthreads/images/graemlins/wink.gif[/img]
When we bought the 9900 trailer , this brake was all but useless unless you keep the rpms very high. [img]/ubbthreads/images/graemlins/eek.gif[/img]
As such , we bought the expensive BD brake and could not be happier. The brake is effective at all rpms , high or low. Very simple way to tow safely. [img]/ubbthreads/images/graemlins/cool.gif[/img]
99.5 F-350 S/C 4X4, 6 SPD.,BD Tow Chip,BD 4" Ex.,BD Guages, K&N FIPK & Wrap,BD Exhaust Brake(air activated),RANCHO 9000sx Shocks ,GENTEX Mirror ,C-Btr mirrors, ALPINE CD/Amps/CONCEPT Spkrs ,VIPER Alarm & AUTO LOC VIP System ,PIAA Lts. ,ALUMINUM tool box/dog kennel,cab guard & 5th wheel tailgate
OILGUARD Bypass Filter, DELVAC Synthetic Oil ,DIESELSITE Coolant Filter System & 203* THERM,Texaco Red Coolant ,ATS Turbo Housing,ITP Power Boost KIT ,ITP S.S HPX ,FCII tires on ULTRA MOTORSPORT rims ,TURBO MASTER Wastegate Controller ,BUSHWACKER Pocket Flares ,SPICER Ceramic Clutch ,FIRESTONE Air Bags & Compressor, MAG HYTEC rear diff cover, NC Hornet's CCV mod, ITP Reg. Return Fuel Sys.
Cowcop is offline
Old 11-27-2006, 11:31 AM   #8 (permalink)
Do any of you guys have an exhaust brake in a 6.0 psd? I have done a lot of research and I'm thinking of installing the BD brake. I have just never heard from anyone with experience with one.
2005 F350 6.0 PSD srw lb sc Zf6 speed
mods: BD exhaust brake- Dura flap mud flaps-Piaa back up lights-Wilson cell amp and antenna-Midwest short throw shifter--C-Betr mirrors-Burning B100
wdwkr is offline
Old 11-27-2006, 04:10 PM   #9 (permalink)
There are also two variations of the expensive kind of exhaust brake: fixed orifice and constant pressure. The fixed orifice ones rely on a fancy version of the EBV to restrict exhaust flow, and depend, again, on high RPM for any effect at all. The constant pressure ones have a blow-off valve and maintain max rated back pressure at any RPM (but are still somewhat RPM dependant - just a much flatter curve).
2000 F450 Lariat 4x4 tractor, Air Dog, Reg Mod, HX, bypass filter, Banks Power Elbow w/3.5 dp, no intake heat, CCV mod, AIS (w/extra hole), DI stage IIs, GP indicator LED, custom 4" exhaust, 4" USG exhaust brake, USG 0.8555 aux. trans. (shift switch in knob), custom air susp., custom alum. rear diff cover extension (dipstick & temp), Detroit locker, ESPAR D5 aux. heat, custom alum tow deck and fuel tanks, Bushwacker 1 1/2" flares, 9k winch, gin poles, Bi-Xenon in '03 Crystals, Lightforce Striker 170 (still Halogen, but VERY bright), Hella Micro DE HID fogs, KW (Isspro) instruments, more to come & lots of other diesels
Pat Dolan is offline
Old 11-28-2006, 04:52 PM   #10 (permalink)
I have the BD brake in my rig and it works well, I use it when pulling my trailer and hauling my camper. In 4 low, 2nd gear it has kept me at 7mph going down a very steep gravel road out hunting with the camper on, very cool. My coast clutch doesn't like it much if I'm going over 60 though.
1997 F350 Crewcab, SRW, 4:10LS, E40D, Banks I/C, 1.0 Turbo Housing, Custom Chip by DP Tuner, Tymar intake, HPX mod and race pipe, fuel shim, Sonnax Valve and Tricumulator Springs, TruCool trans cooler, BD exhaust brake. Six leaf rear spring packs, air bagsTruck Pics
rjlein is offline
Old 11-28-2006, 10:24 PM   #11 (permalink)
Roy_Boy's Avatar
Yes, I have a US Gear Super Duty exhaust brake on mine, it is great!
Just make sure you have a tuner that disables the EGR operation.
Roy_Boy is offline
Old 11-28-2006, 10:45 PM   #12 (permalink)
I have had a BD brake for several years, and it has worked flawlessly. I cannot speak for other systems, but I would run another BD brake again in a minute. The cost may be a bit high, but you get what you pay for.
jgr
Y2K F350, Ecab, LWB, SRW, 4X2, ZF6, Full Gauges, Ebrake, Chipped 271rwhp/584tq, Coolantfilter, fumoto valve, oil by-pass filter, CCV mod with return to intake, dahl 100, straight piped, PML cover, 203 stat and billet, AIS, Zoodad
pristine is offline
Old 11-29-2006, 12:40 AM   #13 (permalink)
Thanks guys. Thats just what I need to hear. My thought is these handshakers should come with one from the factory.
wdwkr is offline
Old 11-29-2006, 06:12 PM   #14 (permalink)
can the BD/Banks exhaust brake be used on the 7.3 IDI? i've heard you can't because of hyd. lifters. anybody know?
dontstop is offline
Old 11-29-2006, 07:04 PM   #15 (permalink)
Goiing out on a limb here but I am pertty shure that the psd has hyd lifters - or we would all be adjusting them once a month [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2000 F-250 supercab off-road 4x4 6-spd Diablo Sport chip, autometer boost & pyro, DIY Tymar, straight pipe dumping before the wheel
jprensink is offline
