What year did the F250 get a boost in the GVW rating from 8800lbs to something higher?
It was in CY 2004, but it was the 2005 model that began hitting the streets in August, 2004.
The 2005-up model comparable to your current 2002 F250 PSD 4x4 SuperCab Shortbox has a GVWR of 9,800 pounds. The 2005-up trucks are a little heavier than your older model, so you'd gain about 800 pounds of payload compared to your current ride when it was stock.
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; TurboRamAir intake and 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and TTM; AIC. I special-ordered it new and plan to drive it until it quits.
my 88 250 has the stock sticker on it for 9k its a 250 hd if that matters idk the things way past a 250 anymore but i got 550 springs and a dana 80 drw rear running singles and i usualy haul way over no problem again thats an upfitter thing i dont have paperwork for except their sticker i think they have it as 8k rear now as their modification (rear is braced and stronger than stock too i think)
thats usualy cheaper than a new truck
look at speed channel's website they have a truck show on there and they usualy have frankentruck in there it has a 550 rear in a350 for your body style you may want to do that
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
<span style="color: red">i have created a website for old ford diesels please check it out and tell me what you think</span> http://oldforddiesels.googlepages.com/home
woah...
so, yeah, there's a key between the ,and the /
Originally Posted by 88beast
my 88 250 has the stock sticker on it for 9k. its a 250 hd if that matters idk. the things way past a 250 anymore but i got 550 springs and a dana 80 drw rear running singles and i usualy haul way over no problem. again thats an upfitter thing i dont have paperwork for except their sticker. i think they have it as 8k rear now as their modification (rear is braced and stronger than stock too i think)
look at speed channel's website. they have a truck show on there and they usualy have frankentruck in there. it has a 550 rear in a350. for your body style you may want to do that
...for those of you that need the punctuation like I do...
'05 F-250 XLT 6.0 auto CC/SB 4x4 ESOF riding on BFG Rugged Trail's. Bone stock 'cept for the Sirius radio and tonneau cover 82k miles. Turbo replaced during previous ownership. HPOP fitting let loose, recall at 75k.
hey josh how much would you charge to follow me on the forum doing that i like it
srry I usualy change sentences with an enter, too much txting i guess
First time's free
Changing sentences with an enter would be a good start. I can read that
