Old 08-22-2007, 11:48 PM   #1 (permalink)
F250 vs F350
What is the main diff between my 99 F250 srw and a F350 srw. I have a set of leaf springs off a 2000 F350 and was wondering, if installed, would I be able to achieve the same payload capacity as a F350
1999 F250 PSD, CC, 4x4, Edge programmer
RAC400 is offline
Old 08-23-2007, 12:05 AM   #2 (permalink)
Re: F250 vs F350
Technically, yes. Legally, no. You are limited by the door sticker and what it says for a GVWR.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
NickKent is offline
Old 08-23-2007, 01:53 AM   #3 (permalink)
Re: F250 vs F350
350 DRW is a lot different.
From what I understand, a SRW 350 is a SRW 250 rated as a SRW 350.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
Old 08-23-2007, 10:03 AM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Re: F250 vs F350
Look at the spring code on the Federal Certification Label on the lower doorpost behind the driver's door. If the second letter is an "A", then your rear spring pack is rated at 6,084 pounds @ground. Code "B" rear springs on an F-350 SRW (and on some F-250s) are rated at 6,830 pounds @ground. So they are a little stiffer.
Your best bet to beef up the rear end of your F-250 is to install Firestone RideRite air bags. Then any time you have a load in the tail or a heavy trailer tied on, pump up the air bags until the headlights no longer point at the stars. http://www.fsip.com/riderite/
The F-350 SRW spring pack will fit. But so will the rear spring pack from the F-350 DRW. If you're going to beef up the rear springs, why stop at 6,830 pounds capacity? Go all the way to the 8,250 pounds @ground from the DRW.
But no amount of mods will change the GVWR of your pickup. Next time, buy enough truck for your needs. [img]/ubbthreads/images/graemlins/wink.gif[/img]
SmokeyWren is online now
Old 08-23-2007, 10:47 AM   #5 (permalink)
My Photos: (13)
Re: F250 vs F350
Why waste your time. Even with the spring up grade, you'll still exceed the GVWR. If GVWR doesn't matter to you, just exceed it with your current springs. Even with new springs, you'll hit the limit of your tires before you hit the limit of the springs unless you swap the tires out also.
Unless you're commerical and having to cross scales, don't worry about weights and when you need to haul something, load it and go. For short hauls, your truck will never notice it.
Ag__Teacher is offline
Old 08-24-2007, 07:52 PM   #6 (permalink)
DezRacer's Avatar
Re: F250 vs F350
Legally speaking, there is nothing that says the gwvr is legally binding to anything. The sticking point according to the vehicle code is the ratings of your tires. You cannot legally exceed this. Gvwr and Gcwr are simply mfg guidelines.
There is a great thread right now over at RV.net, in the fiver section called "ramnifications of towing overweight". The first six or seven pages are great info, then it kind of goes downhill.
On edit, I just went over to RV.net and could not find the thread?? Maybe it got deleted while I was out of town. The moderator did say if it went south it would be deleted without warning. I checked in 8 or so pages looking....
"I just want to be free, free to ride my machine, and not get hassled by The Man"
DezRacer is offline
Old 08-24-2007, 08:26 PM   #7 (permalink)
Re: F250 vs F350
The other thing to remember is if you change your tire size from what is on the sticker.... Your insurance won't cover you & your truck will be illegal. If you get caught at a scale or pulled over you will probably go to jail.
What Ford put on that label is *LAW* and you can't change or go over ANY of it.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
Old 08-24-2007, 09:36 PM   #8 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
Re: F250 vs F350
Absolute Nonsense!
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum.
Winter Operation (How I Do It)
Hard/No Start? Check here first
2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
Old 08-24-2007, 09:43 PM   #9 (permalink)
Roy_Boy's Avatar
Re: F250 vs F350
Leader better save up his money so he can bail all the rest of us out then [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Roy
2004 F350 super cab short box dually
One of a kind
6.0L, 6speed, 4x4, 3.73 axles
US gear exhaust brake
Custom SCT,tuned by Tadd
Engine#3- 6398 miles (still running great)
Haulin' More than most of y'all
02 VW Beetle TDI 5 speed
Roy_Boy is offline
Old 08-24-2007, 10:19 PM   #10 (permalink)
olddieseldude's Avatar
My Photos: (15)
Re: F250 vs F350
Absolute Nonsense!
I've got to agree! It may come to that some day (I'm hearing some European countries are regulating what you can change, or require you to get changes OK'd before you can drive the car on public roads.) but we're not there yet. The whole aftermarket industry would dry up and blow away if it were true.
If you get away from the "Tastes Great" Vs "Less Filling" part of the discussion from what I can tell, reading this forum over the last couple of years, there is no difference except Axles, springs, door plaques, and badging. The frames are the same.
olddieseldude is offline
Old 08-25-2007, 01:37 AM   #11 (permalink)
Re: F250 vs F350
WOW remind me not to go through his neck of the woods!!! If this was so the tire shops WOULD be just as responsible for installing the incorrect tires.
Wayne
yes some people think i am weird.. its what makes me interesting!
1997 F-250 HD, ext cab, short bed, 5 speed, 7.3 turbo, 3" downpipe, 4" custom built exhaust' Bullydog 4 position chip, egt and boost guages, Bean 160cc stage 1 injectors. Single Mass Flywheel conversion.
bigblueskies98 is offline
Old 08-25-2007, 03:54 PM   #12 (permalink)
Re: F250 vs F350
Makes as much sence as that statement.
If one thing on the sticker is *LAW* then it ALL is.
Leader is offline
Old 08-26-2007, 04:55 AM   #13 (permalink)
Re: F250 vs F350
I think it's hilarious how so many people think the GVWR on the sticker is law. Those are manufacturer recomendations ONLY. So long as your running under 26001 Lbs, it doesn't matter(legally speaking). The highway patrol isn't going to weigh private vehicles because there isn't any money in that and it would be a big waist of time. Commercial vehicle's is where the money is at.
'96 F250 Ext Cab XLT, 4X4, 5spd, 3" Down Pipe, 4" Exhaust, Tymar Intake, Single Mass Flywheel, Bully Dog Programmer, Boost and Pyro gauges. 81,000 miles.
bryanpickle is offline
Old 08-26-2007, 09:52 AM   #14 (permalink)
Rich_Kimball's Avatar
Re: F250 vs F350
Poor guy. All he wanted to know was could he put on F350 springs. Sure ya can! But being 2000 model springs, they may be a little weak. A spring shop man told me that for every year installed springs lose 5% of their effectiveness. If you're running E tires and put those on, up to 7K lbs on the rear axle. At least that is what my SRW F350 is rated for, and I have crossed the scales with some heavy loads and fuel at 6850. Mind you, I do have rear air bags too just to firm things up a bit!
Happy trails,
Rich Kimball
2000 F350 XLT CC LB SRW 6spd 4x4 Toreador Red @375,750 miles
'08 Center Console,Ranch Hand Grill Guard, SBC ConO clutch w/Kevlar Bushing, DP Tuner (60T,80E,120R),Gauges,Ford AIS,Walker BTM,AIH delete,HPX Oil Crossover, Wicked Wheel,TurboMaster WG Contoller,Riley BRV+,Riley Boost Boots,EBPV Gut w/mod. pedestal,IH Bellowed (donut less) UpPipes,Final Charge ELC coolant (for 300K miles-THX Gooch)w/heater bypass,Riley Coolant Filter,Ford AIC,Centramatic Wheel Balancers,115gal Aux tank,Firestone airbags w/cab control. Oilguard Bypass Filtration,DFA 'Cross Connect' Fuel Lines,DI Engine Mount FP Gauge (which is broke and nobody cares. Will never buy from DI again)
Rich_Kimball is offline
Old 08-27-2007, 03:10 AM   #15 (permalink)
Re: F250 vs F350
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Leader</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">Technically, yes. Legally, no. You are limited by the door sticker and what it says for a GVWR. </div></div>
If one thing on the sticker is *LAW* then it ALL is. </div></div>\
Nothing on the sticker is law. If you're not a commercial vehicle then there are no laws stating what you can and can't do. Even if you are commercial you aren't bound by what's on the ticker, you're bound by what the commercial laws are.
Many factory rear axle ratings are the capacity of the tires, not the ratings of the springs or the rating of the axle assembly itself. In most cases you can safely put on higher rated tires.
'96 F250 S/C 4x4 4.10 auto, Tymar intake, 3-4" DP 4" exhaust, Edge Evolution, Hypermax IC, Autometer gauges, Hayden 679 trans cooler, Airlift bags w/compressor and in-cab controller, built trans from KTS, Rancho 9000's, 19.5" rims and tires.
'97 F350 C/C 4x4, 3.55 auto.....just starting to mod
Lance 921 camper, 9.5' w/slide-out
'88 Jeep Cherokee, 4dr pick-up conversion rock crawler, D44/D60, Warns, CTM's, 37's, etc.
rocknxj is offline
