Old 07-09-2007, 01:28 AM   #1 (permalink)
Factory Brake Controller
Hello - I have a 2008 F350 PSD Lariat on order with the TowCommand factory brake controller. How good is this factory-installed controller? I've read other posts with people recommending Prodigy or Brakesmart. How does the factory controller compare to these? I plan to order a Jayco Designer 5th wheel next spring (10680 lb dry weight, 14500 lb GVWR). I just want to make sure the factory controller can keep my family safe.
Thanks!
Gary
2008 F350 Lariat SRW SWB CC 4x2 PSD Auto, Oxford White with Pueblo Gold Trim
GWBlack is offline
Old 07-09-2007, 09:26 AM   #2 (permalink)
Re: Factory Brake Controller
Thanks!
Gary
Do a search; I think you'll find almost everyone that has Tow Command loves it and wouldn't trade it for anything. I have a Prodigy because my truck didn't have Tow Command, but if it did I wouldn't replace it.
2004 F350 Crew XLT 4x4 long box, SRW, 3.73 Gears
Bone Stock
newtodieseling is offline
Old 07-09-2007, 10:24 AM   #3 (permalink)
Also, visit rv.net and look into any 5thwheel forums. Personnally, I'm not seeing any complaints. Just one post on here where the guy said his trailer's hydraulic system wasn't compatabile. I know of one guy who's towing a Hitchhiker with disc brakes & using tow command and he's not having any problems. David
2001 F250, Lariat, PSD, 4X4, Crew Cab, Off-Road pkg, trans temp & egt gauges, Bilstein shocks, otherwise stock.
davydee is offline
Old 07-09-2007, 03:38 PM   #4 (permalink)
overfly's Avatar
My Photos: (16)
Best brake controller I've used [img]/ubbthreads/images/graemlins/grin.gif[/img]
2006 F350 - Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
overfly is offline
Old 07-09-2007, 04:30 PM   #5 (permalink)
The factory controller works very well for me. Best I have ever used. It is in a convenient place. Which makes it easy to adjust and God forbidding you ever have to slam on the trailer brakes it is within easy reach.
2005 F350 6.0 PSD srw lb sc Zf6 speed
mods: BD exhaust brake- Dura flap mud flaps-Piaa back up lights-Wilson cell amp and antenna-Midwest short throw shifter--C-Betr mirrors-Burning B100
wdwkr is offline
Old 07-09-2007, 07:15 PM   #6 (permalink)
Since this will be my first SuperDuty, my first diesel and also my first 5th wheel, I have a dumb newbie question. Once I adjust the brake controller properly, why would I need to re-adjust it during an emergency maueuver? Due to the "proportional" control, won't the braking effect be increased automatically during an emergency stop (due to pushing down harder on the brake pedal)? Or is that something I will always need to do manually? I'm concerned that maybe I won't remember such things under the stress of an emergency maneuver.
Thanks!
Gary
GWBlack is offline
Old 07-10-2007, 12:50 AM   #7 (permalink)
Not sure what he meant by that--it works fine in my '07 with a very heavy trailer. It is easy to reach and adjust, but you don't need to adjust it after it is set to the trailer and how you like it to feel.
It does not work well with some of the new trailers that have electric over hydraulic brakes. It should work fine also with the Jayco, unless they have upgraded the brakes to elec/hydraulic.
2007 F350 KR DRW CC 4x4.
2005 Mobile Suites 36TK3
wingnut60 is offline
Old 07-10-2007, 01:41 PM   #8 (permalink)
What I meant was if the trailer ever became unattached from the truck you can use the manual slider to stop and or get the trailer back under control. Also if you ever have the trailer fish-tailing you can use the manual slider to stop the sway. Think of it this way, If you slam on your brakes and the truck brakes heavier than the trailer you will see the trailer driving by your window. I also adjust my trailer brakes according to the load in the trailer.
wdwkr is offline
Old 07-10-2007, 11:49 PM   #9 (permalink)
I have had the Prodigy and the factory brake controller on two similar trucks, the Tow command works much better and smother than I could get the Prodigy to work. It uses the brake pedal pressure and the computer rather than relying on inertia to operate the controller. THE ONLY REASON I use the slide switch is to set the voltage on the controller
first_ford is offline
Old 07-11-2007, 06:08 PM   #10 (permalink)
If you do a search on this topic you'll find where some guys had weird unresolved problems with certain trailers and ended up swapping the ITBC with Brakesmart or other controllers but those cases were minimal. There was also problems with the early 05 vehicles in that you couldn't manually override the ITBC under 15 MPH which means you couldn't do a test pull when hooking up your wagon, but that's been resolved. Mine works great, no problems with anything I've towed with it. Just plug in, set the gain and go.
2006 F-350 DRW, 4X4, 6.0L PSD, 4.10 LS, Tow Command, Reese 15K, Firestone Ride-Rites, Auto Meter 3 guage A-pillar mount, American Tank 45 gal. aux. tank/toolbox, Rhino-Liner, Pro-Flaps, C-Betr mirrors.
2004 Cardinal 33TS LX 5th wheel
truck pics
2004 Cardinal 5th Wheel pics
Fordman6 is offline
Old 07-12-2007, 02:35 PM   #11 (permalink)
Thanks!
Gary
Caugh, caugh! Cequent = Tekonsha = Prodigy = Factory contract for Tow Command = Same quality = Good System.
Darrick S - TDS Sponsor
Southwest Wheel - Serving the wheel, trailer, and towing industry since 1919.
darricks is offline
Old 07-12-2007, 03:30 PM   #12 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
[/ QUOTE ]Cough Cough. Not as good as BrakeSmart! Cough Cough.
haul_n_horses2 is offline
Old 07-12-2007, 04:02 PM   #13 (permalink)
Cough. Cough. Questionable, but the MaxBrake is.
darricks is offline
Old 07-12-2007, 04:49 PM   #14 (permalink)
My Photos: (17)
From what I can tell the MaxBrake is just a poorly finished knock off of the BrakeSmart. Time will tell if it functions as well with a wide variety of trailers/brake systems. I just know that hooking up to an electric brake trailer, there is just one push of the button and the gain is automagically set. Works very slick. No calibrations to perform as on the MaxBrake. Then when I go back to my electric over hydraulic there are no re-calibrations. Just plug in and go.
Old 07-14-2007, 09:56 PM   #15 (permalink)
I had a BrakeSmart in my 2002 and it performed flawlessly. I've had towcommand ITBC in my last two trucks. I still like the BrakeSmart better, but not enough to consider swapping it out. They are both proportional controllers ran of the brake system's hydraulic pressure. The one gripe I still have with Ford's controller is it's diminished output at lower speeds.
--Chad
Cincy, OH
<font color="blue">- 2008 F250, 6.4, 4x4, XLT, SC, LWB, DK Shadow Grey, Rapid Heat, Autopage 2-way Remote Start/Turbo Timer</font>
Glow_Plug is offline
Not a member
