I have an 01 F350 PSD dually with the factory rec. hitch. The truck only has 64K miles. About 5K of that has been towing my 28' enclosed race car trailer. The loaded trailer weighs about 10K lbs. I use a Valley WD hitch w/ round bars.
I have noticed that the hitch pin hole in the receiver has become wallowed out. It's not bad, but enough to have a "clunk" when starting and stoping. It's worse on one side (side with the bent end of the pin). The locking pin (Fulton brand) is not hurt other than a little rust. I guess it's hardened. Likewise, the Valley tube is not hurt. It's solid and the hole is ok. The "wallowed out" gap is about 1/8" on one side and 1/16" on the other. I normally leave the WD hitch in place when not towing. It has saved me from a couple of rear end collisions. Does leaving it in place and bouncing around cause the wallowing of the hole?
1. Is this a common problem?
2. Do I need to replace the hitch?
3. Are there any repair kits available? It seems like you could drill the hole a little larger and weld in a hardened bushing of some type.
4. What are some good brands of hitch if I need to replace it? The local truck acc store carries "Curt Mfg". I want one that bolts in using the factory holes. Any brands to stay away from?
5. Since my WD hitch is 2" shank I guess I need to stay with a class IV. What is the highest rated class IV out there?
Sorry for so many questions, but I thought I would ask the experts.
Dave_C
2001 F350 XLT, SC, DRW, PSD/Auto, Torredor Red/Medium Graphite cloth, 4.10LS, Westin step bars, Pendaliner, Better Built toolbox, stock powertrain For Now
I had the same thing happen but maybe not as much as you describe. I went to Lowes and bought a cheap bronze bushing to slip over the hitch pin. The bushing keeps the bent part of the pin away from the hole. I did not have to repair or replace the actual receiver.
FWIW - Frank
2002 F-250 4x4 XLT CC PSD 6sp
ISSPro Gauges, pre-pump, Walker BTM, Fumoto
PopUp GN Hitch
Cougar 304BHS TT
I would start using a grade 8 bolt. Tighten it down fairly tight. The added friction of the receiver being pinched should eliminate your "slop" problem.
Now if you live in a northern rust belt climate I would recommend some anti sneeze on the hitch tube which will negate a bit of the added friction but it will make removal much easier.
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
I've got an 02 Dually pulling a nearly identical trailer. I am using a draw tite WD hitch. Mine is the exact same way. It has play and I hear it when pulling. I remove the hitch all the time so I don't think that is your problem. I am not worrying about it until it gets worse or bothers me more.
Tom
02 CC XLT Dually 4x2, PSD w/6 spd, White w/Med Flint 40/20/40, TTT Mirrors, 4.10 L/S, PCM=AEB4, Receiver, Cab Steps, Homelink X Visor, Husky F&R Mud Flaps, AIS Ford Filter, WD Pyro & Boost in A-pillar, Line-X, Hutch Tank Mod, Pre-Pump Racor 645R30, 4" Banks Monster Exhaust, Mag-Hytec Diff Cover, Amsoil in Tranny & Diff.
Bye-bye 99 diesel-sucking automatic!!!
That's caused by not enough thickness in the side wall of the receiver tubing.
Most good receivers will weld a 1/4" x 2" washer on the outside of the receiver tube when mfg. You would need a 1/2" x 2" on your existing receiver.
You will also need to replace your hitch pin every couple years for typical pulling and every year if commerical pulling. The pins do work harden and will shear if given enough time.
The strongest commerical made is a 2-1/2" receiver rated at 14000GVW.
After making my own custom hitching, the receiver design is at it limits at about 15000GVW. I increased my pin to a 3/4" pin on this last rebuild and even that was not enough with about 22kGVW on farm use as I still offset that 3/4" pin.
Every trailer I own now is 5th wheel for that very reason. I also converted my GN to a king pin.
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run Define Union: A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
