Old 03-13-2006, 07:03 PM   #1 (permalink)
Fifth Wheel Hitch & Firestone Air Bag Question
Hey Guys
i have the air bags installed on my 99 F250 short bed 4x4. I am looking to get a fifth wheel camper.My question is what fifth wheel hitch installs and will not interfere with the already installed air bags?
thanks in advance
FordPwer..
2005 F250 V10 AT, 4WD CC.
2005 F150 4.6L
2002 GT Stang
2006 500
64frdpwr is offline
Old 03-14-2006, 07:12 AM   #2 (permalink)
Re: Fifth Wheel Hitch & Firestone Air Bag Question
ttt
2005 F150 4.6L
2002 GT Stang
2006 500
64frdpwr is offline
Old 03-14-2006, 08:15 AM   #3 (permalink)
My Photos: (11)
Send a message via ICQ to Fishhook
Drawtite doesn't interfere with mine but I got an OBS and yours is a newer one.
Greg
96 F250XLT,SC, PSD Hooked to a BTS Tranny, LWB 4x4 (4.10s), D60 Straight axle conversion, Isspro Triple A-pillar Guage Pack, Mag-HyTec Axle Cover and a few others.
My Truck
Pics Of Truck Stuff
Fishhook is offline
Old 03-14-2006, 08:28 AM   #4 (permalink)
I think it is the other way around.
I believe you order the bag kit for the hitch equipped truck instead of the hitch for a bag equipped truck. Don't know for sure????
Firestone should be able to tell you but it seems that the kits(bags) say "Reese" on them.
Edmguy
2000 F-250PSD,White,Crew Cab,Shorty,4X4,6 Speed,Luk Clutch,3.73Ls,DP-Tuner F-5 with 16prgms,Tymar Intake,Non-Wastegated Van Turbo w/ATS housing & Stock Wheel,4in Exhaust From Turbo,Zoodad,CCV Mod,ITP SS HPX Line,AIH Delete,ITP Regulated Over-Boost Eliminator,Autometer x3,Fabtech 4inch Lift,Bilstein 5100's,Eagle Alloys 16x8 w/Pro-Comp All-Terrain 35's,Powerslots w/Hawk Pads,Valley 16k Slider 5th-Wheel Hitch,$30 Custom Grille,100,000miles
325hp/721tq 4/06 on Dunbar's Rollers
Towed Item :2004 Cedar Creek 36'BB2S Bunkhouse Fifth-Wheel (12,500lbs)
<font color="blue">My Truck & Fiver :</font>
Click Here
Spare Time Activities:MHFR
<font color="red">Can You Keep Up?</font>
edmguy69 is offline
Old 03-14-2006, 11:02 AM   #5 (permalink)
thanks guys
2005 F150 4.6L
2002 GT Stang
2006 500
64frdpwr is offline
Old 03-14-2006, 05:57 PM   #6 (permalink)
Called tech support at Firestone ride rite...they were absolutly no help; the guy said he did not know and did not even offer to look into it. Gee this is the kind of service you can get anywhere...
2005 F150 4.6L
2002 GT Stang
2006 500
64frdpwr is offline
Old 03-14-2006, 08:35 PM   #7 (permalink)
I've never had a problem with any of the rail mounted 5th wheel systems ( Valley, Reese, Drawtite ) interfereing with an airbag installation on a newer Ford truck. This is assuming you're going to use the standard "L" brackets to tie the hitch to the frame. You won't be able to use the pre-fabbed mounting plates that most hitch makers offer these days, as they go right across where the airbags are mounted, but this is no big deal. Hitch installers have been using L brackets for years and just drilling the required holes themselves.
2006 F-250 4X4 Lariat, C.C. / SWB -- Torreador red
PerryB is offline
Old 03-15-2006, 11:24 AM   #8 (permalink)
I also called Firestone tech support about Ride-Rite air bag spacers for my lifted truck and got the wrong advise and the wrong part number and ended up fabing up my own spacers out of alum. and eating the cost of the advised ones. Restocking and shipping almost cost as much as the spacers themselves. [img]/ubbthreads/images/graemlins/mad.gif[/img]
2005 F-350, 6.0 PSD, Lariat,4x4,CC,LB,Torqshift,7" ProComp StageII Lift,MX-6 Reservoir 6 Way Adjustable Shocks, 37" BFG M/T, 18" Mazzi Hulk Wheels, Duel Steering Stabilizers, 6 Piece Billet Grille, Isspro 3 Guage A-Pillar, AFE SS 4" Turbo Back Exhaust, 4:56's, Firestone Air Bags, SCT by ID
desertsands is offline
Old 03-15-2006, 05:29 PM   #9 (permalink)
I think the b&amp;w turnover ball and companion fifth wheel will work with air bags. Although unless you have a long bed truck then the companion 5ver hitch will not work because it doesn't slide.
2001 F-350 PSD Lariat CC 4x4 LB Auto, 5" flo-pro twister race muffler, isspro pyro, boost, and tran gauges on a-pillar. DP-Tuner (stock, 40, 60, 80, 120), Cobra 29 CB with 4' Firestik, Prodigy Brake Controller, Tru-Cool 4739
RTRF350 is offline
Old 03-15-2006, 10:42 PM   #10 (permalink)
[/ QUOTE ] You mean shortbed, right?? [img]/ubbthreads/images/graemlins/grin.gif[/img]
2000 model Red GMC 3500,DRW,2WD,Reg cab,5.7 V8,auto 8'5" J&I flatbed. 1982 white Ford F-100, reg cab, shortbed, 3.8 V6, 3 speed on the tree.
StuMas is offline
Old 03-15-2006, 11:10 PM   #11 (permalink)
64frdpwr,
If you have the outboard mounted airbags, it might interfere with the fifth wheel hitch. The ones I bought go inboard of the frame, and are made specifically for 5th wheel applications. I ended up not using them since I have an '06 with the staggered shocks, and one of the axle mounts for the airbag need a little grinding, I decided to go with the Timbren SES system.
Red
2006 F350 Lariat, CC, LB, 4x4, 6.0L PSD, Automatic, ESOF, Camper Pkg, FX4 Off Road pkg w/sticker removed, Rancho RS9000X's, Tow Command Pkg w/12.5K factory hitch, Line-X bedliner, Ride Rite 2400's in rear, MBRP Exhaust, DiPricol gauges, 57 gal Transferflow midship replacement tank, Excursion dual-flap sunvisors, Nfab steps
'89 Ford Mustang GT, Sportsman 351 w/Vortech S-Trim, ported Edelbrock Aluminum heads, etc.
red3171 is offline
Old 03-16-2006, 12:56 AM   #12 (permalink)
I use the Companion in my SB all the time.
This space intentionally left blank.
444turbodiesel is offline
