Old 06-18-2007, 06:00 PM   #1 (permalink)
iwejun's Avatar
Fifth wheel tires
I need to replace all four tires on my fifth due to it's encounter with a tornado on March 13th (Friday). I'm having a heck of a time looking for different types. I need a ST 225/75/R15, I would like an 'e' rated if possible since loaded I'm around 12k. Where do I start looking, I know I don't want Carlisle, but Michelin doesn't seem to have that size and Goodyear Marathons look on spec to be too light. Any suggestions would be great, just suggestions I don't want a brand war. TYIA
07' 6.0 Lariat,350, DRW,CC boney stock
Pullrite Superglide, Sandpiper 32BHSS Platinum
2007 Four Winns 224
" LET'S ROLL !" Todd Beamer-Flight 93
iwejun is offline
Old 06-18-2007, 06:52 PM   #2 (permalink)
Re: Fifth wheel tires
Maxxis trailer tires come in that size with a 10 ply rating or 2830 lbs. per tire. I have a friend that has had good luck with Maxxis, in fact he just put on his second set.
2000 Excursion Limited 2x4, 3.73 LS,PSD/Auto,ATS turbo shroud,Badging,BullyDog 4" exhaust,AIS,HX crossover,ISSPRO gauges/A-Pillar,SuperChip 1705, Pre-Pump & In-Tank Mod,Banks TransCommand, ZooDad, Baldwin Oil ByPass,Ford AIC, F350 rear springs, Helwig Rear Sway Bar,Michelin's LTX MS
2003 Sunnybrook/Mobile Scout & Hensley Arrow
sail684 is offline
Old 06-18-2007, 09:45 PM   #3 (permalink)
I just put the maxxis 225/75/15 radial on my trailer e load rated radial you can get them at discount tire for 107.00 before mounting and balancing
2000 F250 4x4 Supercab Lariat, Leer Topper Waag brush guard,ATS ported turbo housing, hypertech hyperpac programmed, S&B air intake,5 inch turbo back exhaust, EGT and Turbo gauges installed, Alpine Head unit and amp, Boston Acoustic Speakers JL Audio Stealthbox . Nicknamed "Elvis" by my brother cause its big and white and you can't always tell where its gonna be seen
texasbyker is offline
Old 06-18-2007, 09:48 PM   #4 (permalink)
My Photos: (28)
I have replaced two of my four tires with Cooper Trailer tires and have had them for 3 seasons now. I love them and can't imagine anything *better* so far [img]/ubbthreads/images/graemlins/cool.gif[/img]
'97 F250 XLT, PSD, Ext Cab, E4OD, 4.10, TYMAR 4 position flip CHIP, BD Downpipe, Isspro pyrometer pre-turbo, AutoMeter tranny gauge, info@TymarPerformance.comTymar air, Tymar coolant filter, and Tymar HPX mod, ported wind deflector, 4" Exhaust, 4" kitty, Hayden tranny cooler w/in-line magnetic filter, Sonnex Valve, Tricumulator Springs, BMM tranny pan Summit Racing, Synthetic ATF, DYNAMAT, AC Mod, Bilstein Shocks from Eshock, Joe Servo IDM Mod, rhino bedliner, custom wheels, Lil' Rocker 5er hitch, 26.5 Prowler LE
RALLY
Roger45 is offline
Old 06-18-2007, 11:57 PM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Cooper Custom Trailer Plus is probably the best on the market, but they cost an arm and a leg and your firstborn son. Plus they come in one size only: ST225/75R15D. Click here.
I had to replace a trailer tire several hundred miles from home on a Friday night, and all they had was a Denman. So I bought it. It's been an excellent trailer tire, so when another trailer needed tires recently, I ordered 4 of them in size ST225/75R15E. They're a lot less expensive than the Coopers. Denman also makes a bias ply trailer tire, but not in load range E. http://www.denmantire.com/catalog/Trailer.pdf - then scroll down to the radials.
SmokeyWren is online now
Old 06-19-2007, 12:26 AM   #6 (permalink)
I cannot vouch for overall quality of the Carlisle tires, but I had one blow-out and I wrote to the company to find a dealer locally so I could keep the set matched. Apparently they must of had an issue with them, and sent me 7 new radials right away, no questions asked. Because of there customer service I will look at replacing them with new Caarlilse, if they actually let me know of a local dealer.
first_ford is offline
Old 06-19-2007, 01:44 AM   #7 (permalink)
Willie's Avatar
Cooper tires for 3 years now [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Bob
My Pictures
1984 Bronco II 4x4 day to day driver : Winter
2005 Explorer Sportrac 4x4 day to day driver : Summer
1991 F350 / Crew cab , Engine 7.3,E4OD tranny. No Turbo but has propane and pyro gauge. The truck is American, complete with a Miles per Hour speedo. Digital trans. temp gauge and voltmeter. Front Captain seats. Control switches for DRL's , Fog lites, High speed idle, Engine kill and scene lites. On board " York " compressed air, Air horns and built in hose reel behind the rear seat. Power bar distribution box from a 1999 Ford Explorer . Checker plate running boards and Frieghtliner mud flaps. LED turn signals in the factory mirrors. DC to AC inverter to run the coffee maker <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Soon to be updated with more toys as time & $$$ permit. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Willie is offline
