I am not familiar with the numbers you gave but I bought the Firestone air bags for the rear along with the pump kit so that I can adjust the air pressure from within the cab.
I purchased mine in 1999 and installed them on my old '87 F250 Light Duty which needed them badly.
I then moved them to my 2000 SD a year later.
They have worked very well for me and are still going strong.
Matt
2000 F250 PSD SC SB Lariat 4x4 Auto Bright Amber
LT265 Turbo Temp Montior
ARB Lockers on Front and Rear
AIC, Air Bags, Jordan Ultra Break Controller
Velvet Rides
I was wanting to buy a B&W hitch but dont want to drill for the air bags. I might make my own hitch out of 6x6x1/2 angle and a piece of 6'' channel. I would bolt the hitch on using 3 factory holes on each side and then weld the air bag brackets to the angle iron side plates.
2002 XLT 350 crew cab white
am/fm/cass/cd 4x4 auto
carpet delete 265/75/16 3.73
limited slip 9900lb package
X springs ranchhand bumpers
B&W hitch
Firestone airbags & compressor
Rancho shocks 136K and all stock
According to Fyrman, there is no problem with the B&W hitch and the Firestone Ride Rites 2330s which mount inboard of the frame. No drilling of the frame required. However they will not work if you have an aftermarket 4" exhaust without some serious compression of the exhaust with a calibrated 3# hammer. I chose to drill myself as I did not want to defeat the purpose of the exhaust.
Thats the same thing I dont want either. I just dont want to drill into the frame. I could make my own hitch and weld the upper bracket from the 2071 kit to my new side bracket which I plan on bolting on using three factory holes
B&W hitch
If you have the bigger exhaust, go with the drill kit. It will work, without welding, with little modification. I've done it. Lots. With the 1199 hitch. The 1198 hitch is designed with flat sideplates. The upper brackets for the airbags fit with no problems. The 1105 hitch replaces both of the before mentions hitches. It is designed after the 1198 so that the drill kit will fit, no problems. Just remember that when you go through the hitch, the bolts that come with the airbags are not long enough. You will need to pick up eight, grade 8, 3/8" bolts. Half inch longer than what comes with the bags.
If you have stock exhaust, go with the 2330 no-drill kit. Be aware that the no-drill kit number changed for '05. The bumpstop design changed between '04 and '05, so the upper bracket changed.
But the problem I face is I dont want to drill my through my frame
[/ QUOTE ]What about my post did you not understand. If you use the Firestone Ride Rite 2330 kit, you do not need to drill anything. Go here and look at the instructions.
'03 F250 CC 4x4 PSD 7.3L Auto
AFE Stage 2 Proguard/Zoodad
4" exhaust
Isspro 3 guage pillar
boost relief
AIH delete
DI 6 Position
ATS Housing
firestone air bags
coolant, trans, oil bypass
transgo shift kit
royal purple front to back
Tru-Cool Max
Home away from home: '02 Montana 3295RK
