Old 12-28-2006, 10:14 AM   #1 (permalink)
Firestone air bags and the compressor kit
I got a ste of firestone air bags and the compressor kit for Christmas and was wondering where people where putting the compressor at. I would also like some ideas where to mount the gauge?
2002 XLT 350 crew cab white
am/fm/cass/cd 4x4 auto
carpet delete 265/75/16 3.73
limited slip 9900lb package
X springs ranchhand bumpers
B&W hitch
Firestone airbags & compressor
Rancho shocks 136K and all stock
1999 Case IH C50
2007 Cougar 302RLS
millwrightdude is offline
Old 12-28-2006, 01:18 PM   #2 (permalink)
Re: Firestone air bags and the compressor kit
Mine isn't the one that comes with the kit, but it's probably similar.
It's mounted above the spare tire on the inside of the frame rail. I made an adapter out of steel plate with tapped holes to match existing holes in the frame. Mounted the compressor to the plate with its own set of tapped mounting holes, then mounted the adapter to the frame.
Plumbed it, wired it, sprayed the mount & bolts with undercoating, put the spare back. Haven't seen it for at least two years.
Art
2000 F350 7.3 PSD 4x4 six-pack dually. All Stock.
Ride Rites with "Big Red" on-board Compressor.
DynaTrac Free-Spin conversion.
Hellroaring Battery Isolator for house batteries.
Flex-A-Lite 900 CFM tranny cooler (for those special 100 Deg./5 MPH-traffic
Florida days) with Magnefine filter.
FleetGuard coolant filter.
Mod Photos
AE Plots
Sun-Lite slide-in camper Plus 31-foot Holiday Rambler TT.
artkelly is offline
Old 12-28-2006, 04:22 PM   #3 (permalink)
My Photos: (6)
After I moved both Optima batteries to the passenger side I had tons of room to install the compressor, pump for water injection and fuse panel on the drivers side.
2007 CC LWB Lariat, 6" Fabtech,dual Bilstein w/res front, Bilstein rear,dual stabilizers,35"BFG M/T
2001 CC LWB Superduty 4" lift,35" BFG M/T,Bilstiens,Tymar,SuperDuty Air Bags,4" Exh,CCV mod,DP Tuner 6 position chip,Snows Water/Meth Injection,BD exh brake,BD Torqloc,Autometer Phantoms in pillar,Wicked Wheel,PML trans/diff covers,fumoto valve,Suncoast trans/triple lock,12,000# Warn,Alpine,Sony,))XM((,dual Optimas on passenger tray...(spare CPS in the glovebox)
Intercooler wrap removed/painted
My Pics
genesiscom is offline
Old 12-28-2006, 05:02 PM   #4 (permalink)
I removed the drivers side battery and air intake assembly and mounted the compresser and relay to the cross frame that holds the radiater. The only problem appeared when the drivers side headlite burned out and I had to remove the relay to get the the light to change it. Hope this helps.
Paul
Keep on stroken
2001 F250 CC SB AT Box Stock, for the time being. 6.0 Trans cooler installed.
loganhauler is offline
Old 12-28-2006, 05:15 PM   #5 (permalink)
Phil G.'s Avatar
It will slide right into the black plastic tray behind the rear seat; assuming crew cab. Then the line to the bags can go out thru the rubber grommet on te back of the cab. The lines to and from the dash can go under the door sill plates. this has worked for me in all three trucks. The compressor still looks new, because it's not out in the weather. I also bought a surplus refrigeration tank for $30 and it friction fit into the tray right beside the comp.
<font color="#313F64">http://www.philztruck.piczo.com/</font><font color="red">font>
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4.Viper VX790 Alarm/RS w/motion sensor, WD pillar Guages,Alpine W205 DVD head unit with Blackbird 2 GPS, and Parrot Handsfree Blueooth + 7" O/H Monitor,Sirius plug in receiver, Kenwood KAC-8492 720w 4ch Amp driving Infinity 6010CS 6.5" components up front and Infiniti Kappa 62.7i 6.5" 2-way in rear doors, Infinity 611a Class D mono amp driving 2- Kenwood W2509 10" subs in custom box Cobra night-watch w/ dual wilson 2000's, 100gal polished alum fuel tank, Reese 5th hitch, Anderson Tool aluminum TT hitch, Bremen full glass running boards, painted mirrors, grille, door handles,valence,wiper arms,RamMount laptop mount,
SOLD w/ 155,000KM - 2004 F350 SRW 6.0L 172"WB Loaded Lariat
SOLD w/ 120,000KM - 2003 F350 SRW 7.3L 172"WB 10/02 Build Loaded Lariat
SOLD w/ 303,000KM - 1999.5 F250 7.3L 172" WB 6/99 Build loaded Lariat
Phil G. is offline
Old 12-28-2006, 08:05 PM   #6 (permalink)
I just sold my 2005 F250. Compressor &amp; tank were mounted inside toolbox. Gage &amp; valve were mounted inside center console. Keep in mind, if you mount the compressor inside the cab it is a little noisy. If you mount it outside the cab, it can pick up debris.
2007 F350 6.0 CC FX4 Lariat LB DRW 4.10: Dark Stone/Arizona Beige, Camper Package.
Add-ons: Eclipse AM/FM/CD/DVD/NAV, XM SkiFi2, Bed by Cajun Coatings, WeatherTech Bugshield/Deflectors/Mats, Husky Splash Guards, 6 piece Billet Grill, Draw Tite 20k hitch, Ride-Rite bags, Air Compressor, (2) Hadley 29" Air Horns, Inverter, MBRP 4" turbo back w/ 5" angle tip, EDGE Juice/Platinum Attitude
Mods: BCP
2007 Holiday Rambler Next Level 37CK 5th Wheel Toy Hauler
3 dogs & 2 birds (Yes, they all travel with us)
mjarx is offline
Old 12-28-2006, 10:04 PM   #7 (permalink)
I dont like the idea of the compressor being inside the cab. I was hoping to put it under the hood somewhere. I would like to here from others where they mount their compressor. I think I might try to mount the gauge and switches on my AIC bracket.
B&W hitch
1999 Case IH C50
2007 Cougar 302RLS
Old 12-28-2006, 10:24 PM   #8 (permalink)
Do you have a toolbox in the bed?
Mods: BCP
mjarx is offline
Old 12-28-2006, 10:36 PM   #9 (permalink)
Banned
Like others have said, mounted both Optimas on the passenger side. This leaves a ton of room for other goodies like the compressor (I went with a larger Viair) a small ammo box for tools, water/meth... The compressor only has a few water spots on it, probably from the zoodad mod but other than that, It doesn't overheat or suck in water.
I have the guage in my custom center console. The guage that comes with the kit (assuming single needle) could be replaced with any 2 1/16 guage. I replaced it with an Autometer 0-150 psi guage that matches the rest of my guages. I almost mounted the switch right next to the 4x4 switch and then placed the guage in my overhead or pillar pod but I ran out of room. It would require a little extra routing of wire and tubing but would make for a clean install.
Scott
sagebel is offline
Old 12-29-2006, 12:40 PM   #10 (permalink)
Mounted mine under the passanger frame rail in a SS box. Mine is rated to wet conditions, but in the box it stays dry.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 12-30-2006, 03:30 PM   #11 (permalink)
overfly's Avatar
My Photos: (16)
I mounted mine under the hood, passenger side. I'll take a picture and post it.
2006 F350 - Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
overfly is offline
Old 12-30-2006, 03:45 PM   #12 (permalink)
Thanks overfly I'll be looking for that.
B&W hitch
1999 Case IH C50
2007 Cougar 302RLS
Old 12-30-2006, 05:57 PM   #13 (permalink)
overfly's Avatar
My Photos: (16)
Got a picture posted. Just click the link in my signature. [img]/ubbthreads/images/graemlins/grin.gif[/img]
overfly is offline
Old 12-30-2006, 06:44 PM   #14 (permalink)
I looked but didnt see anything
B&W hitch
1999 Case IH C50
2007 Cougar 302RLS
Old 12-30-2006, 08:18 PM   #15 (permalink)
overfly's Avatar
My Photos: (16)
Try here. I accidently named the file "Vacuum Pump". Not sure what I was thinking because it's the air compressor..... [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
overfly is offline
Search for used vehicles by ZIP, p
