Old 07-08-2007, 12:18 AM   #1 (permalink)
Fith Wheel Hitches???????? help please!
Hello Guy's
Well I have researched our fith wheel hitch, we are going to go with pullRite super rails & super mounting brackets & for the hitch I realy like the TS3 air ride hitch from Trailsaver hitches in MI.
I like the rails to be under the bead or easily removed to clean the bed! The only problem with Trail saver hitch is the way it lock around the pin, it uses two pieces that close together around the pin like a clam shell leaving the trailer pulling against the opening of the latch???? where the Super 5th uses a cam that loops arount the pin only problem with the Super 5th is it is fixed (ridged mount).
Let me know if any of you are running this set up in your Rig & how do you like it.
Originaly I was thinking about the Super 5th 20.5k from PullRite & a Mor-Ride pin box, I think the Air ride hitch is the way to go.
If any one has or is using the Trailsaver TS3 with the Holland Binkly head how do you like it????
What suggestions do you recomend for the Air compressor & tank, I am also going to install Big Rig air Horns!
Thanks...........Chris
2008 F-450 King Ranch Copper & Gold with every thing but the kitchen sink!
Ordered date was June 12th/07
Build Date July ?/07
Delivery Date August 01/07
Will post lots of picks of our new Rig.
Web Album http://picasaweb.google.com/happycamper64
2006 Antiqua Travel Trailer (Starcraft)
1999 Chev Astro,
Mods for towing, Rancho Shocks, HD Sway bars, Locker Diff, Aerotravel Wind Deflector, Gibson Dual Cat back exhaust, MSD 6AL & blaster coil, AirAid cold air intake, Dual Electric fans, Firestone Air bags with compressor, Windmaster Aerofoil Wind Deflector.
Traided in our Antiqua travel trailer for a 2007 Terry Resort 29.9 Fithwheel (Our First fiver)
cstones is offline
Old 07-08-2007, 12:25 AM   #2 (permalink)
Re: Fith Wheel Hitches???????? help please!
This thread I think can help you out... Fiver Hitch (Air ride 0r fixed hitch)
I am Fordless, SOLD>>> 1999 F350 XLT 7.3 SD SC DRW 4:10 LS Auto Trans 4x4 Auto Hubs APC Telescoppic Heated Power Tow Mirrors K&N Filter Banks 3 1/2 down pipe ATS 4" exhaust 3 gauge (ET, trans temp, turbo boost) pillar mount WD Chip WD Turbo Brake
Steve F. is offline
Old 07-08-2007, 09:50 AM   #3 (permalink)
Hello Steve
Thanks for the link to that post, I was the originator of that post as well.
I am looking for more input on fith wheel hitches & some feed back on the hitches that I am looking to buy. purchasing this hitch could be a farly large investment & I will have it for many years of sevice!
Thank You for any & all advice on this topic.
I will post lots of pic's as soon as we get our Rig
Thank You
Chris
1999 Chev Astro,
cstones is offline
Old 07-08-2007, 10:34 AM   #4 (permalink)
Just pointing the thread out to you, the reason I did that is because I thought maybe you didn't see it because of where posted this thread first [img]/ubbthreads/images/graemlins/wink.gif[/img]
I'm sure someone can help on the things you ask...
All I can point out to you is one thing and I'm not sure if it will help or not. Back when I was towing I had an 18,000lb Reese and its jaws (2 piece) did rotate over the pin and the opening (center of it) did point to the rear of the truck, I had no problems with that type of design.
Steve F. is offline
Old 07-08-2007, 06:43 PM   #5 (permalink)
Dieselgem's Avatar
My Photos: (14)
I am going with the Pullrite Super 5-25K, with a 5th airborne on the trailer The trailer has mor-ride suspension. I had previously used a Pullrite superglide on a short bed truck and like the system. I really like the how it hitches.
2008 F450- Truck Pictures
2008-41'CKS KZ Escalade Toyhauler
Toy Hauler Pictures
Dieselgem is offline
Old 07-08-2007, 09:50 PM   #6 (permalink)
Hello Dieselgem
Once again I will say, Very nice Rig!
How did you mount your rails, did you use the universal mounts or the Super rails & Super brackets??
PullRite dose not have a listing for our 2008 450, I will be calling PullRite on Monday to see if they have the super mounting system in production yet!
Thanks......Chris
1999 Chev Astro,
cstones is offline
Old 07-08-2007, 10:49 PM   #7 (permalink)
Dieselgem's Avatar
My Photos: (14)
I have not had the 25k installed in the new truck yet. I spoke to pullrite early this week and the new brackets are ready. I am using the super rail mounting and having the hitch installed at Dan's in Elkhart Indiana, when I pick up the new trailer. I am finishing the back-up camera wiring and the reverse horn alert tomorrow. I will take photo's of the hitch for you when I get it installed.
Toy Hauler Pictures
Old 07-09-2007, 09:00 PM   #8 (permalink)
What type of camera system are you going to install??? We to also wanted the factory rear camera system but it is not available yet!
Thanks..........Chris
1999 Chev Astro,
cstones is offline
Old 07-09-2007, 09:59 PM   #9 (permalink)
if you order now, you can get the rear camera, it is being installed for 08 job2 and that (job2) is all that can be ordered now.
Steve F. is offline
Old 07-10-2007, 06:51 AM   #10 (permalink)
Thanks Steve for the heads up!
I will Call the sales department this morrning & see if I can add the rear camera to our build, our build date is July 30th there should not be a problem.
1999 Chev Astro,
cstones is offline
Old 07-10-2007, 07:12 AM   #11 (permalink)
Good Morning Group!
Contacted PullRite yesterday! they informed me they do have the Super Brackets & Super rail system in stock! part # 0841 retail $675. Camping World disscounts them @ $609. Super5th 20.5 hitch retail @ $994. Camping World $899.
We have decided to go with Super5th 20.5 because of how the locking arm swings around the pin box, as far as the air ride I will install the AirBorn pin box.
Thanks for all the advice!
This waiting for our Rig is killing me!!!! I must @ least visit the Ford lot 2>3 times weakly after work, & the local Rv Lots as well!
"BTW" we traded in our Antigua travel trailer on the weekend for a "Fiver".
Thanks........Chris
1999 Chev Astro,
cstones is offline
