Old 05-18-2006, 11:34 AM   #1 (permalink)
flashing my trailer marker lights
I have an 05 crewcab.When i tow my 5th wheel i'd like to be able to flash the trailer marker lights when someone lets me in.Does anyone have a thought on how to do this ???? I figure i'll just put a toggle or a push button somewhere on the dash....just need to find out how to hook the darn thing up.If it can be done ???
thanks
2005 f250 cc Lb 2wd PSD
rocky7184 is offline
Old 05-18-2006, 12:02 PM   #2 (permalink)
Re: flashing my trailer marker lights
<font color="green">If your trailer lights are wired as they should be, totally independent of the headlight system, then you simply flip the trailer-light switch.
I am not a big fan of the factory supplied trailer wiring harness, as it is not independent of the truck lighting system.
They are popular, only because any idiot can plug in a trailer harness.
Trailer lights should be on there own dedicated system, totally independent of any part of the factory wiring, drawing power direct from a battery terminal. </font>
1985 F-350
5.9 CUMMINS TURBO DIESEL
G360 GETRAG 5-sp
3:55 DANA 70
LongRider is offline
Old 05-18-2006, 12:03 PM   #3 (permalink)
D_Dunn's Avatar
My Photos: (28)
rocky7184,
I wired my truck up to do that. There were a couple threads about doing it a while back. Mine isn't the most technical, but it works. Click here to see the switch. I spliced into the taillight wire coming out of the headlight switch and routed it through that switch. It's a "momentary off" when you push down. The only down-side is that it blinks everything except the headlights. That includes the front markers and the dash lights. A TDS member had posted about a setup he used utilizing relays, which would even flash them on when the lights were off. Maybe he'll chime in.
Hope this helps...
Dan
My Truck Pics
2000 F-350 Lariat 4x4 Crewcab longbed dually PSD 6 speed with: DP Tuner F5 16-pos. chip; Ford AIS air intake with fender sleeve & Zoodad mod; ITP boost regulator; fumoto valve; DPPI MBRP 4" turbo-back "cool duals" exhaust and 5x18 ITP stainless tips; Triple gauge A-pillar with Isspro EV gauges; "wicked wheel"; AIH delete plug with code eliminator and boost hookup; intercooler foil wrap removed; LED taillight mod, clear headlights, corner lights, cab lights, & dually fender lights; front-mounted 2" receiver, Putco Bossboards; Pace Edwards rolltop tonneau; acetoned badges; rear vision camera & reverse sensors; KC backup lights; C-Betr mirrors; cab lights & fender lights wired as turn signals; LED ID bar; Jordan 2020 Ultima trailer brake; harpoon mod; and more
D_Dunn is offline
Old 05-18-2006, 12:21 PM   #4 (permalink)
Black05's Avatar
There is an easier and less expensive solution. Just activate your emergency flashers for two flashes then deactivate.
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
Old 05-18-2006, 01:20 PM   #5 (permalink)
JimTJr's Avatar
My Photos: (6)
yea, E-flasher for a second that is what I do,, or barely tap the brakes a couple times, that gets the point across. I would hate to cut into the wireing and mess with stuff like that for such a trivial reason, no offence. But when you mess with the wireing, you are asking for possible troubles down the road, ya know?
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 05-18-2006, 01:52 PM   #6 (permalink)
Blue Water Runner's Avatar
That is what I have always done. [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Straight Pipe,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer
My Pictures
Blue Water Runner is offline
Old 05-18-2006, 01:58 PM   #7 (permalink)
I always thought it would be fun to mount a seperate set of "thank you" lights on the back of the truck. Couple of strobes, or a Bat Signal thrown onto the ground with laser beams LOL (OK maybe that might be a tad much) but skies the limit on that deal. How about a LED board that says thank you...
Just eating rainbows and butterflies
01 F350 dually 4x4 CC auto.
311 hp 610 torque a while back.
My Pickup
Some Photos and Sound Clips
Diesel Power & Performance Derby Ks.
#46
Kanman is offline
Old 05-18-2006, 02:06 PM   #8 (permalink)
I came up with a mod that requires three SPDT relays and a momentary switch/button. It is all tied to the wiring harness behind the headlight switch, and once the relays are wired, it only requires a few simple connections to be up and running. If you ever have any trouble with it, you just pop out the healight switch and put the parking light wire back together and everything is back to normal.
The single momentary button will turn your markers on if the headlight switch is off, and blink them off if the factory switch is on. Headlight operation is not affected, but the fogs will go off with the parks. The only real drawback is that you cannot flash your p-lights off if they have been turned on by the autolamp system.
Here's the link
2003 F350 CC, Short, XLT Sport (leather), 7.3PSD, Auto, 4x4. Homemade Tymar, Blizzard 810 Power Plow
a93bowtie is offline
Old 05-18-2006, 02:54 PM   #9 (permalink)
That's exactly what I do and that's what I did when I drove 18 wheelers too.
Capt Ron
May 2003 F-350, CC, DRW, 6.0L, 6sp man, LB, Al Wheels, Moon Roof, 52gal tranfer tank. Hitches: Draw-Tite 16K 4X and B&W GN, 8040lbs GVW. Towing 35' Newmar Kountry Star 5th Wheel Camper, 14,000lbs GVW, or Wells Cargo 24' Car Hauler, 12,000lbs GVW.
CaptRon is offline
Old 05-18-2006, 03:30 PM   #10 (permalink)
Lotsa good idea's fer shure.The easiest would be to do nothing and just use the emergency flashers.And as far as breaking into the wiring goes.....i don't really like to do that but sometimes you just gotta.
I could just keep doing what i've been doing(using my turn sig after moving over),but i wanted to do something different just for the heck of it.
I'll look into that link using those relays and see what that looks like.
thanks for the suggestions guys
Old 05-18-2006, 03:42 PM   #11 (permalink)
I thought that the trailer wiring in the SuperDuties was a separate run originating in a set of relays under the hood? If that is true, could you not then just add a momentary 12v feed to the trailer lights at that point (after the relay) so that it would not affect the truck wiring?
Mark - AMC '78
'00 F350 CC 4x4 LB Lariat - f/r Ranch Hand replacements, gooseneck, TekStyle Profile tonneau, coolant filter, Zoodad mod, AIH mod, GOS headlight harness w/ silverstars, pure sine 120 volt inverter, multiple aux power points, aux. platform for laptop/GPS nav, 2 Meter/70cm Yaesu 7800 ham rig, 11 meter Galaxy 949 (peaked) with Wilson 1000.
mgwerks is offline
Old 05-18-2006, 04:10 PM   #12 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
[/ QUOTE ]I have the relays from a post by B.O.B. in a snow plowing forum. It works great for me.
haul_n_horses2 is offline
Old 05-18-2006, 04:50 PM   #13 (permalink)
I do the E-flash thing. I had a CB in my last truck so I would also tell them thanks over the radio. I haven't got around to installing one in this truck.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
Old 05-18-2006, 05:12 PM   #14 (permalink)
Wasn't his name over there... EZSnow? [img]/ubbthreads/images/graemlins/cool.gif[/img]
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
Performance Mods: ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body ||| LEDs everywhere: taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions, aux backup lights in bumper ||| Misc. Mods: no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX
My Truck Pics
NorCal Powerstrokes
ryaneverk2 is offline
Old 05-18-2006, 06:11 PM   #15 (permalink)
Yep, my handle "over there" is EZSnow
This is the original thread where it all began. You may have to register to view those forums, but it's well worth it. Good place, great people.
